[GeoNode-users] Admin auto login with geoserver not working
Toni Schönbuchner toni.schoenbuchner at csgis.de
Sun May 7 23:05:01 PDT 2017
Francesco,
thanks a lot for your reply. From you answer I assume that this point
All we need to do now is to integrate GeoNode authentication so that GeoNode administrator will be able to access and administer GeoServer as well.
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geoserver_application.html#geonode-authentication-integration>
has changed in 2.6. Can you say why? For me this was a handy feature as one
does not have to remember geoserver login credentials (which can be different
from geonode.)
thanks and a good start to the week,
toni
> Am 07.05.2017 um 23:58 schrieb Francesco Bartoli <xbartolone at gmail.com>:
> Hi Toni,
> this behavior is expected, the first time you access geoserver from geonode you have to login with the button on top of the page.
> Francesco
> Il giorno 07/mag/2017, alle ore 20:38, Toni Schönbuchner <toni.schoenbuchner at csgis.de> ha scritto:
>> Hi,
>> this might be easy. On a Ubuntu 14.04 and 16.04 vagrant
>> I´ve installed geonode 2.6a1 and 2.6c1 from apt and from git!
>> In every test case the geonode admin user is not automatically logged-in
>> in geoserver. Even if I add GEONODE_BASE_URL (192.168.100.1)
>> to web.xml as the documentation suggests nothing changes.
>> The session cookie is valid for 192.168.100.1 / means geoserver
>> should be able to read it.
>> Has something changed with geoserver (2.9-SNAPSHOT) autologin in 2.6?
>> cheers,
>> Toni
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170508/2175c1c5/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170508/2175c1c5/attachment.sig>
More information about the geonode-users mailing list
