[GeoNode-users] Admin auto login with geoserver not working
Simone Dalmasso simone.dalmasso at gmail.com
Mon May 8 00:25:31 PDT 2017
Hi Toni,
GeoNode and Geoserver now authenticate and authorise via oauth2, you will
find a handy button in geoserver (with the geonode logo) to authenticate
easily.
2017-05-08 8:05 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
> Francesco,
> thanks a lot for your reply. From you answer I assume that this point
> All we need to do now is to integrate GeoNode authentication so that
> GeoNode administrator will be able to access and administer GeoServer as
> well.
> http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_install/install_geoserver_application.html#
> geonode-authentication-integration
> has changed in 2.6. Can you say why? For me this was a handy feature as one
> does not have to remember geoserver login credentials (which can be
> different
> from geonode.)
> thanks and a good start to the week,
> toni
> Am 07.05.2017 um 23:58 schrieb Francesco Bartoli <xbartolone at gmail.com>:
> Hi Toni,
> this behavior is expected, the first time you access geoserver from
> geonode you have to login with the button on top of the page.
> Francesco
> Il giorno 07/mag/2017, alle ore 20:38, Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> ha scritto:
> Hi,
> this might be easy. On a Ubuntu 14.04 and 16.04 vagrant
> I´ve installed geonode 2.6a1 and 2.6c1 from apt and from git!
> In every test case the geonode admin user is not automatically logged-in
> in geoserver. Even if I add GEONODE_BASE_URL (192.168.100.1)
> to web.xml as the documentation suggests nothing changes.
> The session cookie is valid for 192.168.100.1 / means geoserver
> should be able to read it.
> Has something changed with geoserver (2.9-SNAPSHOT) autologin in 2.6?
> cheers,
> Toni
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170508/b357a305/attachment.html>
More information about the geonode-users mailing list
