[GeoNode-users] geonode-users Digest, Vol 28, Issue 21
Federico Gianoli alpacagis at gmail.com
Sat May 13 03:59:28 PDT 2017
It's me :)
I have solved the problem,
really I don't understand how, but I have removed the last layers correctly
uploaded before the issue, then I rebooted the server and now everythings
it is working fine.
I should study more how Geoserver works.
I hope you have a nice week-end
Fede
2017-05-13 12:11 GMT+02:00 Federico Gianoli <alpacagis at gmail.com>:
> Thanks Toni,
> I am trying to understand how to fix this error, and I don't understand
> why this has happened later than more than 50 layer correctly uploaded.
> In Geoserver page, I am not able to identify where to check geowebcache,
> in Tile layer window all seems working fine, I have empty cache tile, etc.
> I have check Geoserver logs and there is this error message:
> 2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Returning
> VectorAccessLimits [readAttributes=null, writeAttributes=null,
> writeFilter=Filter.EXCLUDE, readFilter=Filter.EXCLUDE, mode=HIDE] for layer
> geonode:permian_wajid_gaara_aquifers_region and user
> 2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Getting access
> limits for workspace geonode
> 2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Getting admin
> auth for Workspace geonode
> 2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - AdminAuth filter:
> RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs
> ip:"147.162.47.102"+ serv:ANY req:ANY ws:"geonode"+ layer:ANY]
> 2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence.cache] - AdminAuth
> Request for RuleFilter[user:(empty)+ role:ANY inst:name+:default-gs
> 2017-05-13 05:39:19,369 DEBUG [org.geoserver.geofence] - Admin auth for
> User: Workspace:geonode: false
> 2017-05-13 05:39:19,369 ERROR [org.geoserver.ows] -
> org.geoserver.platform.ServiceException: Could not find layer
> at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(
> GetMapKvpRequestReader.java:1341)
> at org.geoserver.wms.map.GetMapKvpRequestReader.read(
> GetMapKvpRequestReader.java:240)
> GetMapKvpRequestReader.java:85)
> at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1498)
> at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:673)
> at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:258)
> at org.springframework.web.servlet.mvc.AbstractController.handleRequest(
> AbstractController.java:147)
> at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter
> .handle(SimpleControllerHandlerAdapter.java:50)
> at org.springframework.web.servlet.DispatcherServlet.
> doDispatch(DispatcherServlet.java:959)
> doService(DispatcherServlet.java:893)
> at org.springframework.web.servlet.FrameworkServlet.processRequest(
> FrameworkServlet.java:968)
> doGet(FrameworkServlet.java:859)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
> service(FrameworkServlet.java:844)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
>  Thanks a lot
> Federico
> 2017-05-13 5:52 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
>> Hi Federico,
>> have you checked your log files like geoserver etc ?
>> I had a similar behavior once. First I´ve tested the layer in
>> geoserver layer preview. Everything worked fine. I don´t remember
>> why and how but found that there are invalid layers in geowebcache.
>> After removing them and a restart it worked again.
>> As said logs first ;)
>> Cheers,
>> Toni
>> > Message: 1
>> > Date: Sat, 13 May 2017 00:34:53 +0200
>> > From: Federico Gianoli <alpacagis at gmail.com>
>> > To: geonode-users at lists.osgeo.org
>> > Subject: [GeoNode-users] Error in layer preview, geonode 2.6
>> > Message-ID:
>> >       <CAO9K6eqGBg39WNm5zRWb1r08uV4Em0ofZRGPNa0mJ+-A16BcAw at mail.g
>> mail.com>
>> > Content-Type: text/plain; charset="utf-8"
>> > Dear list,
>> > I have a problem with Geonode 2.6,
>> > when I upload a layer, I can see the thumbnail with the correct
>> symbology
>> > and location,
>> > but when I open the layer page, I am not able to see neither layer
>> preview
>> > nor legend.
>> > I rebooted the server several times,I tried with a lot of different data
>> > and symbologies but without results...
>> > I have already populated my geonode with more than 50 layers without
>> > problems and now I'm not able to understand what is happened. I tried
>> with
>> > another Geonode istance and everythings works correctly.
>> > Has somebody had the same issue?
>> > Thanks a lot
>> > Federico
>> > [image: Immagine incorporata 1]
>> > [image: Immagine incorporata 2]
>> > -------------- next part --------------
>> > An HTML attachment was scrubbed...
>> > URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/
>> 20170513/8cad597c/attachment.html>
>> > A non-text attachment was scrubbed...
>> > Type: image/png
>> > Desc: not available
>> 20170513/8cad597c/attachment.png>
>> > Type: image/png
>> > Desc: not available
>> 20170513/8cad597c/attachment-0001.png>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170513/4fcc0375/attachment-0001.html>
More information about the geonode-users mailing list
