[GeoNode-users] GeoNode versions and branches
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue May 16 01:18:01 PDT 2017
Dear all,
I'm going to start this thread in order to summarize a bit the status of
GeoNode branches and current versions.
2.6rc1
This is a stable version candidate for the release, which will happen
during this week.
On GitHub this is related to the branch 2.6.x
GeoNode 2.6 works against GeoServer 2.9 with OAuth2 authentication
master and 2.7.x
At the time I'm writing this email, those two are aligned.
2.7.x will become the new stable branch right after the release. A sort of
soft-freeze of master features, where only approved improvements and
bug-fixes related to Issues and PRs will be backported.
"master" (which currently is GeoNode 2.7.x) works against GeoServer 2.10
*WARNING:* *The old master branch has been switched to "notifications" one.
In order to re-align your code you can either:*
*1. Do a fresh checkout*
*2. Follow the instructions below*
# re-align branches
git branch -f new_name HEAD
git checkout new_name
git branch --set-upstream-to=origin/new_name new_name
git push --set-upstream origin new_name
git pull
notifications
This branch is aligned with the old "master" branch and contains a work
(almost ready) allowing GeoNode to enable an external broker for
notifications and signals. This is an important step toward an Enterprise
version of GeoNode, moving it a step forward with:
1. Advanced monitoring and alerting features
2. Clustering and multi-tenancy capabilities
3. Cloud-ready component
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170516/1ce0c7e7/attachment-0001.html>
More information about the geonode-users mailing list
