[GeoNode-users] Problem in geonode updatelayers
Davi Custodio davicustodio at gmail.com
Tue May 16 05:20:56 PDT 2017
Hi everyone, I'm using Geonode 2.4 and I'm having trouble running the
"geonode updatelayers" command.
When I run the command I get the following error log:
root at ide-cnpma:~# geonode updatelayers
  File "/usr/bin/django-admin.py", line 5, in <module>
    management.execute_from_command_line()
  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
399, in execute_from_command_line
    utility.execute()
  File
392, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 242, in run_from_argv
    self.execute(*args, **options.__dict__)
line 285, in execute
    output = self.handle(*args, **options)
  File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
line 108, in handle
    remove_deleted=remove_deleted)
  File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
395, in gs_slurp
    resources = cat.get_resources()
  File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 723,
in get_resources
    for ws in self.get_workspaces():
  File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 861,
in get_workspaces
    description = self.get_xml("%s/workspaces.xml" % self.service_url)
  File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 211,
in get_xml
    response, content = self.http.request(rest_url)
  File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1569,
in request
    (response, content) = self._request(conn, authority, uri, request_uri,
method, body, headers, redirections, cachekey)
  File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1316,
in _request
    (response, content) = self._conn_request(conn, request_uri, method,
body, headers)
  File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1251,
in _conn_request
    conn.connect()
  File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 900,
in connect
    self.sock.connect((self.host, self.port) + sa[2:])
  File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 424, in
connect
    self.__negotiatehttp(destpair[0], destpair[1])
  File "/usr/lib/python2.7/dist-packages/httplib2/socks.py", line 390, in
__negotiatehttp
    raise HTTPError((statuscode, statusline[2]))
httplib2.socks.HTTPError: (403, 'Forbidden')
Can anyone give a tip on what might be causing the problem?
Thank you.
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170516/ac7bdb52/attachment-0001.html>
More information about the geonode-users mailing list
