[GeoNode-users] [GeoNode-devel] GeoNode versions and branches
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 16 07:22:06 PDT 2017
Great thanks Alessio!
2017-05-16 16:20 GMT+02:00 Jeffrey Johnson <jeff at terranodo.io>:
> Alessio. Thanks so much for this housekeeping and the detailed
> explanation. Looking forward to the notifications work being stable
> and to 2.6 finally :)
> On Tue, May 16, 2017 at 1:18 AM, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Dear all,
> > I'm going to start this thread in order to summarize a bit the status of
> > GeoNode branches and current versions.
> > 2.6rc1
> > This is a stable version candidate for the release, which will happen
> during
> > this week.
> > On GitHub this is related to the branch 2.6.x
> > GeoNode 2.6 works against GeoServer 2.9 with OAuth2 authentication
> > master and 2.7.x
> > At the time I'm writing this email, those two are aligned.
> > 2.7.x will become the new stable branch right after the release. A sort
> of
> > soft-freeze of master features, where only approved improvements and
> > bug-fixes related to Issues and PRs will be backported.
> > "master" (which currently is GeoNode 2.7.x) works against GeoServer 2.10
> > WARNING: The old master branch has been switched to "notifications" one.
> In
> > order to re-align your code you can either:
> > 1. Do a fresh checkout
> > 2. Follow the instructions below
> > # re-align branches
> > git branch -f new_name HEAD
> > git checkout new_name
> > git branch --set-upstream-to=origin/new_name new_name
> > git push --set-upstream origin new_name
> > git pull
> > notifications
> > This branch is aligned with the old "master" branch and contains a work
> > (almost ready) allowing GeoNode to enable an external broker for
> > notifications and signals. This is an important step toward an Enterprise
> > version of GeoNode, moving it a step forward with:
> > 1. Advanced monitoring and alerting features
> > 2. Clustering and multi-tenancy capabilities
> > 3. Cloud-ready component
> > Best Regards,
> > Alessio Fabiani.
> > GeoServer Professional Services from the experts!
> > Visit http://goo.gl/it488V for more information.
> > Ing. Alessio Fabiani
> > @alfa7691
> > github
> > Founder/Technical Lead
> > GeoSolutions S.A.S.
> > Via di Montramito 3/A
> > 55054  Massarosa (LU)
> > Italy
> > phone: +39 0584 962313
> > fax:     +39 0584 1660272
> > mob:   +39 331 6233686
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> > finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio
> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> > via e-mail e di procedere alla distruzione del messaggio stesso,
> > cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> per
> > finalità diverse, costituisce comportamento contrario ai principi dettati
> > dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely
> for
> > the attention and use of the named addressee(s) and may be confidential
> or
> > proprietary in nature or covered by the provisions of privacy act
> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> > copying, distribution, or either dissemination, either whole or partial,
> is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> > information in this message that has been received in error. The sender
> does
> > not give any warranty or accept liability as the content, accuracy or
> > completeness of sent messages and accepts no responsibility  for changes
> > made after they were sent or for other risks which arise as a result of
> > e-mail transmission, viruses, etc.
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Jeffrey Johnson
> Managing Principal
> p: 17602089488
> e: jeff at terranodo.io
> w: terranodo.io
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170516/54c6ee34/attachment-0001.html>
More information about the geonode-users mailing list
