[GeoNode-users] GeoNode versions and branches
Francesco Bartoli xbartolone at gmail.com
Tue May 16 13:25:02 PDT 2017
Great work Alessio.
Thanks,
Francesco
16 mag 2017, 10:19 +0200, Alessio Fabiani <alessio.fabiani at geo-solutions.it>, ha scritto:
> Dear all,
> I'm going to start this thread in order to summarize a bit the status of GeoNode branches and current versions.
> 2.6rc1
> This is a stable version candidate for the release, which will happen during this week.
> On GitHub this is related to the branch 2.6.x
> GeoNode 2.6 works against GeoServer 2.9 with OAuth2 authentication
> master and 2.7.x
> At the time I'm writing this email, those two are aligned.
> 2.7.x will become the new stable branch right after the release. A sort of soft-freeze of master features, where only approved improvements and bug-fixes related to Issues and PRs will be backported.
> "master" (which currently is GeoNode 2.7.x) works against GeoServer 2.10 with OAuth2 authentication
> WARNING: The old master branch has been switched to "notifications" one. In order to re-align your code you can either:
> 1. Do a fresh checkout
> 2. Follow the instructions below
> > # re-align branches
> > git branch -f new_name HEAD
> > git checkout new_name
> > git branch --set-upstream-to=origin/new_name new_name
> > git push --set-upstream origin new_name
> > git pull
> notifications
> This branch is aligned with the old "master" branch and contains a work (almost ready) allowing GeoNode to enable an external broker for notifications and signals. This is an important step toward an Enterprise version of GeoNode, moving it a step forward with:
> 1. Advanced monitoring and alerting features
> 2. Clustering and multi-tenancy capabilities
> 3. Cloud-ready component
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github (https://github.com/afabiani?tab=overview)
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313 (tel:+39%200584%20962313)
> fax: +39 0584 1660272 (tel:+39%200584%201660272)
> mob: +39 (tel:+39%C2%A0331%206233686)331 6233686 (tel:+39%C2%A0331%206233686)
> http://www.geo-solutions.it (http://www.geo-solutions.it/)
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170516/969fb8f1/attachment.html>
More information about the geonode-users mailing list
