[GeoNode-users] geonode-users Digest, Vol 28, Issue 33
Toni Schönbuchner toni.schoenbuchner at csgis.de
Fri May 19 02:08:40 PDT 2017
To answer my own question:
it´s var NOTIFICATION_LOCK_LOCATION = '/home/vagrant/geonode/lockdir/‚
which must be set when notification is enabled. It´s of big importance
that the geonode user (in my case www-data) has write access to it.
First I´ve had the issue that the var did not do anything. But after double checking
permissions again it works. Maybe this should go into the offical docs?
cheers,
Toni
> Am 18.05.2017 um 18:55 schrieb geonode-users-request at lists.osgeo.org:
> Hi,
> on a geonode 2.4 I´m running in following error:
> LockFailed at /maps/976/remove
> failed to create /var/www/ber-geonode03vm.Dummy-1-16282
> Django Version:	1.6.11
> Exception Type:	LockFailed
> Exception Value:
> Exception Location:	/usr/lib/python2.7/dist-packages/notification/lockfile.py in acquire, line 249
> Python Executable:	/usr/bin/python
> Python Version:	2.7.6
> For me this looks like the user which geonode runs with tries to write to /var/www, correct?
> How can I change the path (something else than /var/www). And what is this written file for?
> Cheers,
> Toni
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170519/fd23c754/attachment.html>
More information about the geonode-users mailing list
