[GeoNode-users] geonode-users Digest, Vol 28, Issue 33
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri May 19 03:02:07 PDT 2017
thanks for digging into this.
Yes, absolutely this should go into docs.
If you cannot do this, maybe, in order to avoid losing track of this, you
can open an issue reporting those findings and explanations?
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, May 19, 2017 at 11:08 AM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> To answer my own question:
> it´s var NOTIFICATION_LOCK_LOCATION = '/home/vagrant/geonode/lockdir/‚
> which must be set when notification is enabled. It´s of big importance
> that the geonode user (in my case www-data) has write access to it.
> First I´ve had the issue that the var did not do anything. But after
> double checking
> permissions again it works. Maybe this should go into the offical docs?
> cheers,
> Toni
> Am 18.05.2017 um 18:55 schrieb geonode-users-request at lists.osgeo.org:
> Hi,
> on a geonode 2.4 I´m running in following error:
> LockFailed at /maps/976/remove
> failed to create /var/www/ber-geonode03vm.Dummy-1-16282
> Django Version: 1.6.11
> Exception Type: LockFailed
> Exception Value:
> Exception Location: /usr/lib/python2.7/dist-packages/notification/lockfile.py
> in acquire, line 249
> Python Executable: /usr/bin/python
> Python Version: 2.7.6
> For me this looks like the user which geonode runs with tries to write to
> /var/www, correct?
> How can I change the path (something else than /var/www). And what is this
> written file for?
> Cheers,
> Toni
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170519/35a2746e/attachment.html>
More information about the geonode-users mailing list
