[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Federico Gianoli alpacagis at gmail.com
Fri May 19 04:08:23 PDT 2017
Thanks a lot Alessio,
I have changed the files according to your suggestions,
but now I have this error:
*$ sudo python manage.py backup --backup-dir=backup/*
*Before proceeding with the Backup, please ensure that:*
* 1. The backend (DB or whatever) is accessible and you have rights*
* 2. The GeoServer is up and running and reachable from this machine*
*You want to proceed? [n]|y: y*
*Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
<http://212.237.232.12/geoserver/>]' into
'backup/2017-05-19_050730/geoserver_catalog.zip'.*
*Traceback (most recent call last):*
*  File "manage.py", line 11, in <module>*
*    execute_from_command_line(sys.argv)*
*  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line*
*    utility.execute()*
*  File
346, in execute*
*    self.fetch_command(subcommand).run_from_argv(self.argv)*
*  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv*
*    self.execute(*args, **cmd_options)*
line 445, in execute*
*    output = self.handle(*args, **options)*
*  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
line 101, in handle*
*    gs_backup = r.json()*
*  File "/usr/lib/python2.7/dist-packages/requests/models.py", line 808, in
json*
*    return complexjson.loads(self.text, **kwargs)*
*  File "/usr/lib/python2.7/json/__init__.py", line 339, in loads*
*    return _default_decoder.decode(s)*
*  File "/usr/lib/python2.7/json/decoder.py", line 364, in decode*
*    obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
*  File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode*
*    raise ValueError("No JSON object could be decoded")*
*ValueError: No JSON object could be decoded*
*Thanks a lot for your help*
*Fede*
2017-05-05 16:41 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> PR here
> https://github.com/GeoNode/geonode/pull/3031
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Dear all,
>> currently the backup and restore utility should be aligned with latest
>> updates I guess. There are also several issues / improvements we are
>> working on to improve this tool.
>> We will find some spare time soon to devote to those tasks. We will send
>> updates as soon as possible.
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <0584%20962313>
>> fax:     +39 0584 1660272 <0584%20166%200272>
>> mob:   +39 331 6233686 <331%20623%203686>
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi Federico,
>>> there seems to be an issue in the commands, simplejson is not available
>>> anymore, json has to be used. we should fix it.
>>> @afabiani, is that correct?
>>> https://github.com/GeoNode/geonode/blob/2.6.x/geonode/base/m
>>> anagement/commands/restore.py#L28
>>> anagement/commands/backup.py#L26
>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <alpacagis at gmail.com>:
>>>> Dear all,
>>>> I would like to create a backup of my geonode project and I am using
>>>> this guide: http://docs.geonode.org/en/master/tutorials/admin/bac
>>>> kup_restore/
>>>> From my django admin page (Base => backups) I tried to do a backup,
>>>> but, when I run the backup, on a fully writable folder (777), there is this
>>>> server error:
>>>> Internal Server Error
>>>> The server encountered an internal error or misconfiguration and was
>>>> unable to complete your request.
>>>> I have double checked the settings.ini file, and I have noted that the
>>>> configuration file is not yet update for the 2.6 version, it has these
>>>> lines:
>>>> #Migrate from GN 2.4 to GN 2.4
>>>> migrations = base.resourcebase,layers.layer
>>>> ,layers.attribute,maps.map,maps.maplayer
>>>> manglers   = gn24_to_24.ResourceBaseMangler
>>>> ,gn24_to_24.LayerMangler,gn24_to_24.LayerAttributesMangler,g
>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>> Is it correct? Have I to change these lines accordingly to the 2.6
>>>> version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>> When I try to run the backup from command line there is the following
>>>> error about the file backup.py
>>>> How can I solved this issue?
>>>> Tanks a lot
>>>> Federico
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170519/448866c7/attachment-0001.html>
More information about the geonode-users mailing list
