[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Federico Gianoli alpacagis at gmail.com
Tue May 23 08:45:54 PDT 2017
Hi Alessio,
This is the result of these commands:
*$ python manage.py backup --backup-dir=/tmp/backup/*
*Before proceeding with the Backup, please ensure that: 1. The backend (DB
or whatever) is accessible and you have rights 2. The GeoServer is up and
running and reachable from this machine*
*You want to proceed? [n]|y: y*
*Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
<http://212.237.232.12/geoserver/>]' into
'/tmp/backup/2017-05-23_103754/geoserver_catalog.zip'.*
*STARTED - 1/9COMPLETED - 9/9Traceback (most recent call last):  File
"manage.py", line 11, in <module>    execute_from_command_line(sys.argv)
File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line    utility.execute()  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
346, in execute    self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv    self.execute(*args, **cmd_options)  File
"/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
445, in execute    output = self.handle(*args, **options)  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
line 150, in handle    helpers.copy_tree(gs_data_root, gs_data_folder)
File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
line 203, in copy_tree    for item in os.listdir(src):OSError: [Errno 2] No
such file or directory:
'/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'*
The backup is created but with the error (*OSError: [Errno 2] No such file
or directory:
), and the restore command doesn't work
*$ python manage.py restore
--backup-file=/tmp/backup/2017-05-23_103754/geoserver_catalog.zip*
*Before proceeding with the Restore, please ensure that:*
* 1. The backend (DB or whatever) is accessible and you have rights*
* 2. The GeoServer is up and running and reachable from this machine*
*WARNING: The restore will overwrite ALL GeoNode data. You want to proceed?
[n]|y: y*
*Traceback (most recent call last):*
*  File "manage.py", line 11, in <module>*
*    execute_from_command_line(sys.argv)*
*  File
354, in execute_from_command_line*
*    utility.execute()*
*  File
346, in execute*
*    self.fetch_command(subcommand).run_from_argv(self.argv)*
*  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv*
*    self.execute(*args, **cmd_options)*
line 445, in execute*
*    output = self.handle(*args, **options)*
*  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
line 87, in handle*
*    target_folder = helpers.unzip_file(backup_file, restore_folder)*
*  File
line 227, in unzip_file*
*    z.extractall(target_folder)*
*  File "/usr/lib/python2.7/zipfile.py", line 1040, in extractall*
*    self.extract(zipinfo, path, pwd)*
*  File "/usr/lib/python2.7/zipfile.py", line 1028, in extract*
*    return self._extract_member(member, path, pwd)*
*  File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member*
*    file(targetpath, "wb") as target:*
*IOError: [Errno 13] Permission denied:
u'/tmp/restore/geoserver_catalog/store.dat.1'*
Thanks for your help
Federico
2017-05-23 17:33 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Federico, before doing anything, can you try to do this test?
> sudo mkdir /tmp/backup
> sudo chmod -Rf 777 /tmp/backup
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, May 23, 2017 at 5:24 PM, Federico Gianoli <alpacagis at gmail.com>
> wrote:
>> Hi Alessio,
>> thanks for your quick answer,
>> I have checked, but I have not the files 2 and 3 on my geonode instance.
>> How is it possible? I have installed geonode via ppa.
>> I have overwritten all "commands" folder, in order to be sure to have the
>> latest files, bu it is still not working.
>> There is another way to do the backup?
>> In your opinion, if I upgrade my version of geonode (2.6rc) to the last
>> stable (sudo apt-get upgrade   right?), this issue will be solved?
>> How dangerous could be for my data?
>> Thanks a lot
>> Fede
>> 2017-05-23 12:38 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> Digging to the source code of both GeoNode management command [1] and
>>> GeoServer Backup Plugin [2] and [3], seems like that GeoServer can't access
>>> the "${target_folder}/geoserver_catalog.zip"
>>> The ${target_folder} should be composed by the join of ${backup_dir}
>>> and ${dir_time_suffix}, something like ${backup_dir}/<time_stamp> where
>>> ${backup_dir} is the parameter provided when running the backup command
>>> from GeoNode.
>>> Now, the latest GeoNode code [4] tries to set chmod(777) to this
>>> temporary folder, which will be deleted at the end, in order to allow to
>>> GeoServer to write the file.
>>> That means that most probably the user running GeoNode must have full
>>> rights on the ${backup_dir} folder.
>>> Can you maybe try to double check this?
>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>> ase/management/commands/backup.py#L92
>>> [2] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>> mmunity/backup-restore/rest/src/main/java/org/geoserver/back
>>> uprestore/rest/BackupResource.java#L155
>>> [3] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>> mmunity/backup-restore/core/src/main/java/org/geoserver/back
>>> uprestore/Backup.java#L328
>>> [4] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>> ase/management/commands/backup.py#L86
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, May 23, 2017 at 12:23 PM, Federico Gianoli <alpacagis at gmail.com>
>>> wrote:
>>>> Hi Alessio,
>>>> I have checked the Geoserver Log, and here you can find the complete
>>>> geoserver log: https://pastebin.com/c9JeR1NU
>>>> The error that I have noted on the log is this one:
>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - Unable to perform
>>>> backup: :Could not create file.*
>>>> *2017-05-23 04:49:10,598 DEBUG [geoserver.filters] - Compressing output
>>>> for mimetype: text/plain*
>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - *
>>>> *org.geoserver.rest.RestletException: java.lang.IllegalStateException:
>>>> * at org.geoserver.backuprestore.re
>>>> <http://org.geoserver.backuprestore.re>st.BackupResource.runBackup(BackupResource.java:172)*
>>>> <http://org.geoserver.backuprestore.re>st.BackupResource.handlePost(BackupResource.java:108)*
>>>> The rights of  /usr/share/geoserver/data are these:
>>>> drwxr-xr-x  21 tomcat7 tomcat7      4096 May 23 04:49 data
>>>> I have also changed the folder rights adding user: tomcat7 and
>>>> user:user, but without any result.
>>>> Thanks a lot for your help and your patience
>>>> Federico
>>>> 2017-05-22 16:49 GMT+02:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>>> It is possible that GeoServer cannot write to the target folder. Take
>>>>> a look at the GeoServer logs. Also try to rise up the log level if you
>>>>> don't find anything useful.
>>>>> This can be done from the GeoServer admin gui.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Mon, May 22, 2017 at 4:47 PM, Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> Hi,
>>>>>> which version of GeoServer are you using?
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Fri, May 19, 2017 at 1:08 PM, Federico Gianoli <
>>>>>> alpacagis at gmail.com> wrote:
>>>>>>> Thanks a lot Alessio,
>>>>>>> I have changed the files according to your suggestions,
>>>>>>> but now I have this error:
>>>>>>> *$ sudo python manage.py backup --backup-dir=backup/*
>>>>>>> *Before proceeding with the Backup, please ensure that:*
>>>>>>> <http://212.237.232.12/geoserver/>]' into 'backup/2017-05-19_050730
>>>>>>> <050%20730>/geoserver_catalog.zip'.*
>>>>>>> *  File
>>>>>>> *  File
>>>>>>> 346, in execute*
>>>>>>> *  File
>>>>>>> *  File
>>>>>>> 445, in execute*
>>>>>>> *  File
>>>>>>> line 101, in handle*
>>>>>>> *    gs_backup = r.json()*
>>>>>>> *  File "/usr/lib/python2.7/dist-packages/requests/models.py", line
>>>>>>> 808, in json*
>>>>>>> *    return complexjson.loads(self.text, **kwargs)*
>>>>>>> *  File "/usr/lib/python2.7/json/__init__.py", line 339, in loads*
>>>>>>> *    return _default_decoder.decode(s)*
>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 364, in decode*
>>>>>>> *    obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 382, in
>>>>>>> raw_decode*
>>>>>>> *    raise ValueError("No JSON object could be decoded")*
>>>>>>> *ValueError: No JSON object could be decoded*
>>>>>>> *Thanks a lot for your help*
>>>>>>> *Fede*
>>>>>>> 2017-05-05 16:41 GMT+02:00 Alessio Fabiani <
>>>>>>>> PR here
>>>>>>>> https://github.com/GeoNode/geonode/pull/3031
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <
>>>>>>>>> Dear all,
>>>>>>>>> currently the backup and restore utility should be aligned with
>>>>>>>>> latest updates I guess. There are also several issues / improvements we are
>>>>>>>>> working on to improve this tool.
>>>>>>>>> We will find some spare time soon to devote to those tasks. We
>>>>>>>>> will send updates as soon as possible.
>>>>>>>>> Best Regards,
>>>>>>>>> Alessio Fabiani.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>> Hi Federico,
>>>>>>>>>> there seems to be an issue in the commands, simplejson is not
>>>>>>>>>> available anymore, json has to be used. we should fix it.
>>>>>>>>>> @afabiani, is that correct?
>>>>>>>>>> https://github.com/GeoNode/geonode/blob/2.6.x/geonode/base/m
>>>>>>>>>> anagement/commands/restore.py#L28
>>>>>>>>>> anagement/commands/backup.py#L26
>>>>>>>>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <alpacagis at gmail.com>
>>>>>>>>>>> Dear all,
>>>>>>>>>>> I would like to create a backup of my geonode project and I am
>>>>>>>>>>> using this guide: http://docs.geonode.org
>>>>>>>>>>> /en/master/tutorials/admin/backup_restore/
>>>>>>>>>>> From my django admin page (Base => backups) I tried to do a
>>>>>>>>>>> backup, but, when I run the backup, on a fully writable folder (777), there
>>>>>>>>>>> is this server error:
>>>>>>>>>>> Internal Server Error
>>>>>>>>>>> The server encountered an internal error or misconfiguration and
>>>>>>>>>>> was unable to complete your request.
>>>>>>>>>>> I have double checked the settings.ini file, and I have noted
>>>>>>>>>>> that the configuration file is not yet update for the 2.6 version, it has
>>>>>>>>>>> these lines:
>>>>>>>>>>> #Migrate from GN 2.4 to GN 2.4
>>>>>>>>>>> migrations = base.resourcebase,layers.layer
>>>>>>>>>>> ,layers.attribute,maps.map,maps.maplayer
>>>>>>>>>>> manglers   = gn24_to_24.ResourceBaseMangler
>>>>>>>>>>> ,gn24_to_24.LayerMangler,gn24_to_24.LayerAttributesMangler,g
>>>>>>>>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>>>>>>>>> Is it correct? Have I to change these lines accordingly to the
>>>>>>>>>>> 2.6 version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>>>>>>>>> When I try to run the backup from command line there is the
>>>>>>>>>>> following error about the file backup.py
>>>>>>>>>>> How can I solved this issue?
>>>>>>>>>>> Tanks a lot
>>>>>>>>>>> Federico
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170523/5ff92ca9/attachment-0001.html>
More information about the geonode-users mailing list
