[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Federico Gianoli alpacagis at gmail.com
Tue May 23 13:32:00 PDT 2017
Finally it works!
Thanks Alessio for your help. Tomorrow morning I'll try to migrate data.
Creating manually the folder */home/federico/gn_fede/gn_fede/locale* it
works.
but using restore command without Sudo I have this error
*$ python manage.py restore --backup-file=/tmp/backup/2017-05-23_132655.zip*
*Before proceeding with the Restore, please ensure that:*
* 1. The backend (DB or whatever) is accessible and you have rights*
* 2. The GeoServer is up and running and reachable from this machine*
*WARNING: The restore will overwrite ALL GeoNode data. You want to proceed?
[n]|y: y*
*Traceback (most recent call last):*
*  File "manage.py", line 11, in <module>*
*    execute_from_command_line(sys.argv)*
*  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line*
*    utility.execute()*
*  File
346, in execute*
*    self.fetch_command(subcommand).run_from_argv(self.argv)*
*  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv*
*    self.execute(*args, **cmd_options)*
line 445, in execute*
*    output = self.handle(*args, **options)*
*  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
line 87, in handle*
*    target_folder = helpers.unzip_file(backup_file, restore_folder)*
*  File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
line 224, in unzip_file*
*    os.makedirs(target_folder)*
*  File "/usr/lib/python2.7/os.py", line 157, in makedirs*
*    mkdir(name, mode)*
*OSError: [Errno 13] Permission denied: '/tmp/restore/2017-05-23_132655'*
*with sudo command I have the error later:*
*$ sudo python manage.py restore
*[sudo] password for federico:*
[n]|y: y*
*Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/
<http://212.237.232.12/geoserver/>]' into
'/tmp/restore/2017-05-23_132655/geoserver_catalog.zip'.*
*STARTED - 3/9*
*FAILED - 8/9*
*Cleaned out old GeoServer Data Dir: /usr/share/geoserver/data/data/geonode*
*GeoServer Uploaded Data Restored to
'/usr/share/geoserver/data/data/geonode'.*
*Cleaned out old GeoServer GWC Layers Config:
/usr/share/geoserver/data/gwc-layers*
*Restoring GeoServer Vectorial Data : popolazione_veneto*
*Restoring GeoServer Vectorial Data : gcgw_wells_tayarat*
*Restoring GeoServer Vectorial Data : main_groundwater_flow*
*Restoring GeoServer Vectorial Data : swl_asl*
*Restoring GeoServer Vectorial Data : contour_lines*
*Restoring GeoServer Vectorial Data : swl_asl_map_area*
*Restoring GeoServer Vectorial Data : springs_perennial_no_data*
*Restoring GeoServer Vectorial Data : c0506121_ccs2012s*
*Restoring GeoServer Vectorial Data : tectonic_structures*
*Restoring GeoServer Vectorial Data : springs_perennial*
*Restoring GeoServer Vectorial Data : springs_temporary*
*Operations to perform:*
*  Synchronize unmigrated apps: tasks, modeltranslation, django_extensions,
polymorphic, treebeard, gis, pinax_theme_bootstrap_account,
django_forms_bootstrap, catalogue, humanize, geoserver, storages, mptt,
friendlytagloader, staticfiles, geoexplorer, gn_fede, sitemaps, proxy,
pinax_theme_bootstrap, pagination, autocomplete_light, messages, leaflet,
api, avatar, social, security*
*  Apply all migrations: dialogos, people, tastypie, agon_ratings,
documents, actstream, sites, maps, contenttypes, announcements,
user_messages, layers, sessions, guardian, auth, base, groups, services,
oauth2_provider, account, admin, djcelery, upload, taggit*
*Synchronizing apps without migrations:*
*  Creating tables...*
*    Running deferred SQL...*
*  Installing custom SQL...*
*Running migrations:*
*  No migrations to apply.*
*  Your models have changes that are not yet reflected in a migration, and
so won't be applied.*
*  Run 'manage.py makemigrations' to make new migrations, and then re-run
'manage.py migrate' to apply them.*
*Deactivating GeoNode Signals...*
*...done!*
*Deserializing /tmp/restore/2017-05-23_132655/people.json*
*Installed 2 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/accounts.json*
*Installed 3 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/avatars.json*
*Installed 0 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/backups.json*
*Deserializing /tmp/restore/2017-05-23_132655/licenses.json*
*Installed 7 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/topiccategories.json*
*Installed 20 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/regions.json*
*Installed 259 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/resourcebases.json*
*Installed 13 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/contactroles.json*
*Installed 26 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/links.json*
*Installed 296 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/restrictioncodetypes.json*
*Installed 8 object(s) from 1 fixture(s)*
*Deserializing
/tmp/restore/2017-05-23_132655/spatialrepresentationtypes.json*
*Installed 6 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/useropermissions.json*
*Installed 141 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/groupopermissions.json*
*Deserializing /tmp/restore/2017-05-23_132655/uploadsessions.json*
*Installed 18 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/styles.json*
*Installed 12 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/layers.json*
*Deserializing /tmp/restore/2017-05-23_132655/attributes.json*
*Installed 122 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/layerfiles.json*
*Installed 104 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/maps.json*
*Deserializing /tmp/restore/2017-05-23_132655/maplayers.json*
*Deserializing /tmp/restore/2017-05-23_132655/mapsnapshots.json*
*Deserializing /tmp/restore/2017-05-23_132655/documents.json*
*Installed 1 object(s) from 1 fixture(s)*
*Deserializing /tmp/restore/2017-05-23_132655/tags.json*
*Media Files Restored into '/var/www/geonode/uploaded'.*
*Static Root Restored into '/var/www/geonode/static/'.*
*Reactivating GeoNode Signals...*
*...done!*
*  File
*  File
346, in execute*
*  File
line 290, in handle*
*    static_files_folder)*
*  File
line 203, in copy_tree*
*    for item in os.listdir(src):*
*OSError: [Errno 2] No such file or directory:
'/tmp/restore/2017-05-23_132655/static_dirs/media'*
*Creating manually the folder:
 /tmp/restore/2017-05-23_132655/static_dirs/media everythings works
correctly.*
*Tomorrow morning I'll try again, but I hope to have solved the issue,
thanks again Alessio for your help.*
*Good night*
*Federico*
2017-05-23 21:04 GMT+02:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>:
> I tried to do that yesterday. The file do exist in the path and it was
> allegedly created with no errors. However I’m getting this error:
> python manage.py restore --backup-file=backup/2017-05-17_045850.zip
> System check identified some issues:
> WARNINGS:
> *base.ResourceBase.tkeywords: (fields.W340) null has no effect on
> ManyToManyField.*
> [n]|y: y
> Restoring 'GeoServer Catalog [http://atlas.cidehusdigital.u
> evora.pt/geoserver/]' into '/tmp/restore/2017-05-17_04585
> 0/geoserver_catalog.zip'.
>   File "manage.py", line 29, in <module>
>   File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
> line 346, in execute
>   File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
>   File "/usr/src/app/geonode/base/management/commands/restore.py", line
> 97, in handle
>     raise ValueError('Could not find GeoServer Backup file [' +
> geoserver_bk_file + ']')
> ValueError: Could not find GeoServer Backup file
> [/tmp/restore/2017-05-17_045850/geoserver_catalog.zip]
> Best regards,
> Enrique
> El 23 may 2017, a las 19:12, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> escribió:
> Except for the latest issue, which should be a warning (I will need to
> double check this), you should not restore the geoserver_catalog.zip but
> the geonode backup file which should be something like
> --backup-file=/tmp/backup/2017-05-23_120201.zip*
> If it does not exists that means that the latest warning prevents you to
> finalize the backup.
> A quick and dirty workaround is to create the folder
> */home/federico/gn_fede/gn_fede/locale'*
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, May 23, 2017 at 7:39 PM, Federico Gianoli <alpacagis at gmail.com>
> wrote:
>> Thanks a lot Alessio and Enrique,
>> I think we are on the right way to solve the issue... but I still have
>> some errors.
>> I really thank you for your precious help.
>> *$ python manage.py backup --backup-dir=/tmp/backup/*
>> *Before proceeding with the Backup, please ensure that:*
>> *You want to proceed? [n]|y: y*
>> *Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
>> '/tmp/backup/2017-05-23_120201/geoserver_catalog.zip'.*
>> *STARTED - 1/9*
>> *COMPLETED - 9/9*
>> *Dumped GeoServer Uploaded Data from
>> *Dumping GeoServer Vectorial Data : swl_asl*
>> *Dumping GeoServer Vectorial Data : c0506121_ccs2012s*
>> *Dumping GeoServer Vectorial Data : popolazione_veneto*
>> *Dumping GeoServer Vectorial Data : swl_asl_map_area*
>> *Dumping GeoServer Vectorial Data : contour_lines*
>> *Dumping GeoServer Vectorial Data : tectonic_structures*
>> *Dumping GeoServer Vectorial Data : gcgw_wells_tayarat*
>> *Dumping GeoServer Vectorial Data : main_groundwater_flow*
>> *Dumping GeoServer Vectorial Data : springs_perennial*
>> *Dumping GeoServer Vectorial Data : springs_perennial_no_data*
>> *Dumping GeoServer Vectorial Data : springs_temporary*
>> *...done!*
>> *Dumping 'people' into 'people.json'.*
>> *Dumping 'account' into 'accounts.json'.*
>> *Dumping 'avatar.avatar' into 'avatars.json'.*
>> *Dumping 'base.backup' into 'backups.json'.*
>> *Dumping 'base.license' into 'licenses.json'.*
>> *Dumping 'base.topiccategory' into 'topiccategories.json'.*
>> *Dumping 'base.region' into 'regions.json'.*
>> *Dumping 'base.resourcebase' into 'resourcebases.json'.*
>> *Dumping 'base.contactrole' into 'contactroles.json'.*
>> *Dumping 'base.link' into 'links.json'.*
>> *Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.*
>> *Dumping 'base.spatialrepresentationtype' into
>> 'spatialrepresentationtypes.json'.*
>> *Dumping 'guardian.userobjectpermission' into 'useropermissions.json'.*
>> *Dumping 'guardian.groupobjectpermission' into 'groupopermissions.json'.*
>> *Dumping 'layers.uploadsession' into 'uploadsessions.json'.*
>> *Dumping 'layers.style' into 'styles.json'.*
>> *Dumping 'layers.layer' into 'layers.json'.*
>> *Dumping 'layers.attribute' into 'attributes.json'.*
>> *Dumping 'layers.layerfile' into 'layerfiles.json'.*
>> *Dumping 'maps.map' into 'maps.json'.*
>> *Dumping 'maps.maplayer' into 'maplayers.json'.*
>> *Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.*
>> *Dumping 'documents.document' into 'documents.json'.*
>> *Dumping 'taggit' into 'tags.json'.*
>> *Saved Media Files from '/var/www/geonode/uploaded'.*
>> *Saved Static Root from '/var/www/geonode/static/'.*
>> *Saved Static Files from '/etc/geonode/media'.*
>> '/usr/local/lib/python2.7/dist-packages/geonode/static'.*
>> *Saved Static Files from '/home/federico/gn_fede/gn_fede/static'.*
>> *Saved Template Files from '/etc/geonode/templates'.*
>> '/usr/local/lib/python2.7/dist-packages/geonode/templates'.*
>> *...done!*
>> *  File
>> *  File
>> 346, in execute*
>> *  File
>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
>> *  File
>> 445, in execute*
>> *  File
>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>> line 243, in handle*
>> *    helpers.copy_tree(locale_files_folder, locale_folder)*
>> *  File
>> '/home/federico/gn_fede/gn_fede/locale'*
>> *The restore issue:*
>> --backup-file=/tmp/backup/2017-05-23_120201/geoserver_catalog.zipBefore
>> proceeding with the Restore, please ensure that: 1. The backend (DB or
>> whatever) is accessible and you have rights 2. The GeoServer is up and
>> running and reachable from this machineWARNING: The restore will overwrite
>> ALL GeoNode data. You want to proceed? [n]|y: yTraceback (most recent call
>> last):  File "manage.py", line 11, in <module>
>> execute_from_command_line(sys.argv)  File
>> 354, in execute_from_command_line    utility.execute()  File
>> 346, in execute    self.fetch_command(subcommand).run_from_argv(self.argv)
>> line 394, in run_from_argv    self.execute(*args, **cmd_options)  File
>> 445, in execute    output = self.handle(*args, **options)  File
>> line 87, in handle    target_folder = helpers.unzip_file(backup_file,
>> restore_folder)  File
>> line 227, in unzip_file    z.extractall(target_folder)  File
>> "/usr/lib/python2.7/zipfile.py", line 1040, in extractall
>> self.extract(zipinfo, path, pwd)  File "/usr/lib/python2.7/zipfile.py",
>> line 1028, in extract    return self._extract_member(member, path, pwd)
>> File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member
>> file(targetpath, "wb") as target:IOError: [Errno 13] Permission denied:
>> u'/tmp/restore/geoserver_catalog/store.dat.1'*
>> *Usuìing SUDO command, the error is different:*
>> $ sudo python manage.py restore --backup-file=/tmp/backup/2017
>> proceed? [n]|y: y
>> Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/]' into
>> '/tmp/restore/geoserver_catalog/geoserver_catalog.zip'.
>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>     utility.execute()
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
>> line 97, in handle
>> [/tmp/restore/geoserver_catalog/geoserver_catalog.zip]
>> *Anyway, using Enrique suggestion, the system doesn't work and I have
>> this error:*
>> Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/]' into
>> '/tmp/backup/2017-05-23_122247/geoserver_catalog.zip'.
>> STARTED - 1/9
>> COMPLETED - 9/9
>>     utility.execute()
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>> line 150, in handle
>>     helpers.copy_tree(gs_data_root, gs_data_folder)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver
>> /data/geonode'
>> 2017-05-23 18:16 GMT+02:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>:
>>> Hi,
>>> I have the same problem that Federico. A few days ago, I made that
>>> change, “datadir = geoserver/data”, and the backup also failed. However,
>>> when i set “datadir” to “geoserver/“ it works, although “geoserver_catalog”
>>> is not included in the backup zip file.
>>> Best regards,
>>> Enrique
>>> El 23 may 2017, a las 16:52, Alessio Fabiani <
>>> Ok, so, the GeoServer backup has been done "COMPLETED - 9/9" but there's
>>> an error on the backup settings.
>>> It looks like it cannot find the GeoServer Data Dir path on the local
>>> server.
>>> Edit this file
>>> geonode/base/management/commands/settings.ini
>>> and be sure to change this "datadir = *geoserver/data*" with the
>>> absolute path to the GEOSERVER_DATA_DIR
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, May 23, 2017 at 5:45 PM, Federico Gianoli <alpacagis at gmail.com>
>>> wrote:
>>>> Hi Alessio,
>>>> This is the result of these commands:
>>>> *Before proceeding with the Backup, please ensure that: 1. The backend
>>>> (DB or whatever) is accessible and you have rights 2. The GeoServer is up
>>>> '/tmp/backup/2017-05-23_103754/geoserver_catalog.zip'.*
>>>> *STARTED - 1/9COMPLETED - 9/9Traceback (most recent call last):  File
>>>> "manage.py", line 11, in <module>    execute_from_command_line(sys.argv)
>>>> line 354, in execute_from_command_line    utility.execute()  File
>>>> line 150, in handle    helpers.copy_tree(gs_data_root, gs_data_folder)
>>>> File
>>>> line 203, in copy_tree    for item in os.listdir(src):OSError: [Errno 2] No
>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'*
>>>> The backup is created but with the error (*OSError: [Errno 2] No such
>>>> file or directory:
>>>> ), and the restore command doesn't work
>>>> --backup-file=/tmp/backup/2017-05-23_103754/geoserver_catalog.zip*
>>>> proceed? [n]|y: y*
>>>> *  File
>>>> *  File
>>>> 346, in execute*
>>>> *  File
>>>> *  File
>>>> 445, in execute*
>>>> *  File
>>>> line 87, in handle*
>>>> *  File
>>>> line 227, in unzip_file*
>>>> *    z.extractall(target_folder)*
>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1040, in extractall*
>>>> *    self.extract(zipinfo, path, pwd)*
>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1028, in extract*
>>>> *    return self._extract_member(member, path, pwd)*
>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member*
>>>> *    file(targetpath, "wb") as target:*
>>>> *IOError: [Errno 13] Permission denied:
>>>> Thanks for your help
>>>> Federico
>>>> 2017-05-23 17:33 GMT+02:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>>> Federico, before doing anything, can you try to do this test?
>>>>> sudo mkdir /tmp/backup
>>>>> sudo chmod -Rf 777 /tmp/backup
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Tue, May 23, 2017 at 5:24 PM, Federico Gianoli <alpacagis at gmail.com
>>>>> > wrote:
>>>>>> Hi Alessio,
>>>>>> thanks for your quick answer,
>>>>>> I have checked, but I have not the files 2 and 3 on my geonode
>>>>>> instance. How is it possible? I have installed geonode via ppa.
>>>>>> I have overwritten all "commands" folder, in order to be sure to have
>>>>>> the latest files, bu it is still not working.
>>>>>> There is another way to do the backup?
>>>>>> In your opinion, if I upgrade my version of geonode (2.6rc) to the
>>>>>> last stable (sudo apt-get upgrade   right?), this issue will be solved?
>>>>>> How dangerous could be for my data?
>>>>>> Thanks a lot
>>>>>> Fede
>>>>>> 2017-05-23 12:38 GMT+02:00 Alessio Fabiani <
>>>>>>> Digging to the source code of both GeoNode management command [1]
>>>>>>> and GeoServer Backup Plugin [2] and [3], seems like that GeoServer can't
>>>>>>> access the "${target_folder}/geoserver_catalog.zip"
>>>>>>> The ${target_folder} should be composed by the join of ${backup_dir}
>>>>>>> and ${dir_time_suffix}, something like ${backup_dir}/<time_stamp>
>>>>>>> where ${backup_dir} is the parameter provided when running the
>>>>>>> backup command from GeoNode.
>>>>>>> Now, the latest GeoNode code [4] tries to set chmod(777) to this
>>>>>>> temporary folder, which will be deleted at the end, in order to allow to
>>>>>>> GeoServer to write the file.
>>>>>>> That means that most probably the user running GeoNode must have
>>>>>>> full rights on the ${backup_dir} folder.
>>>>>>> Can you maybe try to double check this?
>>>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>> ase/management/commands/backup.py#L92
>>>>>>> [2] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>> mmunity/backup-restore/rest/src/main/java/org/geoserver/back
>>>>>>> uprestore/rest/BackupResource.java#L155
>>>>>>> [3] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>> mmunity/backup-restore/core/src/main/java/org/geoserver/back
>>>>>>> uprestore/Backup.java#L328
>>>>>>> [4] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>> ase/management/commands/backup.py#L86
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Tue, May 23, 2017 at 12:23 PM, Federico Gianoli <
>>>>>>> alpacagis at gmail.com> wrote:
>>>>>>>> Hi Alessio,
>>>>>>>> I have checked the Geoserver Log, and here you can find the
>>>>>>>> complete geoserver log: https://pastebin.com/c9JeR1NU
>>>>>>>> The error that I have noted on the log is this one:
>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - Unable to perform
>>>>>>>> backup: :Could not create file.*
>>>>>>>> *2017-05-23 04:49:10,598 DEBUG [geoserver.filters] - Compressing
>>>>>>>> output for mimetype: text/plain*
>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - *
>>>>>>>> *org.geoserver.rest.RestletException:
>>>>>>>> java.lang.IllegalStateException: Could not create file.*
>>>>>>>> * at org.geoserver.backuprestore.re
>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.runBackup(BackupResource.java:172)*
>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.handlePost(BackupResource.java:108)*
>>>>>>>> The rights of  /usr/share/geoserver/data are these:
>>>>>>>> drwxr-xr-x  21 tomcat7 tomcat7      4096 May 23 04:49 data
>>>>>>>> I have also changed the folder rights adding user: tomcat7 and
>>>>>>>> user:user, but without any result.
>>>>>>>> Thanks a lot for your help and your patience
>>>>>>>> Federico
>>>>>>>> 2017-05-22 16:49 GMT+02:00 Alessio Fabiani <
>>>>>>>>> It is possible that GeoServer cannot write to the target folder.
>>>>>>>>> Take a look at the GeoServer logs. Also try to rise up the log level if you
>>>>>>>>> don't find anything useful.
>>>>>>>>> This can be done from the GeoServer admin gui.
>>>>>>>>> Best Regards,
>>>>>>>>> Alessio Fabiani.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Mon, May 22, 2017 at 4:47 PM, Alessio Fabiani <
>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> which version of GeoServer are you using?
>>>>>>>>>> Best Regards,
>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Italy
>>>>>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> On Fri, May 19, 2017 at 1:08 PM, Federico Gianoli <
>>>>>>>>>>> Thanks a lot Alessio,
>>>>>>>>>>> I have changed the files according to your suggestions,
>>>>>>>>>>> but now I have this error:
>>>>>>>>>>> *$ sudo python manage.py backup --backup-dir=backup/*
>>>>>>>>>>> rights*
>>>>>>>>>>> machine*
>>>>>>>>>>> <http://212.237.232.12/geoserver/>]' into 'backup/2017-05-19_050730
>>>>>>>>>>> <050%20730>/geoserver_catalog.zip'.*
>>>>>>>>>>> *  File
>>>>>>>>>>> *  File
>>>>>>>>>>> 346, in execute*
>>>>>>>>>>> *  File
>>>>>>>>>>> *  File
>>>>>>>>>>> 445, in execute*
>>>>>>>>>>> *  File
>>>>>>>>>>> line 101, in handle*
>>>>>>>>>>> *    gs_backup = r.json()*
>>>>>>>>>>> *  File "/usr/lib/python2.7/dist-packages/requests/models.py",
>>>>>>>>>>> line 808, in json*
>>>>>>>>>>> *    return complexjson.loads(self.text, **kwargs)*
>>>>>>>>>>> *  File "/usr/lib/python2.7/json/__init__.py", line 339, in
>>>>>>>>>>> loads*
>>>>>>>>>>> *    return _default_decoder.decode(s)*
>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 364, in
>>>>>>>>>>> decode*
>>>>>>>>>>> *    obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 382, in
>>>>>>>>>>> raw_decode*
>>>>>>>>>>> *    raise ValueError("No JSON object could be decoded")*
>>>>>>>>>>> *ValueError: No JSON object could be decoded*
>>>>>>>>>>> *Thanks a lot for your help*
>>>>>>>>>>> *Fede*
>>>>>>>>>>> 2017-05-05 16:41 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>> PR here
>>>>>>>>>>>> https://github.com/GeoNode/geonode/pull/3031
>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Italy
>>>>>>>>>>>> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <
>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>> currently the backup and restore utility should be aligned
>>>>>>>>>>>>> with latest updates I guess. There are also several issues / improvements
>>>>>>>>>>>>> we are working on to improve this tool.
>>>>>>>>>>>>> We will find some spare time soon to devote to those tasks. We
>>>>>>>>>>>>> will send updates as soon as possible.
>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>>>>>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>> Hi Federico,
>>>>>>>>>>>>>> there seems to be an issue in the commands, simplejson is not
>>>>>>>>>>>>>> available anymore, json has to be used. we should fix it.
>>>>>>>>>>>>>> @afabiani, is that correct?
>>>>>>>>>>>>>> https://github.com/GeoNode/geonode/blob/2.6.x/geonode/base/m
>>>>>>>>>>>>>> anagement/commands/restore.py#L28
>>>>>>>>>>>>>> anagement/commands/backup.py#L26
>>>>>>>>>>>>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <
>>>>>>>>>>>>>> alpacagis at gmail.com>:
>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>> I would like to create a backup of my geonode project and I
>>>>>>>>>>>>>>> am using this guide: http://docs.geonode.org
>>>>>>>>>>>>>>> /en/master/tutorials/admin/backup_restore/
>>>>>>>>>>>>>>> From my django admin page (Base => backups) I tried to do a
>>>>>>>>>>>>>>> backup, but, when I run the backup, on a fully writable folder (777), there
>>>>>>>>>>>>>>> is this server error:
>>>>>>>>>>>>>>> Internal Server Error
>>>>>>>>>>>>>>> The server encountered an internal error or misconfiguration
>>>>>>>>>>>>>>> and was unable to complete your request.
>>>>>>>>>>>>>>> I have double checked the settings.ini file, and I have
>>>>>>>>>>>>>>> noted that the configuration file is not yet update for the 2.6 version, it
>>>>>>>>>>>>>>> has these lines:
>>>>>>>>>>>>>>> #Migrate from GN 2.4 to GN 2.4
>>>>>>>>>>>>>>> migrations = base.resourcebase,layers.layer
>>>>>>>>>>>>>>> ,layers.attribute,maps.map,maps.maplayer
>>>>>>>>>>>>>>> manglers   = gn24_to_24.ResourceBaseMangler
>>>>>>>>>>>>>>> ,gn24_to_24.LayerMangler,gn24_to_24.LayerAttributesMangler,g
>>>>>>>>>>>>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>>>>>>>>>>>>> Is it correct? Have I to change these lines accordingly to
>>>>>>>>>>>>>>> the 2.6 version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>>>>>>>>>>>>> When I try to run the backup from command line there is the
>>>>>>>>>>>>>>> following error about the file backup.py
>>>>>>>>>>>>>>> How can I solved this issue?
>>>>>>>>>>>>>>> Tanks a lot
>>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170523/5b5f32f1/attachment-0001.html>
More information about the geonode-users mailing list
