[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Enrique Cerrillo Cuenca cerrillo at uevora.pt
Wed May 24 02:41:57 PDT 2017
I forgot to mention that the settings.ini file is as follows:
[geoserver]
datadir = /geoserver_data/
dumpvectordata = yes
dumprasterdata = yes
If I set "datadir" to /geoserver_data/data/ I got errors.
2017-05-24 10:29 GMT+01:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>:
> Thanks Alessio for all your help. I expect to help you finding the bugs.
> Things are not working here. I do get the "COMPLETE[9/9]” message, but I
> get an error when trying to restore the backup file.
> Best regards,
> Enrique
> manage.py backup --backup-dir=/var/opt/geonode/backups
> System check identified some issues:
> WARNINGS:
> *base.ResourceBase.tkeywords: (fields.W340) null has no effect on
> ManyToManyField.*
> Before proceeding with the Backup, please ensure that:
>  1. The backend (DB or whatever) is accessible and you have rights
>  2. The GeoServer is up and running and reachable from this machine
> Dumping 'GeoServer Catalog [http:----]' into '//var/opt/geonode/backups/201
> 7-05-24_041950/geoserver_catalog.zip'.
> STARTED - 1/9
> COMPLETED - 9/9
> Dumped GeoServer Uploaded Data from '/geoserver_data/data/geonode'.
> Deactivating GeoNode Signals...
> ...done!
> Dumping 'people' into 'people.json'.
> Dumping 'account' into 'accounts.json'.
> Dumping 'avatar.avatar' into 'avatars.json'.
> Dumping 'base.backup' into 'backups.json'.
> Dumping 'base.license' into 'licenses.json'.
> Dumping 'base.topiccategory' into 'topiccategories.json'.
> Dumping 'base.region' into 'regions.json'.
> Dumping 'base.resourcebase' into 'resourcebases.json'.
> Dumping 'base.contactrole' into 'contactroles.json'.
> Dumping 'base.link' into 'links.json'.
> Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.
> Dumping 'base.spatialrepresentationtype' into
> 'spatialrepresentationtypes.json'.
> Dumping 'guardian.userobjectpermission' into 'useropermissions.json'.
> Dumping 'guardian.groupobjectpermission' into 'groupopermissions.json'.
> Dumping 'layers.uploadsession' into 'uploadsessions.json'.
> Dumping 'layers.style' into 'styles.json'.
> Dumping 'layers.layer' into 'layers.json'.
> Dumping 'layers.attribute' into 'attributes.json'.
> Dumping 'layers.layerfile' into 'layerfiles.json'.
> Dumping 'maps.map' into 'maps.json'.
> Dumping 'maps.maplayer' into 'maplayers.json'.
> Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.
> Dumping 'documents.document' into 'documents.json'.
> Dumping 'taggit' into 'tags.json'.
> Saved Media Files from '/var/opt/geonode/backups/geonode/uploaded'.
> Saved Static Root from '/var/opt/geonode/backups/static_root'.
> Saved Static Files from '/var/opt/geonode/backups/geonode/static'.
> Saved Locale Files from '/var/opt/geonode/backups/geonode/locale'.
> Backup Finished. Archive generated.
> Reactivating GeoNode Signals...
> ...done!
> /var/opt/geonode/backups/2017-05-24_041950.zip
> manage.py restore --backup-file=/var/opt/geonode
> WARNINGS:
> ManyToManyField.*
> Before proceeding with the Restore, please ensure that:
> WARNING: The restore will overwrite ALL GeoNode data. You want to proceed?
> [n]|y: y
> Restoring 'GeoServer Catalog [http://------]' into
> '/tmp/restore/2017-05-24_041950/geoserver_catalog.zip'.
> Traceback (most recent call last):
>   File "manage.py", line 29, in <module>
>     execute_from_command_line(sys.argv)
>   File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
> line 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
> line 445, in execute
>     output = self.handle(*args, **options)
>   File "/usr/src/app/geonode/base/management/commands/restore.py", line
> 97, in handle
>     raise ValueError('Could not find GeoServer Backup file [' +
> geoserver_bk_file + ']')
> ValueError: Could not find GeoServer Backup file
> [/tmp/restore/2017-05-24_041950/geoserver_catalog.zip]
> El 24 may 2017, a las 8:43, Alessio Fabiani <alessio.fabiani at geo-solutions
> .it> escribió:
> Those error are due to settings issues I guess.
> There are open issues to let backup/restore command more resilient and
> more stable. We need to find some time to improve it soon.
> @Enrique, your error is caused by GeoServer backup. Basically for some
> reason it is not able to complete the backup of the catalog. Until you see
> a message "COMPLETE[9/9]" the backup of GeoServer is not fully done. You
> should take a look at the GeoServer logs in order to see why it is failing.
> Usually this depends on some wrong configuration of datastores.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, May 23, 2017 at 10:32 PM, Federico Gianoli <alpacagis at gmail.com>
> wrote:
>> Finally it works!
>> Thanks Alessio for your help. Tomorrow morning I'll try to migrate data.
>> Creating manually the folder */home/federico/gn_fede/gn_fede/locale* it
>> works.
>> but using restore command without Sudo I have this error
>> *$ python manage.py restore
>> --backup-file=/tmp/backup/2017-05-23_132655.zip*
>> *Before proceeding with the Restore, please ensure that:*
>> * 1. The backend (DB or whatever) is accessible and you have rights*
>> * 2. The GeoServer is up and running and reachable from this machine*
>> *WARNING: The restore will overwrite ALL GeoNode data. You want to
>> proceed? [n]|y: y*
>> *Traceback (most recent call last):*
>> *  File "manage.py", line 11, in <module>*
>> *    execute_from_command_line(sys.argv)*
>> *  File
>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>> 354, in execute_from_command_line*
>> *    utility.execute()*
>> *  File
>> 346, in execute*
>> *    self.fetch_command(subcommand).run_from_argv(self.argv)*
>> *  File
>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
>> 394, in run_from_argv*
>> *    self.execute(*args, **cmd_options)*
>> *  File
>> 445, in execute*
>> *    output = self.handle(*args, **options)*
>> *  File
>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
>> line 87, in handle*
>> *    target_folder = helpers.unzip_file(backup_file, restore_folder)*
>> *  File
>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
>> line 224, in unzip_file*
>> *    os.makedirs(target_folder)*
>> *  File "/usr/lib/python2.7/os.py", line 157, in makedirs*
>> *    mkdir(name, mode)*
>> *OSError: [Errno 13] Permission denied: '/tmp/restore/2017-05-23_132655'*
>> *with sudo command I have the error later:*
>> *$ sudo python manage.py restore
>> *[sudo] password for federico:*
>> proceed? [n]|y: y*
>> *Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/
>> <http://212.237.232.12/geoserver/>]' into
>> '/tmp/restore/2017-05-23_132655/geoserver_catalog.zip'.*
>> *STARTED - 3/9*
>> *FAILED - 8/9*
>> *Cleaned out old GeoServer Data Dir:
>> /usr/share/geoserver/data/data/geonode*
>> *GeoServer Uploaded Data Restored to
>> '/usr/share/geoserver/data/data/geonode'.*
>> *Cleaned out old GeoServer GWC Layers Config:
>> /usr/share/geoserver/data/gwc-layers*
>> *Restoring GeoServer Vectorial Data : popolazione_veneto*
>> *Restoring GeoServer Vectorial Data : gcgw_wells_tayarat*
>> *Restoring GeoServer Vectorial Data : main_groundwater_flow*
>> *Restoring GeoServer Vectorial Data : swl_asl*
>> *Restoring GeoServer Vectorial Data : contour_lines*
>> *Restoring GeoServer Vectorial Data : swl_asl_map_area*
>> *Restoring GeoServer Vectorial Data : springs_perennial_no_data*
>> *Restoring GeoServer Vectorial Data : c0506121_ccs2012s*
>> *Restoring GeoServer Vectorial Data : tectonic_structures*
>> *Restoring GeoServer Vectorial Data : springs_perennial*
>> *Restoring GeoServer Vectorial Data : springs_temporary*
>> *Operations to perform:*
>> *  Synchronize unmigrated apps: tasks, modeltranslation,
>> django_extensions, polymorphic, treebeard, gis,
>> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
>> geoserver, storages, mptt, friendlytagloader, staticfiles, geoexplorer,
>> gn_fede, sitemaps, proxy, pinax_theme_bootstrap, pagination,
>> autocomplete_light, messages, leaflet, api, avatar, social, security*
>> *  Apply all migrations: dialogos, people, tastypie, agon_ratings,
>> documents, actstream, sites, maps, contenttypes, announcements,
>> user_messages, layers, sessions, guardian, auth, base, groups, services,
>> oauth2_provider, account, admin, djcelery, upload, taggit*
>> *Synchronizing apps without migrations:*
>> *  Creating tables...*
>> *    Running deferred SQL...*
>> *  Installing custom SQL...*
>> *Running migrations:*
>> *  No migrations to apply.*
>> *  Your models have changes that are not yet reflected in a migration,
>> and so won't be applied.*
>> *  Run 'manage.py makemigrations' to make new migrations, and then re-run
>> 'manage.py migrate' to apply them.*
>> *Deactivating GeoNode Signals...*
>> *...done!*
>> *Deserializing /tmp/restore/2017-05-23_132655/people.json*
>> *Installed 2 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/accounts.json*
>> *Installed 3 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/avatars.json*
>> *Installed 0 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/backups.json*
>> *Deserializing /tmp/restore/2017-05-23_132655/licenses.json*
>> *Installed 7 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/topiccategories.json*
>> *Installed 20 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/regions.json*
>> *Installed 259 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/resourcebases.json*
>> *Installed 13 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/contactroles.json*
>> *Installed 26 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/links.json*
>> *Installed 296 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/restrictioncodetypes.json*
>> *Installed 8 object(s) from 1 fixture(s)*
>> *Deserializing
>> /tmp/restore/2017-05-23_132655/spatialrepresentationtypes.json*
>> *Installed 6 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/useropermissions.json*
>> *Installed 141 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/groupopermissions.json*
>> *Deserializing /tmp/restore/2017-05-23_132655/uploadsessions.json*
>> *Installed 18 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/styles.json*
>> *Installed 12 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/layers.json*
>> *Deserializing /tmp/restore/2017-05-23_132655/attributes.json*
>> *Installed 122 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/layerfiles.json*
>> *Installed 104 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/maps.json*
>> *Deserializing /tmp/restore/2017-05-23_132655/maplayers.json*
>> *Deserializing /tmp/restore/2017-05-23_132655/mapsnapshots.json*
>> *Deserializing /tmp/restore/2017-05-23_132655/documents.json*
>> *Installed 1 object(s) from 1 fixture(s)*
>> *Deserializing /tmp/restore/2017-05-23_132655/tags.json*
>> *Media Files Restored into '/var/www/geonode/uploaded'.*
>> *Static Root Restored into '/var/www/geonode/static/'.*
>> *Reactivating GeoNode Signals...*
>> *...done!*
>> *  File
>> *  File
>> 346, in execute*
>> *  File
>> *  File
>> 445, in execute*
>> *  File
>> line 290, in handle*
>> *    static_files_folder)*
>> *  File
>> line 203, in copy_tree*
>> *    for item in os.listdir(src):*
>> *OSError: [Errno 2] No such file or directory:
>> '/tmp/restore/2017-05-23_132655/static_dirs/media'*
>> *Creating manually the folder:
>>  /tmp/restore/2017-05-23_132655/static_dirs/media everythings works
>> correctly.*
>> *Tomorrow morning I'll try again, but I hope to have solved the issue,
>> thanks again Alessio for your help.*
>> *Good night*
>> *Federico*
>> 2017-05-23 21:04 GMT+02:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>:
>>> I tried to do that yesterday. The file do exist in the path and it was
>>> allegedly created with no errors. However I’m getting this error:
>>> python manage.py restore --backup-file=backup/2017-05-17_045850
>>> <045%20850>.zip
>>> WARNINGS:
>>> ManyToManyField.*
>>> proceed? [n]|y: y
>>> Restoring 'GeoServer Catalog [http://atlas.cidehusdigital.u
>>> evora.pt/geoserver/]' into '/tmp/restore/2017-05-17_04585
>>>     utility.execute()
>>> 97, in handle
>>> [/tmp/restore/2017-05-17_045850/geoserver_catalog.zip]
>>> Best regards,
>>> Enrique
>>> El 23 may 2017, a las 19:12, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> escribió:
>>> Except for the latest issue, which should be a warning (I will need to
>>> double check this), you should not restore the geoserver_catalog.zip but
>>> the geonode backup file which should be something like
>>> --backup-file=/tmp/backup/2017-05-23_120201.zip*
>>> If it does not exists that means that the latest warning prevents you to
>>> finalize the backup.
>>> A quick and dirty workaround is to create the folder
>>> */home/federico/gn_fede/gn_fede/locale'*
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, May 23, 2017 at 7:39 PM, Federico Gianoli <alpacagis at gmail.com>
>>> wrote:
>>>> Thanks a lot Alessio and Enrique,
>>>> I think we are on the right way to solve the issue... but I still have
>>>> some errors.
>>>> I really thank you for your precious help.
>>>> *$ python manage.py backup --backup-dir=/tmp/backup/*
>>>> *Before proceeding with the Backup, please ensure that:*
>>>> *You want to proceed? [n]|y: y*
>>>> *Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
>>>> '/tmp/backup/2017-05-23_120201/geoserver_catalog.zip'.*
>>>> *STARTED - 1/9*
>>>> *COMPLETED - 9/9*
>>>> *Dumped GeoServer Uploaded Data from
>>>> *Dumping GeoServer Vectorial Data : swl_asl*
>>>> *Dumping GeoServer Vectorial Data : c0506121_ccs2012s*
>>>> *Dumping GeoServer Vectorial Data : popolazione_veneto*
>>>> *Dumping GeoServer Vectorial Data : swl_asl_map_area*
>>>> *Dumping GeoServer Vectorial Data : contour_lines*
>>>> *Dumping GeoServer Vectorial Data : tectonic_structures*
>>>> *Dumping GeoServer Vectorial Data : gcgw_wells_tayarat*
>>>> *Dumping GeoServer Vectorial Data : main_groundwater_flow*
>>>> *Dumping GeoServer Vectorial Data : springs_perennial*
>>>> *Dumping GeoServer Vectorial Data : springs_perennial_no_data*
>>>> *Dumping GeoServer Vectorial Data : springs_temporary*
>>>> *...done!*
>>>> *Dumping 'people' into 'people.json'.*
>>>> *Dumping 'account' into 'accounts.json'.*
>>>> *Dumping 'avatar.avatar' into 'avatars.json'.*
>>>> *Dumping 'base.backup' into 'backups.json'.*
>>>> *Dumping 'base.license' into 'licenses.json'.*
>>>> *Dumping 'base.topiccategory' into 'topiccategories.json'.*
>>>> *Dumping 'base.region' into 'regions.json'.*
>>>> *Dumping 'base.resourcebase' into 'resourcebases.json'.*
>>>> *Dumping 'base.contactrole' into 'contactroles.json'.*
>>>> *Dumping 'base.link' into 'links.json'.*
>>>> *Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.*
>>>> *Dumping 'base.spatialrepresentationtype' into
>>>> 'spatialrepresentationtypes.json'.*
>>>> *Dumping 'guardian.userobjectpermission' into 'useropermissions.json'.*
>>>> *Dumping 'guardian.groupobjectpermission' into
>>>> 'groupopermissions.json'.*
>>>> *Dumping 'layers.uploadsession' into 'uploadsessions.json'.*
>>>> *Dumping 'layers.style' into 'styles.json'.*
>>>> *Dumping 'layers.layer' into 'layers.json'.*
>>>> *Dumping 'layers.attribute' into 'attributes.json'.*
>>>> *Dumping 'layers.layerfile' into 'layerfiles.json'.*
>>>> *Dumping 'maps.map' into 'maps.json'.*
>>>> *Dumping 'maps.maplayer' into 'maplayers.json'.*
>>>> *Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.*
>>>> *Dumping 'documents.document' into 'documents.json'.*
>>>> *Dumping 'taggit' into 'tags.json'.*
>>>> *Saved Media Files from '/var/www/geonode/uploaded'.*
>>>> *Saved Static Root from '/var/www/geonode/static/'.*
>>>> *Saved Static Files from '/etc/geonode/media'.*
>>>> '/usr/local/lib/python2.7/dist-packages/geonode/static'.*
>>>> *Saved Static Files from '/home/federico/gn_fede/gn_fede/static'.*
>>>> *Saved Template Files from '/etc/geonode/templates'.*
>>>> '/usr/local/lib/python2.7/dist-packages/geonode/templates'.*
>>>> *...done!*
>>>> *  File
>>>> *  File
>>>> 346, in execute*
>>>> *  File
>>>> *  File
>>>> 445, in execute*
>>>> *  File
>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>>>> line 243, in handle*
>>>> *    helpers.copy_tree(locale_files_folder, locale_folder)*
>>>> *  File
>>>> '/home/federico/gn_fede/gn_fede/locale'*
>>>> *The restore issue:*
>>>> --backup-file=/tmp/backup/2017-05-23_120201/geoserver_catalog.zipBefore
>>>> proceeding with the Restore, please ensure that: 1. The backend (DB or
>>>> whatever) is accessible and you have rights 2. The GeoServer is up and
>>>> running and reachable from this machineWARNING: The restore will overwrite
>>>> ALL GeoNode data. You want to proceed? [n]|y: yTraceback (most recent call
>>>> last):  File "manage.py", line 11, in <module>
>>>> execute_from_command_line(sys.argv)  File
>>>> 354, in execute_from_command_line    utility.execute()  File
>>>> 346, in execute    self.fetch_command(subcommand).run_from_argv(self.argv)
>>>> File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>> line 394, in run_from_argv    self.execute(*args, **cmd_options)  File
>>>> 445, in execute    output = self.handle(*args, **options)  File
>>>> line 87, in handle    target_folder = helpers.unzip_file(backup_file,
>>>> restore_folder)  File
>>>> line 227, in unzip_file    z.extractall(target_folder)  File
>>>> "/usr/lib/python2.7/zipfile.py", line 1040, in extractall
>>>> self.extract(zipinfo, path, pwd)  File "/usr/lib/python2.7/zipfile.py",
>>>> line 1028, in extract    return self._extract_member(member, path, pwd)
>>>> File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member
>>>> file(targetpath, "wb") as target:IOError: [Errno 13] Permission denied:
>>>> u'/tmp/restore/geoserver_catalog/store.dat.1'*
>>>> *Usuìing SUDO command, the error is different:*
>>>> $ sudo python manage.py restore --backup-file=/tmp/backup/2017
>>>> proceed? [n]|y: y
>>>> Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/]' into
>>>> '/tmp/restore/geoserver_catalog/geoserver_catalog.zip'.
>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>>     utility.execute()
>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
>>>> line 97, in handle
>>>> [/tmp/restore/geoserver_catalog/geoserver_catalog.zip]
>>>> *Anyway, using Enrique suggestion, the system doesn't work and I have
>>>> this error:*
>>>> Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/]' into
>>>> '/tmp/backup/2017-05-23_122247/geoserver_catalog.zip'.
>>>> STARTED - 1/9
>>>> COMPLETED - 9/9
>>>>     utility.execute()
>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>>>> line 150, in handle
>>>>     helpers.copy_tree(gs_data_root, gs_data_folder)
>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver
>>>> /data/geonode'
>>>> 2017-05-23 18:16 GMT+02:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>
>>>>> Hi,
>>>>> I have the same problem that Federico. A few days ago, I made that
>>>>> change, “datadir = geoserver/data”, and the backup also failed. However,
>>>>> when i set “datadir” to “geoserver/“ it works, although “geoserver_catalog”
>>>>> is not included in the backup zip file.
>>>>> Best regards,
>>>>> Enrique
>>>>> El 23 may 2017, a las 16:52, Alessio Fabiani <
>>>>> Ok, so, the GeoServer backup has been done "COMPLETED - 9/9" but
>>>>> there's an error on the backup settings.
>>>>> It looks like it cannot find the GeoServer Data Dir path on the local
>>>>> server.
>>>>> Edit this file
>>>>> geonode/base/management/commands/settings.ini
>>>>> and be sure to change this "datadir = *geoserver/data*" with the
>>>>> absolute path to the GEOSERVER_DATA_DIR
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Tue, May 23, 2017 at 5:45 PM, Federico Gianoli <alpacagis at gmail.com
>>>>> > wrote:
>>>>>> Hi Alessio,
>>>>>> This is the result of these commands:
>>>>>> *Before proceeding with the Backup, please ensure that: 1. The
>>>>>> backend (DB or whatever) is accessible and you have rights 2. The GeoServer
>>>>>> '/tmp/backup/2017-05-23_103754/geoserver_catalog.zip'.*
>>>>>> *STARTED - 1/9COMPLETED - 9/9Traceback (most recent call last):  File
>>>>>> "manage.py", line 11, in <module>    execute_from_command_line(sys.argv)
>>>>>> line 354, in execute_from_command_line    utility.execute()  File
>>>>>> line 150, in handle    helpers.copy_tree(gs_data_root, gs_data_folder)
>>>>>> File
>>>>>> line 203, in copy_tree    for item in os.listdir(src):OSError: [Errno 2] No
>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'*
>>>>>> The backup is created but with the error (*OSError: [Errno 2] No
>>>>>> ), and the restore command doesn't work
>>>>>> --backup-file=/tmp/backup/2017-05-23_103754/geoserver_catalog.zip*
>>>>>> proceed? [n]|y: y*
>>>>>> *  File
>>>>>> *  File
>>>>>> 346, in execute*
>>>>>> *  File
>>>>>> *  File
>>>>>> 445, in execute*
>>>>>> *  File
>>>>>> line 87, in handle*
>>>>>> *  File
>>>>>> line 227, in unzip_file*
>>>>>> *    z.extractall(target_folder)*
>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1040, in extractall*
>>>>>> *    self.extract(zipinfo, path, pwd)*
>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1028, in extract*
>>>>>> *    return self._extract_member(member, path, pwd)*
>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1083, in
>>>>>> _extract_member*
>>>>>> *    file(targetpath, "wb") as target:*
>>>>>> *IOError: [Errno 13] Permission denied:
>>>>>> Thanks for your help
>>>>>> Federico
>>>>>> 2017-05-23 17:33 GMT+02:00 Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>> Federico, before doing anything, can you try to do this test?
>>>>>>> sudo mkdir /tmp/backup
>>>>>>> sudo chmod -Rf 777 /tmp/backup
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Tue, May 23, 2017 at 5:24 PM, Federico Gianoli <
>>>>>>> alpacagis at gmail.com> wrote:
>>>>>>>> Hi Alessio,
>>>>>>>> thanks for your quick answer,
>>>>>>>> I have checked, but I have not the files 2 and 3 on my geonode
>>>>>>>> instance. How is it possible? I have installed geonode via ppa.
>>>>>>>> I have overwritten all "commands" folder, in order to be sure to
>>>>>>>> have the latest files, bu it is still not working.
>>>>>>>> There is another way to do the backup?
>>>>>>>> In your opinion, if I upgrade my version of geonode (2.6rc) to the
>>>>>>>> last stable (sudo apt-get upgrade   right?), this issue will be solved?
>>>>>>>> How dangerous could be for my data?
>>>>>>>> Thanks a lot
>>>>>>>> Fede
>>>>>>>> 2017-05-23 12:38 GMT+02:00 Alessio Fabiani <
>>>>>>>>> Digging to the source code of both GeoNode management command [1]
>>>>>>>>> and GeoServer Backup Plugin [2] and [3], seems like that GeoServer can't
>>>>>>>>> access the "${target_folder}/geoserver_catalog.zip"
>>>>>>>>> The ${target_folder} should be composed by the join of ${backup_dir}
>>>>>>>>> and ${dir_time_suffix}, something like ${backup_dir}/<time_stamp>
>>>>>>>>> where ${backup_dir} is the parameter provided when running the
>>>>>>>>> backup command from GeoNode.
>>>>>>>>> Now, the latest GeoNode code [4] tries to set chmod(777) to this
>>>>>>>>> temporary folder, which will be deleted at the end, in order to allow to
>>>>>>>>> GeoServer to write the file.
>>>>>>>>> That means that most probably the user running GeoNode must have
>>>>>>>>> full rights on the ${backup_dir} folder.
>>>>>>>>> Can you maybe try to double check this?
>>>>>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>>>> ase/management/commands/backup.py#L92
>>>>>>>>> [2] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>>>> mmunity/backup-restore/rest/src/main/java/org/geoserver/back
>>>>>>>>> uprestore/rest/BackupResource.java#L155
>>>>>>>>> [3] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>>>> mmunity/backup-restore/core/src/main/java/org/geoserver/back
>>>>>>>>> uprestore/Backup.java#L328
>>>>>>>>> [4] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>>>> ase/management/commands/backup.py#L86
>>>>>>>>> Best Regards,
>>>>>>>>> Alessio Fabiani.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Tue, May 23, 2017 at 12:23 PM, Federico Gianoli <
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> I have checked the Geoserver Log, and here you can find the
>>>>>>>>>> complete geoserver log: https://pastebin.com/c9JeR1NU
>>>>>>>>>> The error that I have noted on the log is this one:
>>>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - Unable to
>>>>>>>>>> perform backup: :Could not create file.*
>>>>>>>>>> *2017-05-23 04:49:10,598 DEBUG [geoserver.filters] - Compressing
>>>>>>>>>> output for mimetype: text/plain*
>>>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - *
>>>>>>>>>> *org.geoserver.rest.RestletException:
>>>>>>>>>> java.lang.IllegalStateException: Could not create file.*
>>>>>>>>>> * at org.geoserver.backuprestore.re
>>>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.runBackup(BackupResource.java:172)*
>>>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.handlePost(BackupResource.java:108)*
>>>>>>>>>> The rights of  /usr/share/geoserver/data are these:
>>>>>>>>>> drwxr-xr-x  21 tomcat7 tomcat7      4096 May 23 04:49 data
>>>>>>>>>> I have also changed the folder rights adding user: tomcat7 and
>>>>>>>>>> user:user, but without any result.
>>>>>>>>>> Thanks a lot for your help and your patience
>>>>>>>>>> Federico
>>>>>>>>>> 2017-05-22 16:49 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>> It is possible that GeoServer cannot write to the target folder.
>>>>>>>>>>> Take a look at the GeoServer logs. Also try to rise up the log level if you
>>>>>>>>>>> don't find anything useful.
>>>>>>>>>>> This can be done from the GeoServer admin gui.
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Italy
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> On Mon, May 22, 2017 at 4:47 PM, Alessio Fabiani <
>>>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> which version of GeoServer are you using?
>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Italy
>>>>>>>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>>>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>>>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>>>>>>>> On Fri, May 19, 2017 at 1:08 PM, Federico Gianoli <
>>>>>>>>>>>>> Thanks a lot Alessio,
>>>>>>>>>>>>> I have changed the files according to your suggestions,
>>>>>>>>>>>>> but now I have this error:
>>>>>>>>>>>>> *$ sudo python manage.py backup --backup-dir=backup/*
>>>>>>>>>>>>> rights*
>>>>>>>>>>>>> machine*
>>>>>>>>>>>>> <http://212.237.232.12/geoserver/>]' into 'backup/2017-05-19_050730
>>>>>>>>>>>>> <050%20730>/geoserver_catalog.zip'.*
>>>>>>>>>>>>> *  File
>>>>>>>>>>>>> *  File
>>>>>>>>>>>>> 346, in execute*
>>>>>>>>>>>>> *  File
>>>>>>>>>>>>> *  File
>>>>>>>>>>>>> 445, in execute*
>>>>>>>>>>>>> *  File
>>>>>>>>>>>>> line 101, in handle*
>>>>>>>>>>>>> *    gs_backup = r.json()*
>>>>>>>>>>>>> *  File "/usr/lib/python2.7/dist-packages/requests/models.py",
>>>>>>>>>>>>> line 808, in json*
>>>>>>>>>>>>> *    return complexjson.loads(self.text, **kwargs)*
>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/__init__.py", line 339, in
>>>>>>>>>>>>> loads*
>>>>>>>>>>>>> *    return _default_decoder.decode(s)*
>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 364, in
>>>>>>>>>>>>> decode*
>>>>>>>>>>>>> *    obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 382, in
>>>>>>>>>>>>> raw_decode*
>>>>>>>>>>>>> *    raise ValueError("No JSON object could be decoded")*
>>>>>>>>>>>>> *ValueError: No JSON object could be decoded*
>>>>>>>>>>>>> *Thanks a lot for your help*
>>>>>>>>>>>>> *Fede*
>>>>>>>>>>>>> 2017-05-05 16:41 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>>> PR here
>>>>>>>>>>>>>> https://github.com/GeoNode/geonode/pull/3031
>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>>> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <
>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>> currently the backup and restore utility should be aligned
>>>>>>>>>>>>>>> with latest updates I guess. There are also several issues / improvements
>>>>>>>>>>>>>>> we are working on to improve this tool.
>>>>>>>>>>>>>>> We will find some spare time soon to devote to those tasks.
>>>>>>>>>>>>>>> We will send updates as soon as possible.
>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>>>>>>>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>> Hi Federico,
>>>>>>>>>>>>>>>> there seems to be an issue in the commands, simplejson is
>>>>>>>>>>>>>>>> not available anymore, json has to be used. we should fix it.
>>>>>>>>>>>>>>>> @afabiani, is that correct?
>>>>>>>>>>>>>>>> node/blob/2.6.x/geonode/base/m
>>>>>>>>>>>>>>>> anagement/commands/restore.py#L28
>>>>>>>>>>>>>>>> anagement/commands/backup.py#L26
>>>>>>>>>>>>>>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <
>>>>>>>>>>>>>>>> alpacagis at gmail.com>:
>>>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>>>> I would like to create a backup of my geonode project and
>>>>>>>>>>>>>>>>> I am using this guide: http://docs.geonode.org
>>>>>>>>>>>>>>>>> /en/master/tutorials/admin/backup_restore/
>>>>>>>>>>>>>>>>> From my django admin page (Base => backups) I tried to do
>>>>>>>>>>>>>>>>> a backup, but, when I run the backup, on a fully writable folder (777),
>>>>>>>>>>>>>>>>> there is this server error:
>>>>>>>>>>>>>>>>> Internal Server Error
>>>>>>>>>>>>>>>>> The server encountered an internal error or
>>>>>>>>>>>>>>>>> misconfiguration and was unable to complete your request.
>>>>>>>>>>>>>>>>> I have double checked the settings.ini file, and I have
>>>>>>>>>>>>>>>>> noted that the configuration file is not yet update for the 2.6 version, it
>>>>>>>>>>>>>>>>> has these lines:
>>>>>>>>>>>>>>>>> #Migrate from GN 2.4 to GN 2.4
>>>>>>>>>>>>>>>>> migrations = base.resourcebase,layers.layer
>>>>>>>>>>>>>>>>> ,layers.attribute,maps.map,maps.maplayer
>>>>>>>>>>>>>>>>> manglers   = gn24_to_24.ResourceBaseMangler
>>>>>>>>>>>>>>>>> ,gn24_to_24.LayerMangler,gn24_
>>>>>>>>>>>>>>>>> to_24.LayerAttributesMangler,g
>>>>>>>>>>>>>>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>>>>>>>>>>>>>>> Is it correct? Have I to change these lines accordingly to
>>>>>>>>>>>>>>>>> the 2.6 version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>>>>>>>>>>>>>>> When I try to run the backup from command line there is
>>>>>>>>>>>>>>>>> the following error about the file backup.py
>>>>>>>>>>>>>>>>> How can I solved this issue?
>>>>>>>>>>>>>>>>> Tanks a lot
>>>>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/2c996deb/attachment-0001.html>
More information about the geonode-users mailing list
