[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Enrique Cerrillo Cuenca cerrillo at uevora.pt
Wed May 24 03:42:06 PDT 2017
Thanks again, Alessio. There is not such a zip file inside the zipped
backup file.
Here is a screenshot from the Geoserver status:
[image: Imágenes integradas 1]
If I try to perform a backup I get the following java-related error:
[image: Imágenes integradas 2]
Thanks
2017-05-24 11:30 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Enrique,
> can you please unzip this file /var/opt/geonode/backups/2017-05-24_041950.zip
> and see if there is a geoserver_catalog.zip inside?
> Can you also unzip that one too?
> Also, to be fully sure you are setting the correct GeoServer Data Dir into
> settings.ini, go to the GeoServer Admin GUI and check this option
> [image: Inline image 1]
> From here you can also test your GeoServer backup and restore
> functionality through this interface
> [image: Inline image 2]
> You can test the "geoserver_catalog.zip" file throught a DRY-RUN restore
> here also.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Wed, May 24, 2017 at 11:41 AM, Enrique Cerrillo Cuenca <
> cerrillo at uevora.pt> wrote:
>> I forgot to mention that the settings.ini file is as follows:
>> [geoserver]
>> datadir = /geoserver_data/
>> dumpvectordata = yes
>> dumprasterdata = yes
>> If I set "datadir" to /geoserver_data/data/ I got errors.
>> 2017-05-24 10:29 GMT+01:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>:
>>> Thanks Alessio for all your help. I expect to help you finding the bugs.
>>> Things are not working here. I do get the "COMPLETE[9/9]” message, but I
>>> get an error when trying to restore the backup file.
>>> Best regards,
>>> Enrique
>>> manage.py backup --backup-dir=/var/opt/geonode/backups
>>> System check identified some issues:
>>> WARNINGS:
>>> *base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>>> ManyToManyField.*
>>> Before proceeding with the Backup, please ensure that:
>>>  1. The backend (DB or whatever) is accessible and you have rights
>>>  2. The GeoServer is up and running and reachable from this machine
>>> Dumping 'GeoServer Catalog [http:----]' into
>>> '//var/opt/geonode/backups/2017-05-24_041950 <041%20950>/geoserver_catal
>>> og.zip'.
>>> STARTED - 1/9
>>> COMPLETED - 9/9
>>> Dumped GeoServer Uploaded Data from '/geoserver_data/data/geonode'.
>>> Deactivating GeoNode Signals...
>>> ...done!
>>> Dumping 'people' into 'people.json'.
>>> Dumping 'account' into 'accounts.json'.
>>> Dumping 'avatar.avatar' into 'avatars.json'.
>>> Dumping 'base.backup' into 'backups.json'.
>>> Dumping 'base.license' into 'licenses.json'.
>>> Dumping 'base.topiccategory' into 'topiccategories.json'.
>>> Dumping 'base.region' into 'regions.json'.
>>> Dumping 'base.resourcebase' into 'resourcebases.json'.
>>> Dumping 'base.contactrole' into 'contactroles.json'.
>>> Dumping 'base.link' into 'links.json'.
>>> Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.
>>> Dumping 'base.spatialrepresentationtype' into
>>> 'spatialrepresentationtypes.json'.
>>> Dumping 'guardian.userobjectpermission' into 'useropermissions.json'.
>>> Dumping 'guardian.groupobjectpermission' into 'groupopermissions.json'.
>>> Dumping 'layers.uploadsession' into 'uploadsessions.json'.
>>> Dumping 'layers.style' into 'styles.json'.
>>> Dumping 'layers.layer' into 'layers.json'.
>>> Dumping 'layers.attribute' into 'attributes.json'.
>>> Dumping 'layers.layerfile' into 'layerfiles.json'.
>>> Dumping 'maps.map' into 'maps.json'.
>>> Dumping 'maps.maplayer' into 'maplayers.json'.
>>> Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.
>>> Dumping 'documents.document' into 'documents.json'.
>>> Dumping 'taggit' into 'tags.json'.
>>> Saved Media Files from '/var/opt/geonode/backups/geonode/uploaded'.
>>> Saved Static Root from '/var/opt/geonode/backups/static_root'.
>>> Saved Static Files from '/var/opt/geonode/backups/geonode/static'.
>>> Saved Locale Files from '/var/opt/geonode/backups/geonode/locale'.
>>> Backup Finished. Archive generated.
>>> Reactivating GeoNode Signals...
>>> ...done!
>>> /var/opt/geonode/backups/2017-05-24_041950 <041%20950>.zip
>>> manage.py restore --backup-file=/var/opt/geonode/backups/2017-05-24_
>>> WARNINGS:
>>> ManyToManyField.*
>>> Before proceeding with the Restore, please ensure that:
>>> WARNING: The restore will overwrite ALL GeoNode data. You want to
>>> proceed? [n]|y: y
>>> Restoring 'GeoServer Catalog [http://------]' into
>>> '/tmp/restore/2017-05-24_041950/geoserver_catalog.zip'.
>>> Traceback (most recent call last):
>>>   File "manage.py", line 29, in <module>
>>>     execute_from_command_line(sys.argv)
>>>   File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> line 354, in execute_from_command_line
>>>     utility.execute()
>>> line 346, in execute
>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>   File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
>>> line 394, in run_from_argv
>>>     self.execute(*args, **cmd_options)
>>> line 445, in execute
>>>     output = self.handle(*args, **options)
>>>   File "/usr/src/app/geonode/base/management/commands/restore.py", line
>>> 97, in handle
>>>     raise ValueError('Could not find GeoServer Backup file [' +
>>> geoserver_bk_file + ']')
>>> ValueError: Could not find GeoServer Backup file
>>> [/tmp/restore/2017-05-24_041950/geoserver_catalog.zip]
>>> El 24 may 2017, a las 8:43, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> escribió:
>>> Those error are due to settings issues I guess.
>>> There are open issues to let backup/restore command more resilient and
>>> more stable. We need to find some time to improve it soon.
>>> @Enrique, your error is caused by GeoServer backup. Basically for some
>>> reason it is not able to complete the backup of the catalog. Until you see
>>> a message "COMPLETE[9/9]" the backup of GeoServer is not fully done. You
>>> should take a look at the GeoServer logs in order to see why it is failing.
>>> Usually this depends on some wrong configuration of datastores.
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, May 23, 2017 at 10:32 PM, Federico Gianoli <alpacagis at gmail.com>
>>> wrote:
>>>> Finally it works!
>>>> Thanks Alessio for your help. Tomorrow morning I'll try to migrate data.
>>>> Creating manually the folder */home/federico/gn_fede/gn_fede/locale* it
>>>> works.
>>>> but using restore command without Sudo I have this error
>>>> *$ python manage.py restore
>>>> --backup-file=/tmp/backup/2017-05-23_132655.zip*
>>>> *Before proceeding with the Restore, please ensure that:*
>>>> * 1. The backend (DB or whatever) is accessible and you have rights*
>>>> * 2. The GeoServer is up and running and reachable from this machine*
>>>> *WARNING: The restore will overwrite ALL GeoNode data. You want to
>>>> proceed? [n]|y: y*
>>>> *Traceback (most recent call last):*
>>>> *  File "manage.py", line 11, in <module>*
>>>> *    execute_from_command_line(sys.argv)*
>>>> *  File
>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>> 354, in execute_from_command_line*
>>>> *    utility.execute()*
>>>> *  File
>>>> 346, in execute*
>>>> *    self.fetch_command(subcommand).run_from_argv(self.argv)*
>>>> *  File
>>>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
>>>> 394, in run_from_argv*
>>>> *    self.execute(*args, **cmd_options)*
>>>> *  File
>>>> 445, in execute*
>>>> *    output = self.handle(*args, **options)*
>>>> *  File
>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
>>>> line 87, in handle*
>>>> *    target_folder = helpers.unzip_file(backup_file, restore_folder)*
>>>> *  File
>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
>>>> line 224, in unzip_file*
>>>> *    os.makedirs(target_folder)*
>>>> *  File "/usr/lib/python2.7/os.py", line 157, in makedirs*
>>>> *    mkdir(name, mode)*
>>>> *OSError: [Errno 13] Permission denied:
>>>> '/tmp/restore/2017-05-23_132655'*
>>>> *with sudo command I have the error later:*
>>>> *$ sudo python manage.py restore
>>>> *[sudo] password for federico:*
>>>> proceed? [n]|y: y*
>>>> *Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/
>>>> <http://212.237.232.12/geoserver/>]' into
>>>> '/tmp/restore/2017-05-23_132655/geoserver_catalog.zip'.*
>>>> *STARTED - 3/9*
>>>> *FAILED - 8/9*
>>>> *Cleaned out old GeoServer Data Dir:
>>>> /usr/share/geoserver/data/data/geonode*
>>>> *GeoServer Uploaded Data Restored to
>>>> '/usr/share/geoserver/data/data/geonode'.*
>>>> *Cleaned out old GeoServer GWC Layers Config:
>>>> /usr/share/geoserver/data/gwc-layers*
>>>> *Restoring GeoServer Vectorial Data : popolazione_veneto*
>>>> *Restoring GeoServer Vectorial Data : gcgw_wells_tayarat*
>>>> *Restoring GeoServer Vectorial Data : main_groundwater_flow*
>>>> *Restoring GeoServer Vectorial Data : swl_asl*
>>>> *Restoring GeoServer Vectorial Data : contour_lines*
>>>> *Restoring GeoServer Vectorial Data : swl_asl_map_area*
>>>> *Restoring GeoServer Vectorial Data : springs_perennial_no_data*
>>>> *Restoring GeoServer Vectorial Data : c0506121_ccs2012s*
>>>> *Restoring GeoServer Vectorial Data : tectonic_structures*
>>>> *Restoring GeoServer Vectorial Data : springs_perennial*
>>>> *Restoring GeoServer Vectorial Data : springs_temporary*
>>>> *Operations to perform:*
>>>> *  Synchronize unmigrated apps: tasks, modeltranslation,
>>>> django_extensions, polymorphic, treebeard, gis,
>>>> pinax_theme_bootstrap_account, django_forms_bootstrap, catalogue, humanize,
>>>> geoserver, storages, mptt, friendlytagloader, staticfiles, geoexplorer,
>>>> gn_fede, sitemaps, proxy, pinax_theme_bootstrap, pagination,
>>>> autocomplete_light, messages, leaflet, api, avatar, social, security*
>>>> *  Apply all migrations: dialogos, people, tastypie, agon_ratings,
>>>> documents, actstream, sites, maps, contenttypes, announcements,
>>>> user_messages, layers, sessions, guardian, auth, base, groups, services,
>>>> oauth2_provider, account, admin, djcelery, upload, taggit*
>>>> *Synchronizing apps without migrations:*
>>>> *  Creating tables...*
>>>> *    Running deferred SQL...*
>>>> *  Installing custom SQL...*
>>>> *Running migrations:*
>>>> *  No migrations to apply.*
>>>> *  Your models have changes that are not yet reflected in a migration,
>>>> and so won't be applied.*
>>>> *  Run 'manage.py makemigrations' to make new migrations, and then
>>>> re-run 'manage.py migrate' to apply them.*
>>>> *Deactivating GeoNode Signals...*
>>>> *...done!*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/people.json*
>>>> *Installed 2 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/accounts.json*
>>>> *Installed 3 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/avatars.json*
>>>> *Installed 0 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/backups.json*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/licenses.json*
>>>> *Installed 7 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/topiccategories.json*
>>>> *Installed 20 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/regions.json*
>>>> *Installed 259 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/resourcebases.json*
>>>> *Installed 13 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/contactroles.json*
>>>> *Installed 26 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/links.json*
>>>> *Installed 296 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/restrictioncodetypes.json*
>>>> *Installed 8 object(s) from 1 fixture(s)*
>>>> *Deserializing
>>>> /tmp/restore/2017-05-23_132655/spatialrepresentationtypes.json*
>>>> *Installed 6 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/useropermissions.json*
>>>> *Installed 141 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/groupopermissions.json*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/uploadsessions.json*
>>>> *Installed 18 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/styles.json*
>>>> *Installed 12 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/layers.json*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/attributes.json*
>>>> *Installed 122 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/layerfiles.json*
>>>> *Installed 104 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/maps.json*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/maplayers.json*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/mapsnapshots.json*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/documents.json*
>>>> *Installed 1 object(s) from 1 fixture(s)*
>>>> *Deserializing /tmp/restore/2017-05-23_132655/tags.json*
>>>> *Media Files Restored into '/var/www/geonode/uploaded'.*
>>>> *Static Root Restored into '/var/www/geonode/static/'.*
>>>> *Reactivating GeoNode Signals...*
>>>> *...done!*
>>>> *  File
>>>> *  File
>>>> 346, in execute*
>>>> *  File
>>>> *  File
>>>> 445, in execute*
>>>> *  File
>>>> line 290, in handle*
>>>> *    static_files_folder)*
>>>> *  File
>>>> line 203, in copy_tree*
>>>> *    for item in os.listdir(src):*
>>>> *OSError: [Errno 2] No such file or directory:
>>>> '/tmp/restore/2017-05-23_132655/static_dirs/media'*
>>>> *Creating manually the folder:
>>>>  /tmp/restore/2017-05-23_132655/static_dirs/media everythings works
>>>> correctly.*
>>>> *Tomorrow morning I'll try again, but I hope to have solved the issue,
>>>> thanks again Alessio for your help.*
>>>> *Good night*
>>>> *Federico*
>>>> 2017-05-23 21:04 GMT+02:00 Enrique Cerrillo Cuenca <cerrillo at uevora.pt>
>>>>> I tried to do that yesterday. The file do exist in the path and it was
>>>>> allegedly created with no errors. However I’m getting this error:
>>>>> python manage.py restore --backup-file=backup/2017-05-17_045850
>>>>> <045%20850>.zip
>>>>> WARNINGS:
>>>>> ManyToManyField.*
>>>>> proceed? [n]|y: y
>>>>> Restoring 'GeoServer Catalog [http://atlas.cidehusdigital.u
>>>>> evora.pt/geoserver/]' into '/tmp/restore/2017-05-17_04585
>>>>>     utility.execute()
>>>>> line 97, in handle
>>>>> [/tmp/restore/2017-05-17_045850/geoserver_catalog.zip]
>>>>> Best regards,
>>>>> Enrique
>>>>> El 23 may 2017, a las 19:12, Alessio Fabiani <
>>>>> Except for the latest issue, which should be a warning (I will need to
>>>>> double check this), you should not restore the geoserver_catalog.zip but
>>>>> the geonode backup file which should be something like
>>>>> --backup-file=/tmp/backup/2017-05-23_120201.zip*
>>>>> If it does not exists that means that the latest warning prevents you
>>>>> to finalize the backup.
>>>>> A quick and dirty workaround is to create the folder
>>>>> */home/federico/gn_fede/gn_fede/locale'*
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Tue, May 23, 2017 at 7:39 PM, Federico Gianoli <alpacagis at gmail.com
>>>>> > wrote:
>>>>>> Thanks a lot Alessio and Enrique,
>>>>>> I think we are on the right way to solve the issue... but I still
>>>>>> have some errors.
>>>>>> I really thank you for your precious help.
>>>>>> *$ python manage.py backup --backup-dir=/tmp/backup/*
>>>>>> *Before proceeding with the Backup, please ensure that:*
>>>>>> *You want to proceed? [n]|y: y*
>>>>>> *Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
>>>>>> '/tmp/backup/2017-05-23_120201/geoserver_catalog.zip'.*
>>>>>> *STARTED - 1/9*
>>>>>> *COMPLETED - 9/9*
>>>>>> *Dumped GeoServer Uploaded Data from
>>>>>> *Dumping GeoServer Vectorial Data : swl_asl*
>>>>>> *Dumping GeoServer Vectorial Data : c0506121_ccs2012s*
>>>>>> *Dumping GeoServer Vectorial Data : popolazione_veneto*
>>>>>> *Dumping GeoServer Vectorial Data : swl_asl_map_area*
>>>>>> *Dumping GeoServer Vectorial Data : contour_lines*
>>>>>> *Dumping GeoServer Vectorial Data : tectonic_structures*
>>>>>> *Dumping GeoServer Vectorial Data : gcgw_wells_tayarat*
>>>>>> *Dumping GeoServer Vectorial Data : main_groundwater_flow*
>>>>>> *Dumping GeoServer Vectorial Data : springs_perennial*
>>>>>> *Dumping GeoServer Vectorial Data : springs_perennial_no_data*
>>>>>> *Dumping GeoServer Vectorial Data : springs_temporary*
>>>>>> *...done!*
>>>>>> *Dumping 'people' into 'people.json'.*
>>>>>> *Dumping 'account' into 'accounts.json'.*
>>>>>> *Dumping 'avatar.avatar' into 'avatars.json'.*
>>>>>> *Dumping 'base.backup' into 'backups.json'.*
>>>>>> *Dumping 'base.license' into 'licenses.json'.*
>>>>>> *Dumping 'base.topiccategory' into 'topiccategories.json'.*
>>>>>> *Dumping 'base.region' into 'regions.json'.*
>>>>>> *Dumping 'base.resourcebase' into 'resourcebases.json'.*
>>>>>> *Dumping 'base.contactrole' into 'contactroles.json'.*
>>>>>> *Dumping 'base.link' into 'links.json'.*
>>>>>> *Dumping 'base.restrictioncodetype' into 'restrictioncodetypes.json'.*
>>>>>> *Dumping 'base.spatialrepresentationtype' into
>>>>>> 'spatialrepresentationtypes.json'.*
>>>>>> *Dumping 'guardian.userobjectpermission' into
>>>>>> 'useropermissions.json'.*
>>>>>> *Dumping 'guardian.groupobjectpermission' into
>>>>>> 'groupopermissions.json'.*
>>>>>> *Dumping 'layers.uploadsession' into 'uploadsessions.json'.*
>>>>>> *Dumping 'layers.style' into 'styles.json'.*
>>>>>> *Dumping 'layers.layer' into 'layers.json'.*
>>>>>> *Dumping 'layers.attribute' into 'attributes.json'.*
>>>>>> *Dumping 'layers.layerfile' into 'layerfiles.json'.*
>>>>>> *Dumping 'maps.map' into 'maps.json'.*
>>>>>> *Dumping 'maps.maplayer' into 'maplayers.json'.*
>>>>>> *Dumping 'maps.mapsnapshot' into 'mapsnapshots.json'.*
>>>>>> *Dumping 'documents.document' into 'documents.json'.*
>>>>>> *Dumping 'taggit' into 'tags.json'.*
>>>>>> *Saved Media Files from '/var/www/geonode/uploaded'.*
>>>>>> *Saved Static Root from '/var/www/geonode/static/'.*
>>>>>> *Saved Static Files from '/etc/geonode/media'.*
>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/static'.*
>>>>>> *Saved Static Files from '/home/federico/gn_fede/gn_fede/static'.*
>>>>>> *Saved Template Files from '/etc/geonode/templates'.*
>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/templates'.*
>>>>>> *...done!*
>>>>>> *  File
>>>>>> *  File
>>>>>> 346, in execute*
>>>>>> *  File
>>>>>> *  File
>>>>>> 445, in execute*
>>>>>> *  File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>>>>>> line 243, in handle*
>>>>>> *    helpers.copy_tree(locale_files_folder, locale_folder)*
>>>>>> *  File
>>>>>> '/home/federico/gn_fede/gn_fede/locale'*
>>>>>> *The restore issue:*
>>>>>> --backup-file=/tmp/backup/2017-05-23_120201/geoserver_catalog.zipBefore
>>>>>> proceeding with the Restore, please ensure that: 1. The backend (DB or
>>>>>> whatever) is accessible and you have rights 2. The GeoServer is up and
>>>>>> running and reachable from this machineWARNING: The restore will overwrite
>>>>>> ALL GeoNode data. You want to proceed? [n]|y: yTraceback (most recent call
>>>>>> last):  File "manage.py", line 11, in <module>
>>>>>> execute_from_command_line(sys.argv)  File
>>>>>> 354, in execute_from_command_line    utility.execute()  File
>>>>>> 346, in execute    self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>> File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>>>> line 394, in run_from_argv    self.execute(*args, **cmd_options)  File
>>>>>> 445, in execute    output = self.handle(*args, **options)  File
>>>>>> line 87, in handle    target_folder = helpers.unzip_file(backup_file,
>>>>>> restore_folder)  File
>>>>>> line 227, in unzip_file    z.extractall(target_folder)  File
>>>>>> "/usr/lib/python2.7/zipfile.py", line 1040, in extractall
>>>>>> self.extract(zipinfo, path, pwd)  File "/usr/lib/python2.7/zipfile.py",
>>>>>> line 1028, in extract    return self._extract_member(member, path, pwd)
>>>>>> File "/usr/lib/python2.7/zipfile.py", line 1083, in _extract_member
>>>>>> file(targetpath, "wb") as target:IOError: [Errno 13] Permission denied:
>>>>>> u'/tmp/restore/geoserver_catalog/store.dat.1'*
>>>>>> *Usuìing SUDO command, the error is different:*
>>>>>> $ sudo python manage.py restore --backup-file=/tmp/backup/2017
>>>>>> proceed? [n]|y: y
>>>>>> Restoring 'GeoServer Catalog [http://212.237.232.12/geoserver/]'
>>>>>> into '/tmp/restore/geoserver_catalog/geoserver_catalog.zip'.
>>>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>>>>     utility.execute()
>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py",
>>>>>> line 97, in handle
>>>>>> [/tmp/restore/geoserver_catalog/geoserver_catalog.zip]
>>>>>> *Anyway, using Enrique suggestion, the system doesn't work and I have
>>>>>> this error:*
>>>>>> Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/]' into
>>>>>> '/tmp/backup/2017-05-23_122247/geoserver_catalog.zip'.
>>>>>> STARTED - 1/9
>>>>>> COMPLETED - 9/9
>>>>>>     utility.execute()
>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>>>>>> line 150, in handle
>>>>>>     helpers.copy_tree(gs_data_root, gs_data_folder)
>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py",
>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver
>>>>>> /data/geonode'
>>>>>> 2017-05-23 18:16 GMT+02:00 Enrique Cerrillo Cuenca <
>>>>>>> Hi,
>>>>>>> I have the same problem that Federico. A few days ago, I made that
>>>>>>> change, “datadir = geoserver/data”, and the backup also failed. However,
>>>>>>> when i set “datadir” to “geoserver/“ it works, although “geoserver_catalog”
>>>>>>> is not included in the backup zip file.
>>>>>>> Best regards,
>>>>>>> Enrique
>>>>>>> El 23 may 2017, a las 16:52, Alessio Fabiani <
>>>>>>> Ok, so, the GeoServer backup has been done "COMPLETED - 9/9" but
>>>>>>> there's an error on the backup settings.
>>>>>>> It looks like it cannot find the GeoServer Data Dir path on the
>>>>>>> local server.
>>>>>>> Edit this file
>>>>>>> geonode/base/management/commands/settings.ini
>>>>>>> and be sure to change this "datadir = *geoserver/data*" with the
>>>>>>> absolute path to the GEOSERVER_DATA_DIR
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Tue, May 23, 2017 at 5:45 PM, Federico Gianoli <
>>>>>>> alpacagis at gmail.com> wrote:
>>>>>>>> Hi Alessio,
>>>>>>>> This is the result of these commands:
>>>>>>>> *Before proceeding with the Backup, please ensure that: 1. The
>>>>>>>> backend (DB or whatever) is accessible and you have rights 2. The GeoServer
>>>>>>>> '/tmp/backup/2017-05-23_103754/geoserver_catalog.zip'.*
>>>>>>>> *STARTED - 1/9COMPLETED - 9/9Traceback (most recent call last):
>>>>>>>> line 150, in handle    helpers.copy_tree(gs_data_root, gs_data_folder)
>>>>>>>> File
>>>>>>>> line 203, in copy_tree    for item in os.listdir(src):OSError: [Errno 2] No
>>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/../geoserver/data/data/geonode'*
>>>>>>>> The backup is created but with the error (*OSError: [Errno 2] No
>>>>>>>> ), and the restore command doesn't work
>>>>>>>> --backup-file=/tmp/backup/2017-05-23_103754/geoserver_catalog.zip*
>>>>>>>> machine*
>>>>>>>> proceed? [n]|y: y*
>>>>>>>> *  File
>>>>>>>> *  File
>>>>>>>> 346, in execute*
>>>>>>>> *  File
>>>>>>>> *  File
>>>>>>>> 445, in execute*
>>>>>>>> *  File
>>>>>>>> line 87, in handle*
>>>>>>>> restore_folder)*
>>>>>>>> *  File
>>>>>>>> line 227, in unzip_file*
>>>>>>>> *    z.extractall(target_folder)*
>>>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1040, in extractall*
>>>>>>>> *    self.extract(zipinfo, path, pwd)*
>>>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1028, in extract*
>>>>>>>> *    return self._extract_member(member, path, pwd)*
>>>>>>>> *  File "/usr/lib/python2.7/zipfile.py", line 1083, in
>>>>>>>> _extract_member*
>>>>>>>> *    file(targetpath, "wb") as target:*
>>>>>>>> *IOError: [Errno 13] Permission denied:
>>>>>>>> Thanks for your help
>>>>>>>> Federico
>>>>>>>> 2017-05-23 17:33 GMT+02:00 Alessio Fabiani <
>>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>>>> Federico, before doing anything, can you try to do this test?
>>>>>>>>> sudo mkdir /tmp/backup
>>>>>>>>> sudo chmod -Rf 777 /tmp/backup
>>>>>>>>> Best Regards,
>>>>>>>>> Alessio Fabiani.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Tue, May 23, 2017 at 5:24 PM, Federico Gianoli <
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> thanks for your quick answer,
>>>>>>>>>> I have checked, but I have not the files 2 and 3 on my geonode
>>>>>>>>>> instance. How is it possible? I have installed geonode via ppa.
>>>>>>>>>> I have overwritten all "commands" folder, in order to be sure to
>>>>>>>>>> have the latest files, bu it is still not working.
>>>>>>>>>> There is another way to do the backup?
>>>>>>>>>> In your opinion, if I upgrade my version of geonode (2.6rc) to
>>>>>>>>>> the last stable (sudo apt-get upgrade   right?), this issue will be solved?
>>>>>>>>>> How dangerous could be for my data?
>>>>>>>>>> Thanks a lot
>>>>>>>>>> Fede
>>>>>>>>>> 2017-05-23 12:38 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>> Digging to the source code of both GeoNode management command
>>>>>>>>>>> [1] and GeoServer Backup Plugin [2] and [3], seems like that GeoServer
>>>>>>>>>>> can't access the "${target_folder}/geoserver_catalog.zip"
>>>>>>>>>>> The ${target_folder} should be composed by the join of ${backup_dir}
>>>>>>>>>>> and ${dir_time_suffix}, something like ${backup_dir}/<time_stamp>
>>>>>>>>>>> where ${backup_dir} is the parameter provided when running the
>>>>>>>>>>> backup command from GeoNode.
>>>>>>>>>>> Now, the latest GeoNode code [4] tries to set chmod(777) to this
>>>>>>>>>>> temporary folder, which will be deleted at the end, in order to allow to
>>>>>>>>>>> GeoServer to write the file.
>>>>>>>>>>> That means that most probably the user running GeoNode must have
>>>>>>>>>>> full rights on the ${backup_dir} folder.
>>>>>>>>>>> Can you maybe try to double check this?
>>>>>>>>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>>>>>> ase/management/commands/backup.py#L92
>>>>>>>>>>> [2] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>>>>>> mmunity/backup-restore/rest/src/main/java/org/geoserver/back
>>>>>>>>>>> uprestore/rest/BackupResource.java#L155
>>>>>>>>>>> [3] https://github.com/geoserver/geoserver/blob/2.9.x/src/co
>>>>>>>>>>> mmunity/backup-restore/core/src/main/java/org/geoserver/back
>>>>>>>>>>> uprestore/Backup.java#L328
>>>>>>>>>>> [4] https://github.com/GeoNode/geonode/blob/master/geonode/b
>>>>>>>>>>> ase/management/commands/backup.py#L86
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Italy
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> On Tue, May 23, 2017 at 12:23 PM, Federico Gianoli <
>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>> I have checked the Geoserver Log, and here you can find the
>>>>>>>>>>>> complete geoserver log: https://pastebin.com/c9JeR1NU
>>>>>>>>>>>> The error that I have noted on the log is this one:
>>>>>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - Unable to
>>>>>>>>>>>> perform backup: :Could not create file.*
>>>>>>>>>>>> *2017-05-23 04:49:10,598 DEBUG [geoserver.filters] -
>>>>>>>>>>>> Compressing output for mimetype: text/plain*
>>>>>>>>>>>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - *
>>>>>>>>>>>> *org.geoserver.rest.RestletException:
>>>>>>>>>>>> java.lang.IllegalStateException: Could not create file.*
>>>>>>>>>>>> * at org.geoserver.backuprestore.re
>>>>>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.runBackup(BackupResource.java:172)*
>>>>>>>>>>>> <http://org.geoserver.backuprestore.re/>st.BackupResource.handlePost(BackupResource.java:108)*
>>>>>>>>>>>> The rights of  /usr/share/geoserver/data are these:
>>>>>>>>>>>> drwxr-xr-x  21 tomcat7 tomcat7      4096 May 23 04:49 data
>>>>>>>>>>>> I have also changed the folder rights adding user: tomcat7 and
>>>>>>>>>>>> user:user, but without any result.
>>>>>>>>>>>> Thanks a lot for your help and your patience
>>>>>>>>>>>> Federico
>>>>>>>>>>>> 2017-05-22 16:49 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>> It is possible that GeoServer cannot write to the target
>>>>>>>>>>>>> folder. Take a look at the GeoServer logs. Also try to rise up the log
>>>>>>>>>>>>> level if you don't find anything useful.
>>>>>>>>>>>>> This can be done from the GeoServer admin gui.
>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>> On Mon, May 22, 2017 at 4:47 PM, Alessio Fabiani <
>>>>>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> which version of GeoServer are you using?
>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>>>>>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>>>>>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>>>>>>>>>> On Fri, May 19, 2017 at 1:08 PM, Federico Gianoli <
>>>>>>>>>>>>>>> Thanks a lot Alessio,
>>>>>>>>>>>>>>> I have changed the files according to your suggestions,
>>>>>>>>>>>>>>> but now I have this error:
>>>>>>>>>>>>>>> *$ sudo python manage.py backup --backup-dir=backup/*
>>>>>>>>>>>>>>> rights*
>>>>>>>>>>>>>>> machine*
>>>>>>>>>>>>>>> [http://212.237.232.12/geoserver/ <http://212.237.232.12/geoserver/>]' into
>>>>>>>>>>>>>>> 'backup/2017-05-19_050730 <050%20730>/geoserver_catalog.zip'.*
>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>> 346, in execute*
>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>> 445, in execute*
>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>> line 101, in handle*
>>>>>>>>>>>>>>> *    gs_backup = r.json()*
>>>>>>>>>>>>>>> *  File
>>>>>>>>>>>>>>> "/usr/lib/python2.7/dist-packages/requests/models.py", line 808, in json*
>>>>>>>>>>>>>>> *    return complexjson.loads(self.text, **kwargs)*
>>>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/__init__.py", line 339, in
>>>>>>>>>>>>>>> loads*
>>>>>>>>>>>>>>> *    return _default_decoder.decode(s)*
>>>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 364, in
>>>>>>>>>>>>>>> decode*
>>>>>>>>>>>>>>> *    obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
>>>>>>>>>>>>>>> *  File "/usr/lib/python2.7/json/decoder.py", line 382, in
>>>>>>>>>>>>>>> raw_decode*
>>>>>>>>>>>>>>> *    raise ValueError("No JSON object could be decoded")*
>>>>>>>>>>>>>>> *ValueError: No JSON object could be decoded*
>>>>>>>>>>>>>>> *Thanks a lot for your help*
>>>>>>>>>>>>>>> *Fede*
>>>>>>>>>>>>>>> 2017-05-05 16:41 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>>>>> PR here
>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode/pull/3031
>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>>>> currently the backup and restore utility should be aligned
>>>>>>>>>>>>>>>>> with latest updates I guess. There are also several issues / improvements
>>>>>>>>>>>>>>>>> we are working on to improve this tool.
>>>>>>>>>>>>>>>>> We will find some spare time soon to devote to those
>>>>>>>>>>>>>>>>> tasks. We will send updates as soon as possible.
>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>> Hi Federico,
>>>>>>>>>>>>>>>>>> there seems to be an issue in the commands, simplejson is
>>>>>>>>>>>>>>>>>> not available anymore, json has to be used. we should fix it.
>>>>>>>>>>>>>>>>>> @afabiani, is that correct?
>>>>>>>>>>>>>>>>>> node/blob/2.6.x/geonode/base/m
>>>>>>>>>>>>>>>>>> anagement/commands/restore.py#L28
>>>>>>>>>>>>>>>>>> anagement/commands/backup.py#L26
>>>>>>>>>>>>>>>>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <
>>>>>>>>>>>>>>>>>> alpacagis at gmail.com>:
>>>>>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>>>>>> I would like to create a backup of my geonode project
>>>>>>>>>>>>>>>>>>> and I am using this guide: http://docs.geonode.org
>>>>>>>>>>>>>>>>>>> /en/master/tutorials/admin/backup_restore/
>>>>>>>>>>>>>>>>>>> From my django admin page (Base => backups) I tried to
>>>>>>>>>>>>>>>>>>> do a backup, but, when I run the backup, on a fully writable folder (777),
>>>>>>>>>>>>>>>>>>> there is this server error:
>>>>>>>>>>>>>>>>>>> Internal Server Error
>>>>>>>>>>>>>>>>>>> The server encountered an internal error or
>>>>>>>>>>>>>>>>>>> misconfiguration and was unable to complete your request.
>>>>>>>>>>>>>>>>>>> I have double checked the settings.ini file, and I have
>>>>>>>>>>>>>>>>>>> noted that the configuration file is not yet update for the 2.6 version, it
>>>>>>>>>>>>>>>>>>> has these lines:
>>>>>>>>>>>>>>>>>>> #Migrate from GN 2.4 to GN 2.4
>>>>>>>>>>>>>>>>>>> migrations = base.resourcebase,layers.layer
>>>>>>>>>>>>>>>>>>> ,layers.attribute,maps.map,maps.maplayer
>>>>>>>>>>>>>>>>>>> manglers   = gn24_to_24.ResourceBaseMangler
>>>>>>>>>>>>>>>>>>> ,gn24_to_24.LayerMangler,gn24_
>>>>>>>>>>>>>>>>>>> to_24.LayerAttributesMangler,g
>>>>>>>>>>>>>>>>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>>>>>>>>>>>>>>>>> Is it correct? Have I to change these lines accordingly
>>>>>>>>>>>>>>>>>>> to the 2.6 version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>>>>>>>>>>>>>>>>> When I try to run the backup from command line there is
>>>>>>>>>>>>>>>>>>> the following error about the file backup.py
>>>>>>>>>>>>>>>>>>> How can I solved this issue?
>>>>>>>>>>>>>>>>>>> Tanks a lot
>>>>>>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/3ebc2954/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/3ebc2954/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/3ebc2954/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/3ebc2954/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/3ebc2954/attachment-0007.png>
More information about the geonode-users mailing list
