[GeoNode-users] Installing GeoNode on RedHat OS 7.0
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 24 06:46:46 PDT 2017
Indeed this is an issue with python gdal installation.
if you have gdal 1.11 then you might have to do "pip install gdal==1.11.3"
2017-05-24 14:51 GMT+02:00 Rasika Chinchwade <rasikachinchwade31 at gmail.com>:
> Thank you Simone.Now we solved the proxy issue but new problem arises with
> migration command.
> The django version for GeoNode 2.4.x is 1.6.11 which does not have
> migration support.
> So whenever I ran the coomand *pyrhon manage.py migrate *it is giving me
> eeror like
> Unknown command: 'migrate'
> Type 'manage.py help' for usage.
> Then we tried with python manage.py syndb
> that also not satisfied the problem.
> Then I tried with south app by seaching on net. but that was also giving
> me same error
> (*both syncdb  and south app giving error as follows)*
> Not enabling BingMaps base layer as a BING_API_KEY is not defined in
> local_settings.py file.
> Traceback (most recent call last):
>   File "manage.py", line 28, in <module>
>     execute_from_command_line(sys.argv)
>   File "/usr/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 399, in execute_from_command_line
>     utility.execute()
> line 392, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/lib/python2.7/site-packages/django/core/management/base.py",
> line 242, in run_from_argv
>     self.execute(*args, **options.__dict__)
> line 284, in execute
>     self.validate()
> line 310, in validate
>     num_errors = get_validation_errors(s, app)
>   File "/usr/lib/python2.7/site-packages/django/core/management/validation.py",
> line 34, in get_validation_errors
>     for (app_name, error) in get_app_errors().items():
>   File "/usr/lib/python2.7/site-packages/django/db/models/loading.py",
> line 196, in get_app_errors
>     self._populate()
> line 78, in _populate
>     self.load_app(app_name)
> line 99, in load_app
>     models = import_module('%s.models' % app_name)
>   File "/usr/lib/python2.7/site-packages/django/utils/importlib.py", line
> 40, in import_module
>     __import__(name)
>   File "/usr/lib/python2.7/site-packages/modeltranslation/models.py",
> line 84, in <module>
>     handle_translation_registrations()
> line 80, in handle_translation_registrations
>     autodiscover()
> line 31, in autodiscover
>     import_module(module)
>     __import__(name)
>   File "/data/cms/geonode/geonode/base/translation.py", line 2, in
> <module>
>     from geonode.base.models import (TopicCategory,
> SpatialRepresentationType, Region,
>   File "/data/cms/geonode/geonode/base/models.py", line 28, in <module>
>     from geonode.utils import bbox_to_wkt
>   File "/data/cms/geonode/geonode/utils.py", line 28, in <module>
>    * from osgeo import ogr*
> *ImportError: No module named osgeo*
> We have installed  pip install gdal
> version of gdal=1.11.4
> Still the same problem arises.
> Please five any idea to solve this problem as soon as possible.
> Thank you
> On Wed, May 24, 2017 at 3:09 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi, seems that you have network issues. Not sure what can be, check that
>> your server can correctly reach internet and if there are proxies, make
>> sure your server is using them correctly.
>> Best
>> 2017-05-24 11:27 GMT+02:00 Rasika Chinchwade <
>>> Thank you sir for your reply.
>>> After running the command that you mentioned in reply I am getting the
>>> following error:
>>> Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after
>>> connection broken by 'NewConnectionError('<pip._ven
>>> dor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object
>>> at 0x2da6690>: Failed to establish a new connection: [Errno 101] Network is
>>> unreachable',)': /simple/pip/
>>> Retrying (Retry(total=3, connect=None, read=None, redirect=None)) after
>>> at 0x2da6810>: Failed to establish a new connection: [Errno 101] Network is
>>> Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after
>>> at 0x2da6990>: Failed to establish a new connection: [Errno 101] Network is
>>> Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after
>>> at 0x2da6b10>: Failed to establish a new connection: [Errno 101] Network is
>>> Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after
>>> at 0x2da6c90>: Failed to establish a new connection: [Errno 101] Network is
>>> *Requirement already up-to-date: pip in /usr/lib/python2.7/site-packages*
>>> I kept proxy settings in the terminal also. Kindly suggest me the way
>>> for installing it on my system.
>>> Thank you
>>> On Wed, May 24, 2017 at 12:34 PM, Simone Dalmasso <
>>>> Hi, installation with pip is different from the installation with yum,
>>>>  try to update pip first with "pip install --upgrade pip" this may help you
>>>> to find the correct pil.
>>>> 2017-05-24 5:35 GMT+02:00 Rasika Chinchwade <
>>>>> Hi,
>>>>> I am following the instructions metioned from below link to deploy
>>>>> Geonode 2.6.x in Rhel 7.2 64 bit machine.
>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>>> n/setup_on_centos/index.html
>>>>> when I am doing the step
>>>>> cd /home/geonode/geonode
>>>>> pip install -e .
>>>>> *that is giving me error like pilliow version>=3.1.1 not
>>>>> satisfied.Also when I tried to update it with command*
>>>>> *yum update python-imaging*
>>>>> it is showing uptodate.Nothing to do.And the version of python-pillow
>>>>> is 2.0.0-19 is already installed and latest one. And also serached on net
>>>>> for downloading latest rpm of python-pillow for rhel 7.2 but unable to find.
>>>>> Please suggest me to proceed further.
>>>>> Thank you
>>>>> On Mon, May 22, 2017 at 5:35 PM, Simone Dalmasso <
>>>>>> Hi, you can follow this one, although we released the 2.6 and we have
>>>>>> to update the version number in the docs.
>>>>>> 2017-05-22 13:32 GMT+02:00 Rasika Chinchwade <
>>>>>>> hello all,
>>>>>>>  I want to install geonode on RedHat 7.0 ,64 bit OS.
>>>>>>> I got the following link when I searched for it.
>>>>>>> https://groups.google.com/forum/#!topic/geonode-users/jxgWTFQhrOA which
>>>>>>> is from year 2014 for the rhel 6.6.
>>>>>>> Please suggest whether the steps mentioned in above link will
>>>>>>> sufficient for deploying GeoNode latest version in Rhel 7.0.Please reply as
>>>>>>> soon as possible.
>>>>>>> Thank you
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/a72ae317/attachment-0001.html>
More information about the geonode-users mailing list
