[GeoNode-users] "Local Geoserver" returns /maps/[object Object]/geoserver/wms using 2.6 & geonode-client
David Kennewell david.kennewell at hydrata.com
Wed May 24 21:45:17 PDT 2017
Hi Simone,
I wasn't sure if it was a 2.6 configuration issue, or a react client bug,
but I tested with the geoexplorer client this morning and it works fine, so
it must be something on the react side.
I've filed a ticket in geonode-client.
Thanks
On Wed, May 24, 2017 at 10:35 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Hi this seems a client issue right?
> Mind filing a ticket in the Geonode client repo? Thanks.
> Il giorno mer 24 mag 2017 alle 18:48 David Kennewell <
> david.kennewell at hydrata.com> ha scritto:
>> OK, so I'm running Geonode 2.6 installed with apt-get, and geonode-client
>> 0.23 compiled from source at master (#4118783 for the record, although I
>> get the same behaviour using the pip install v0.0.18).
>> When I create a new map (from the geonode maps_browse "new map" button),
>> then expand the layers button and click "add layer", my "Local Geoserver"
>> is returning a 404 popup.
>> In the browser console I get the message:
>> http://myamazinggeonode.com/proxy/?url=http%3A%2F%
>> 2Fmyamazinggeonode.com%2Fmaps%2F%5Bobject%20Object%5D%
>> 2Fgeoserver%2Fwms%3Fservice%3DWMS%26request%3DGetCapabilities%26version%
>> 3D1.3.0
>> If you read translate the URL encoding, you'll notice the url contains a
>> reference to "/maps/[object Object]/geoserver/wms?"
>> Does this give anyone hints as to what's misconfigured?
>> Dave
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170525/2c7df68b/attachment.html>
More information about the geonode-users mailing list
