[GeoNode-users] geoserver authentication in multi-geosites
Alessio Fabiani alessio.fabiani at gmail.com
Wed May 31 07:17:36 PDT 2017
In that case I guess there are two possible causes (I would need some time
to investigate more on this thoguh):
1. Download Links (somehow) are not generated on your GeoNode DB; this is
the most probable cause. Currently there is no other solution than create
the manually or either create a simple script that does it for you
automatically.
2. GeoNode does not recognize the store type of the Resource.
On Wed, May 31, 2017 at 4:13 PM, Eugenio Trumpy <frippe12573 at hotmail.com>
wrote:
> This layer was uploaded directly from the child site. The original layer
> was in tif format,
> so that geoserver stored it as geotiff store.
> The issue was that such layer cannot be downloaded as geotiff.
> As download choice I have only JPEG, PDF, PNG, KML, View in Google Earth,
> Tiles
> instead of the complete list:
> JPEG, PDF, PNG, ArcGrid, GeoTIFF, Gtopo30, ImageMosaic, KML, View in
> Google Earth, Tiles
> E.
> *Da:* Alessio Fabiani <alessio.fabiani at gmail.com>
> *Inviato:* mercoledì 31 maggio 2017 15:55
> *A:* Eugenio Trumpy
> *Cc:* geonode-users; Simone Dalmasso
> *Oggetto:* Re: [GeoNode-users] geoserver authentication in multi-geosites
> I guess I got the problem, you configured the layer as a cascade WMS.
> However, sorry... what was exactly the issue?
> On Wed, May 31, 2017 at 3:52 PM, Eugenio Trumpy <frippe12573 at hotmail.com>
> wrote:
>> I see that layer as anonymous user.
>> E.
>> *Inviato:* mercoledì 31 maggio 2017 15:45
>> *A:* Eugenio Trumpy
>> Hello Eugenio,
>> so, just do a quick test... if the layer is public, go to
>> http://geothoponode.igg.cnr.it/geoserver2 and, as anonymous user, try to
>> hit Layer Preview.
>> If you don't see your layer listed here, that means that the security (at
>> least on that geoserver2 instance) does not allow you to access it as an
>> anonymous user.
>> On Wed, May 31, 2017 at 3:20 PM, Eugenio Trumpy <frippe12573 at hotmail.com>
>> wrote:
>>> Hi Alessio,
>>> the raster layer is a public layer. It can be seen by anyone (check box
>>> marked). There is also my name among the users. The same for download
>>> capabilities.
>>> I saw this information in the 'Change layer permissions' panel.
>>> What do you mean with "Is the geotiff present and configured on the
>>> second instance too"? If you mean that the raster layer is listed also
>>> in the child site,
>>> the answer is yes.
>>> I don't know how to catch the request, however the geoserver log output
>>> is:
>>> https://pastebin.com/W0K9LHde
>>> any hints?
>>> E.
>>> *Inviato:* mercoledì 24 maggio 2017 15.50
>>> *A:* Eugenio Trumpy
>>> multi-geosites
>>> Is the geotiff present and configured on the second instance too? Is it
>>> private or publicly accessible? Can you somehow intercept the requests and
>>> send them here?
>>> On May 20, 2017 15:20, "Eugenio Trumpy" <frippe12573 at hotmail.com> wrote:
>>>> Hi all,
>>>> unfortunately I was not able to solve the issue raised in this thread.
>>>> I was just living in the situation described.
>>>> However, today I have to face a consequent, I guess, issue.
>>>> From a child site I'm not able to download a raster layer (uploaded as
>>>> tif) in geotiff format (i.e. in the download menu there is not the item
>>>> 'Geotiff').
>>>> If I try to download the same raster layer from the master site it is
>>>> possible (i.e. in the download menu there is the item 'Geotiff').
>>>> I think is a matter of geoserver configuration/authentication in
>>>> geonode-multitenancy environment.
>>>> Have you got any suggestion?
>>>> E.
>>>> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
>>>> *Inviato:* mercoledì 5 aprile 2017 15.39
>>>> *A:* Eugenio Trumpy
>>>> *Cc:* geonode-users at lists.osgeo.org
>>>> *Oggetto:* Re: geoserver authentication in multi-geosites
>>>> Eugenio, I don't see wrong config. It is ok I guess to leave the master
>>>> site host in the gs config as well as I think it is ok that you cannot log
>>>> in directly into gs from a child site. That said, when geosites was
>>>> developed, the geoserver ext was modified to make sure that geoserver pings
>>>> the same host that made the http request for authentication instead of
>>>> relying on the base url parameter. So ideally it should work as you would
>>>> expect.
>>>> 2017-04-05 14:39 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>> Hi,
>>>>> I'm working on geonode 2.4 in a Ubuntu server 14.04LTS (tomcat7,
>>>>> java8).
>>>>> I had to upgrade geoserver from 2.7.x version up to 2.9.x.
>>>>> In the system I configured geonode to work as multi-geosites.
>>>>> The master site is the normal geonode site, I mean it use the
>>>>> local_setting.py I have in /geonode/geonode
>>>>> The geosites are in /geonode/geonode/contrib/geosites, and they use
>>>>> the relative config files.
>>>>> The documentation: https://github.com/terranodo/geosites-project
>>>>> /blob/master/GEOSITES-README.md
>>>>> indicates to leave empty <baseurl> in config.xml in
>>>>> security/auth/geonodeauthprovider/
>>>>> In that way I have this error:
>>>>> java.lang.IllegalArgumentException: host parameter is null
>>>>> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:206)
>>>>> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:155)
>>>>> 	org.apache.commons.httpclient.SimpleHttpConnectionManager.getConnectionWithTimeout(SimpleHttpConnectionManager.java:175)
>>>>> 	org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:153)
>>>>> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
>>>>> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
>>>>> 	org.geonode.security.HTTPClient.sendGET(HTTPClient.java:89)
>>>>> 	org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
>>>>> 	org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
>>>>> 	org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
>>>>> 	org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
>>>>> 	org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
>>>>> 	org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:323)
>>>>> 	org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:94)
>>>>> 	org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
>>>>> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>> 	org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
>>>>> 	org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>>>>> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>> 	org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>>>>> 	org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
>>>>> 	org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
>>>>> 	org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
>>>>> 	org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>>> 	org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
>>>>> 	org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>>>>> 	org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>> 	org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>>>>> 	org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>>>>> 	org.springframework.web.filter.CharacterEncodingFilter.doFilterIntaernal(CharacterEncodingFilter.java:121)
>>>>> 	org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
>>>>> both if I use the geoserver link in the menu (once logged in) and if I
>>>>> call geoserver by using the geoserver url in the browser address bar.
>>>>> If set the doman name of the master site in <baseurl> in config.xml
>>>>> in security/auth/geonodeauthprovider/
>>>>> I'm able to enter in geoserver as admin from the menu, by the way
>>>>> doing the same operation from a geosite
>>>>> I got the geoserverage but not logged.
>>>>> The master site virtualhost as well as those of the geosites have the
>>>>> proxypass and reverse pointing to http://localhost:8080/geoserver
>>>>> The same in /geonode/geonode/contrib/geosites/local_setting.py and
>>>>> pre-setting.py I have http://localhost:8080/geoserver
>>>>> Is there a wrong configuration?
>>>>> Any hints?
>>>> Simone
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170531/e2a4f652/attachment-0001.html>
More information about the geonode-users mailing list
