[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Pasquali paolo.pasquali at ithaca.polito.it
Tue Nov 7 01:29:34 PST 2017
Dear all,
I'm experiencing this problem with GeoNode 2.6.3. From some point on, every
layer I upload does not appear in the GeoFence list.
I've tried to edit and save permissions, restart Apache, Tomcat, run
fixlayerpermission but with no result.
This is not happening in my local installation that reflects the affected
website.
Is there some action I can take except upgrading GeoServer?
Thanks.
Best,
Paolo
On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <alpacagis at gmail.com>
wrote:
> Dear list,
> It seems that the problem with the permission is solved with the upgrading
> of geoserver to 2.10 version
> Thanks Alessio for your help
> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
> .it>:
>> In that case you are correct. You need to double check that GeoFence
>> access rules have been correctly set on GeoServer for the layer you are
>> modifying.
>> If you cannot find them or the rules are not correctly updated, it is
>> possible that there is some communication issue between GeoNode and
>> GeoServer.
>> [image: Inline image 1]
>> Maybe try to do some tests and double check that the rules actually
>> change.
>> P.S.: do not use browser refresh on GeoFence Rules, but always click here
>> [image: Inline image 2]
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> github <https://github.com/afabiani?tab=overview>
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <(331)%20623-3686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <alpacagis at gmail.com>
>> wrote:
>>> Thanks  for your reply Alessio,
>>> about the layer preview question, I am logged in with the "SGI" user,
>>> that should be have the permission to see the layer.
>>> Moreover, the user that I'm using, is part of the "Staff" group, but I
>>> can't see the layer preview.
>>> Where I am wrong?
>>> [image: Immagine incorporata 1]
>>> Really thanks
>>> Federico
>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>:
>>>> Hello,
>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>> groups.
>>>> 2) you can either change the Javascript of the map composer or manually
>>>> modify the SLDs on GeoServer by setting ths Max and Min Scale Denominators
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <alpacagis at gmail.com>
>>>> wrote:
>>>>> Dear list,
>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>> 1- Layer permission issue:
>>>>> When I change the permission: "who can view it" from Anyone to a
>>>>> specific user/group, It works but the layer preview disappear, and I am not
>>>>> more able to see the layer shape. Should I have to set something in Django
>>>>> or Geoserver?
>>>>> 2- Is it possible to fix a specific scale for the map view in the map
>>>>> composer? e.g. I would see a map only at 1:250'000 (or at the zoom level
>>>>> that is closest to 1:250'000...)
>>>>> Thanks a lot
>>>>> Federico
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/d0f12b3b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/d0f12b3b/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/d0f12b3b/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/d0f12b3b/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/d0f12b3b/attachment-0007.png>
More information about the geonode-users mailing list
