[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Corti pcorti at gmail.com
Tue Nov 7 08:21:30 PST 2017
Hi Paolo
Strange, it should work. Can you remove the try/except block and send me
again the stack trace?
thanks
p
On Tue, Nov 7, 2017 at 10:06 AM, Paolo Pasquali <
paolo.pasquali at ithaca.polito.it> wrote:
> Ciao Paolo.
> Actually I'm getting an error:
> $ python manage.py sync_geofence
> ('Unexpected error:', <type 'exceptions.AttributeError'>)
> Traceback (most recent call last):
>   File "manage.py", line 11, in <module>
>     execute_from_command_line(sys.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
> line 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
> line 445, in execute
>     output = self.handle(*args, **options)
>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/
> management/commands/sync_geofence.py", line 58, in handle
>     print 'perm_spec is %s' % perm_spec
> UnboundLocalError: local variable 'perm_spec' referenced before assignment
> Thanks!
> P.
> On Tue, Nov 7, 2017 at 3:44 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> Hi Paolo
>> while I am not sure why this is happening (it shouldn't), in GeoNode
>> master there is now a sync_geofence command which will fix things:
>> https://github.com/GeoNode/geonode/blob/master/geono
>> de/geoserver/management/commands/sync_geofence.py
>> It should work for 2.6.x as well, in case not let me know
>> cheers
>> p
>> On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
>>> Dear all,
>>> I'm experiencing this problem with GeoNode 2.6.3. From some point on,
>>> every layer I upload does not appear in the GeoFence list.
>>> I've tried to edit and save permissions, restart Apache, Tomcat, run
>>> fixlayerpermission but with no result.
>>> This is not happening in my local installation that reflects the
>>> affected website.
>>> Is there some action I can take except upgrading GeoServer?
>>> Thanks.
>>> Best,
>>> Paolo
>>> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <alpacagis at gmail.com>
>>> wrote:
>>>> Dear list,
>>>> It seems that the problem with the permission is solved with the
>>>> upgrading of geoserver to 2.10 version
>>>> Thanks Alessio for your help
>>>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>>> In that case you are correct. You need to double check that GeoFence
>>>>> access rules have been correctly set on GeoServer for the layer you are
>>>>> modifying.
>>>>> If you cannot find them or the rules are not correctly updated, it is
>>>>> possible that there is some communication issue between GeoNode and
>>>>> GeoServer.
>>>>> [image: Inline image 1]
>>>>> Maybe try to do some tests and double check that the rules actually
>>>>> change.
>>>>> P.S.: do not use browser refresh on GeoFence Rules, but always click
>>>>> here
>>>>> [image: Inline image 2]
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> GeoServer Professional Services from the experts!
>>>>> Visit http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> github <https://github.com/afabiani?tab=overview>
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A
>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>>> 55054  Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>> mob:   +39 331 6233686 <(331)%20623-3686>
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>> The information in this message and/or attachments, is intended solely
>>>>> for the attention and use of the named addressee(s) and may be confidential
>>>>> or proprietary in nature or covered by the provisions of privacy act
>>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>>> strictly forbidden except previous formal approval of the named
>>>>> addressee(s). If you are not the intended recipient, please contact
>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>> information in this message that has been received in error. The sender
>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>> made after they were sent or for other risks which arise as a result of
>>>>> e-mail transmission, viruses, etc.
>>>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <alpacagis at gmail.com
>>>>> > wrote:
>>>>>> Thanks  for your reply Alessio,
>>>>>> about the layer preview question, I am logged in with the "SGI" user,
>>>>>> that should be have the permission to see the layer.
>>>>>> Moreover, the user that I'm using, is part of the "Staff" group, but
>>>>>> I can't see the layer preview.
>>>>>> Where I am wrong?
>>>>>> [image: Immagine incorporata 1]
>>>>>> Really thanks
>>>>>> Federico
>>>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>>>>> Hello,
>>>>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>>>>> groups.
>>>>>>> 2) you can either change the Javascript of the map composer or
>>>>>>> manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>>>> Denominators
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> 55054  Massarosa
>>>>>>> (LU)
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <
>>>>>>> alpacagis at gmail.com> wrote:
>>>>>>>> Dear list,
>>>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>>>> 1- Layer permission issue:
>>>>>>>> When I change the permission: "who can view it" from Anyone to a
>>>>>>>> specific user/group, It works but the layer preview disappear, and I am not
>>>>>>>> more able to see the layer shape. Should I have to set something in Django
>>>>>>>> or Geoserver?
>>>>>>>> 2- Is it possible to fix a specific scale for the map view in the
>>>>>>>> map composer? e.g. I would see a map only at 1:250'000 (or at the zoom
>>>>>>>> level that is closest to 1:250'000...)
>>>>>>>> Thanks a lot
>>>>>>>> Federico
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/1cb069ed/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/1cb069ed/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/1cb069ed/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/1cb069ed/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/1cb069ed/attachment-0007.png>
More information about the geonode-users mailing list
