[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Pasquali paolo.pasquali at ithaca.polito.it
Tue Nov 7 09:02:38 PST 2017
I've run the script without layer.alternate (don't know what it is) and I
get:
Synchronizing permissions for layer 1/95
('Unexpected error:', None)
perm_spec is {u'users': {u'paolo': [u'view_resourcebase',
u'download_resourcebase', u'change_resourcebase_metadata',
u'change_resourcebase', u'delete_resourcebase',
u'change_resourcebase_permissions', u'publish_resourcebase',
u'change_layer_data', u'change_layer_style']}, u'groups': {u'anonymous':
[u'download_resourcebase', u'view_resourcebase']}}
On Tue, Nov 7, 2017 at 5:56 PM, Paolo Pasquali <
paolo.pasquali at ithaca.polito.it> wrote:
> Sorry, maybe you asked for this:
> $ python manage.py sync_geofence
> Traceback (most recent call last):
>   File "manage.py", line 11, in <module>
>     execute_from_command_line(sys.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
> line 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
> line 445, in execute
>     output = self.handle(*args, **options)
>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/
> management/commands/sync_geofence.py", line 53, in handle
>     print 'Synchronizing permissions for layer %s/%s: %s' % (count,
> layers_count, layer.alternate)
> AttributeError: 'Layer' object has no attribute 'alternate'
> Paolo Pasquali
> ITHACA
> Information Technology for Humanitarian Assistance, Cooperation and Action
> via Pier Carlo Boggio, 61 - 10138 Torino - Italy
> Tel. +39 011 1975 1111 <+39%20011%201975%201111>
> Fax +39 011 1975 1122 <+39%20011%201975%201122>
> www.ithacaweb.org
> On Tue, Nov 7, 2017 at 5:30 PM, Paolo Pasquali <
>> Hi,
>> No stack trace. It seems it does nothing.
>> Thanks.
>> On Tue, Nov 7, 2017 at 5:21 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>> Hi Paolo
>>> Strange, it should work. Can you remove the try/except block and send me
>>> again the stack trace?
>>> thanks
>>> p
>>> On Tue, Nov 7, 2017 at 10:06 AM, Paolo Pasquali <
>>>> Ciao Paolo.
>>>> Actually I'm getting an error:
>>>> ('Unexpected error:', <type 'exceptions.AttributeError'>)
>>>>     utility.execute()
>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/managem
>>>> ent/commands/sync_geofence.py", line 58, in handle
>>>>     print 'perm_spec is %s' % perm_spec
>>>> UnboundLocalError: local variable 'perm_spec' referenced before
>>>> assignment
>>>> Thanks!
>>>> P.
>>>> On Tue, Nov 7, 2017 at 3:44 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>> Hi Paolo
>>>>> while I am not sure why this is happening (it shouldn't), in GeoNode
>>>>> master there is now a sync_geofence command which will fix things:
>>>>> https://github.com/GeoNode/geonode/blob/master/geono
>>>>> de/geoserver/management/commands/sync_geofence.py
>>>>> It should work for 2.6.x as well, in case not let me know
>>>>> cheers
>>>>> p
>>>>> On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
>>>>>> Dear all,
>>>>>> I'm experiencing this problem with GeoNode 2.6.3. From some point on,
>>>>>> every layer I upload does not appear in the GeoFence list.
>>>>>> I've tried to edit and save permissions, restart Apache, Tomcat, run
>>>>>> fixlayerpermission but with no result.
>>>>>> This is not happening in my local installation that reflects the
>>>>>> affected website.
>>>>>> Is there some action I can take except upgrading GeoServer?
>>>>>> Thanks.
>>>>>> Best,
>>>>>> Paolo
>>>>>> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <
>>>>>> alpacagis at gmail.com> wrote:
>>>>>>> Dear list,
>>>>>>> It seems that the problem with the permission is solved with the
>>>>>>> upgrading of geoserver to 2.10 version
>>>>>>> Thanks Alessio for your help
>>>>>>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>>> In that case you are correct. You need to double check that
>>>>>>>> GeoFence access rules have been correctly set on GeoServer for the layer
>>>>>>>> you are modifying.
>>>>>>>> If you cannot find them or the rules are not correctly updated, it
>>>>>>>> is possible that there is some communication issue between GeoNode and
>>>>>>>> GeoServer.
>>>>>>>> [image: Inline image 1]
>>>>>>>> Maybe try to do some tests and double check that the rules actually
>>>>>>>> change.
>>>>>>>> P.S.: do not use browser refresh on GeoFence Rules, but always
>>>>>>>> click here
>>>>>>>> [image: Inline image 2]
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> GeoServer Professional Services from the experts!
>>>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>>>> Ing. Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> github <https://github.com/afabiani?tab=overview>
>>>>>>>> Founder/Technical Lead
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Via di Montramito 3/A
>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>>>>>> 55054  Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>>> mob:   +39 331 6233686 <(331)%20623-3686>
>>>>>>>> http://www.geo-solutions.it
>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <
>>>>>>>>> Thanks  for your reply Alessio,
>>>>>>>>> about the layer preview question, I am logged in with the "SGI"
>>>>>>>>> user, that should be have the permission to see the layer.
>>>>>>>>> Moreover, the user that I'm using, is part of the "Staff" group,
>>>>>>>>> but I can't see the layer preview.
>>>>>>>>> Where I am wrong?
>>>>>>>>> [image: Immagine incorporata 1]
>>>>>>>>> Really thanks
>>>>>>>>> Federico
>>>>>>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>>>>>>>> Hello,
>>>>>>>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>>>>>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>>>>>>>> groups.
>>>>>>>>>> 2) you can either change the Javascript of the map composer or
>>>>>>>>>> manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>>>>>>> Denominators
>>>>>>>>>> Best Regards,
>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> 55054  Massarosa
>>>>>>>>>> (LU)
>>>>>>>>>> Italy
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <
>>>>>>>>>>> Dear list,
>>>>>>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>>>>>>> 1- Layer permission issue:
>>>>>>>>>>> When I change the permission: "who can view it" from Anyone to a
>>>>>>>>>>> specific user/group, It works but the layer preview disappear, and I am not
>>>>>>>>>>> more able to see the layer shape. Should I have to set something in Django
>>>>>>>>>>> or Geoserver?
>>>>>>>>>>> 2- Is it possible to fix a specific scale for the map view in
>>>>>>>>>>> the map composer? e.g. I would see a map only at 1:250'000 (or at the zoom
>>>>>>>>>>> level that is closest to 1:250'000...)
>>>>>>>>>>> Thanks a lot
>>>>>>>>>>> Federico
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/ce08cf25/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/ce08cf25/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/ce08cf25/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/ce08cf25/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/ce08cf25/attachment-0007.png>
More information about the geonode-users mailing list
