[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Corti pcorti at gmail.com
Wed Nov 8 07:51:07 PST 2017
Hi Paolo
Look at this issue, it is exactly what you are hitting in 2.6.x:
https://github.com/GeoNode/geonode/issues/3376
This has been fixed in master:
https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
2f822aeae6
This way updatelayers will correctly sync permissions, which otherwise are
messed.
cheers
p
On Wed, Nov 8, 2017 at 5:18 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Paolo, for what I can tell, I haven't had any issues with gs 2.9 so far
> but never tried updatelayers. I think that with the 2.9 it has to run as
> many 2.6 instances are using it.
> Could it be some misconfiguration in the oauth system? Do you have any
> error in the logs when uploading a layer?
> 2017-11-08 11:13 GMT+01:00 Paolo Pasquali <paolo.pasquali at ithaca.polito.it
>> Hi,
>> I just want to summarize what it is happening on my 2.6.3 version.
>> For no apparent reason GeoFence is not writing permissions of newly
>> created layers anymore. In GeoServer the new layers are not listed in the
>> GeoFence section.
>> Running updatelayers screwed up all layers permissions. The sync_geofence
>> script fixed the old layers but not the new ones (since the issue occurred).
>> Looking into catalina.out I get this error when trying to view a layer
>> without being logged:
>> 08 Nov 10:49:02 ERROR [geoserver.ows] -
>> org.geoserver.platform.ServiceException: Could not find layer
>> geonode:ville_3a4edffa
>> So, I'm still using GeoServer 2.9 and it seems that this permission issue
>> has been fixed on 2.10.
>> Can you confirm?
>> What would you suggest? Upgrading to GeoServer 2.10 or reinstalling the
>> whole platform?
>> Thanks for your help.
>> Best,
>> Paolo
>> On Wed, Nov 8, 2017 at 9:15 AM, Paolo Pasquali <
>> paolo.pasquali at ithaca.polito.it> wrote:
>>> Thanks Paolo!
>>> It solved the issue. I owe you a beer. Daje!
>>> Ciao.
>>> P.
>>> On Tue, Nov 7, 2017 at 6:09 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>> Hi Paolo
>>>> File a ticket. Later today I will try to backport the command to 2.6.x
>>>> cheers
>>>> p
>>>> On Tue, Nov 7, 2017 at 12:02 PM, Paolo Pasquali <
>>>>> I've run the script without layer.alternate (don't know what it is)
>>>>> and I get:
>>>>> Synchronizing permissions for layer 1/95
>>>>> ('Unexpected error:', None)
>>>>> perm_spec is {u'users': {u'paolo': [u'view_resourcebase',
>>>>> u'download_resourcebase', u'change_resourcebase_metadata',
>>>>> u'change_resourcebase', u'delete_resourcebase',
>>>>> u'change_resourcebase_permissions', u'publish_resourcebase',
>>>>> u'change_layer_data', u'change_layer_style']}, u'groups': {u'anonymous':
>>>>> [u'download_resourcebase', u'view_resourcebase']}}
>>>>> On Tue, Nov 7, 2017 at 5:56 PM, Paolo Pasquali <
>>>>>> Sorry, maybe you asked for this:
>>>>>> $ python manage.py sync_geofence
>>>>>> Traceback (most recent call last):
>>>>>>   File "manage.py", line 11, in <module>
>>>>>>     execute_from_command_line(sys.argv)
>>>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>>>> line 354, in execute_from_command_line
>>>>>>     utility.execute()
>>>>>> line 346, in execute
>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>>>> line 394, in run_from_argv
>>>>>>     self.execute(*args, **cmd_options)
>>>>>> line 445, in execute
>>>>>>     output = self.handle(*args, **options)
>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/managem
>>>>>> ent/commands/sync_geofence.py", line 53, in handle
>>>>>>     print 'Synchronizing permissions for layer %s/%s: %s' % (count,
>>>>>> layers_count, layer.alternate)
>>>>>> AttributeError: 'Layer' object has no attribute 'alternate'
>>>>>> Paolo Pasquali
>>>>>> ITHACA
>>>>>> Information Technology for Humanitarian Assistance, Cooperation and
>>>>>> Action
>>>>>> via Pier Carlo Boggio, 61 - 10138 Torino - Italy
>>>>>> <https://maps.google.com/?q=via+Pier+Carlo+Boggio,+61+-%C2%A010138+Torino+-+Italy&entry=gmail&source=g>
>>>>>> Tel. +39 011 1975 1111 <+39%20011%201975%201111>
>>>>>> Fax +39 011 1975 1122 <+39%20011%201975%201122>
>>>>>> www.ithacaweb.org
>>>>>> On Tue, Nov 7, 2017 at 5:30 PM, Paolo Pasquali <
>>>>>>> Hi,
>>>>>>> No stack trace. It seems it does nothing.
>>>>>>> Thanks.
>>>>>>> On Tue, Nov 7, 2017 at 5:21 PM, Paolo Corti <pcorti at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi Paolo
>>>>>>>> Strange, it should work. Can you remove the try/except block and
>>>>>>>> send me again the stack trace?
>>>>>>>> thanks
>>>>>>>> p
>>>>>>>> On Tue, Nov 7, 2017 at 10:06 AM, Paolo Pasquali <
>>>>>>>>> Ciao Paolo.
>>>>>>>>> Actually I'm getting an error:
>>>>>>>>> ('Unexpected error:', <type 'exceptions.AttributeError'>)
>>>>>>>>> ges/django/core/management/__init__.py", line 354, in
>>>>>>>>>     utility.execute()
>>>>>>>>> ges/django/core/management/__init__.py", line 346, in execute
>>>>>>>>> ges/django/core/management/base.py", line 394, in run_from_argv
>>>>>>>>> ges/django/core/management/base.py", line 445, in execute
>>>>>>>>> -packages/geonode/base/management/commands/sync_geofence.py",
>>>>>>>>> line 58, in handle
>>>>>>>>>     print 'perm_spec is %s' % perm_spec
>>>>>>>>> UnboundLocalError: local variable 'perm_spec' referenced before
>>>>>>>>> assignment
>>>>>>>>> Thanks!
>>>>>>>>> P.
>>>>>>>>> On Tue, Nov 7, 2017 at 3:44 PM, Paolo Corti <pcorti at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Hi Paolo
>>>>>>>>>> while I am not sure why this is happening (it shouldn't), in
>>>>>>>>>> GeoNode master there is now a sync_geofence command which will fix things:
>>>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geono
>>>>>>>>>> de/geoserver/management/commands/sync_geofence.py
>>>>>>>>>> It should work for 2.6.x as well, in case not let me know
>>>>>>>>>> cheers
>>>>>>>>>> p
>>>>>>>>>> On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
>>>>>>>>>>> Dear all,
>>>>>>>>>>> I'm experiencing this problem with GeoNode 2.6.3. From some
>>>>>>>>>>> point on, every layer I upload does not appear in the GeoFence list.
>>>>>>>>>>> I've tried to edit and save permissions, restart Apache, Tomcat,
>>>>>>>>>>> run fixlayerpermission but with no result.
>>>>>>>>>>> This is not happening in my local installation that reflects the
>>>>>>>>>>> affected website.
>>>>>>>>>>> Is there some action I can take except upgrading GeoServer?
>>>>>>>>>>> Thanks.
>>>>>>>>>>> Best,
>>>>>>>>>>> Paolo
>>>>>>>>>>> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <
>>>>>>>>>>> alpacagis at gmail.com> wrote:
>>>>>>>>>>>> Dear list,
>>>>>>>>>>>> It seems that the problem with the permission is solved with
>>>>>>>>>>>> the upgrading of geoserver to 2.10 version
>>>>>>>>>>>> Thanks Alessio for your help
>>>>>>>>>>>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>>>>>>>> In that case you are correct. You need to double check that
>>>>>>>>>>>>> GeoFence access rules have been correctly set on GeoServer for the layer
>>>>>>>>>>>>> you are modifying.
>>>>>>>>>>>>> If you cannot find them or the rules are not correctly
>>>>>>>>>>>>> updated, it is possible that there is some communication issue between
>>>>>>>>>>>>> GeoNode and GeoServer.
>>>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>>>> Maybe try to do some tests and double check that the rules
>>>>>>>>>>>>> actually change.
>>>>>>>>>>>>> P.S.: do not use browser refresh on GeoFence Rules, but always
>>>>>>>>>>>>> click here
>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>> GeoServer Professional Services from the experts!
>>>>>>>>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> github <https://github.com/afabiani?tab=overview>
>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> Via di Montramito 3/A
>>>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>>>>>>>>>>> 55054  Massarosa
>>>>>>>>>>>>> (LU)
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>>>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>>>>>>>> mob:   +39 331 6233686 <(331)%20623-3686>
>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>>>>>>>> Le informazioni contenute in questo messaggio di posta
>>>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>>>>> The information in this message and/or attachments, is
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>>>>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <
>>>>>>>>>>>>>> Thanks  for your reply Alessio,
>>>>>>>>>>>>>> about the layer preview question, I am logged in with the
>>>>>>>>>>>>>> "SGI" user, that should be have the permission to see the layer.
>>>>>>>>>>>>>> Moreover, the user that I'm using, is part of the "Staff"
>>>>>>>>>>>>>> group, but I can't see the layer preview.
>>>>>>>>>>>>>> Where I am wrong?
>>>>>>>>>>>>>> [image: Immagine incorporata 1]
>>>>>>>>>>>>>> Really thanks
>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>>> 1) if you remove "Anyone" check the layer is no more
>>>>>>>>>>>>>>> publicly accessible. It will be visible only by logged-in users belonging
>>>>>>>>>>>>>>> to allowed groups.
>>>>>>>>>>>>>>> 2) you can either change the Javascript of the map composer
>>>>>>>>>>>>>>> or manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>>>>>>>>>>>> Denominators
>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>> 55054  Massarosa
>>>>>>>>>>>>>>> (LU)
>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <
>>>>>>>>>>>>>>>> Dear list,
>>>>>>>>>>>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>>>>>>>>>>>> 1- Layer permission issue:
>>>>>>>>>>>>>>>> When I change the permission: "who can view it" from Anyone
>>>>>>>>>>>>>>>> to a specific user/group, It works but the layer preview disappear, and I
>>>>>>>>>>>>>>>> am not more able to see the layer shape. Should I have to set something in
>>>>>>>>>>>>>>>> Django or Geoserver?
>>>>>>>>>>>>>>>> 2- Is it possible to fix a specific scale for the map view
>>>>>>>>>>>>>>>> in the map composer? e.g. I would see a map only at 1:250'000 (or at the
>>>>>>>>>>>>>>>> zoom level that is closest to 1:250'000...)
>>>>>>>>>>>>>>>> Thanks a lot
>>>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>> Paolo Corti
>>>>>>>>>> Geospatial software developer
>>>>>>>>>> web: http://www.paolocorti.net
>>>>>>>>>> twitter: @capooti
>>>>>>>>>> skype: capooti
>>>>>>>> Paolo Corti
>>>>>>>> twitter: @capooti
>>>>>>>> skype: capooti
>>>> Paolo Corti
>>>> twitter: @capooti
>>>> skype: capooti
> Simone
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/08ed4aa8/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/08ed4aa8/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/08ed4aa8/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/08ed4aa8/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/08ed4aa8/attachment-0007.png>
More information about the geonode-users mailing list
