[GeoNode-users] Problem uploading raster file
Simone Dalmasso simone.dalmasso at gmail.com
Thu Nov 9 01:42:27 PST 2017
Stefano, I tested on a new GeoNode installation and I can confirm the
issue, geoserver is unable to spot the srs. It looks a data issue, could
you try to reproject/resave it in a gis software and try again?
This is the gdalinfo output for info
PROJCS["ETRS_1989_LAEA",
    GEOGCS["GCS_ETRS_1989",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS_1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6258"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Lambert_Azimuthal_Equal_Area"],
    PARAMETER["latitude_of_center",52],
    PARAMETER["longitude_of_center",10],
    PARAMETER["false_easting",4321000],
    PARAMETER["false_northing",3210000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
2017-11-08 16:48 GMT+01:00 <Stefano.LUONI at ext.ec.europa.eu>:
> Hello,
> I currently have issues with GeoTiff raster files: after uploading from
> GeoNode, the layer page displays an empty map. Looking from GeoServer admin
> website, I can see the layer it's disabled, because no SRS is detected; the
> only way to enable the layer is to manually set SRS.
> After enabling the layer, this is visibile from GeoNode, but it is not
> centered in the map, like the bounds are not correctly computed; the layer
> preview from GeoServer is fine though.
> This is happening on a 2.6.3 installation (standard deployment), with
> GeoServer 2.9; I tried using both open-jdk and Oracle Java8 with the same
> result.
> The same raster file is uploaded correctly on a development installation
> (GeoNode 2.9, Geoserver 2.12).
> You can find an extraction of GeoSever log attached to this email; it
> contains several errors, like
> ERROR [geoserver.rest] - No such datastore: geonode,floodmapeu_rp200y
> ERROR [geoserver.rest] - No such coverage store: geonode,floodmapeu_rp200y
> ERROR [geoserver.rest] - No such wms store: geonode,floodmapeu_rp200y
> ERROR [geoserver.rest] - No such style: floodmapeu_rp200y
> ERROR [geoserver.ows] -
> org.geoserver.platform.ServiceException: Could not find layer
> geonode:floodmapeu_rp200y
> I guess something is wrong with my GeoServer installation, but I cannot
> say how.
> You may download the raster file from this link:
> https://drive.google.com/file/d/1u2iUD4Gf_QZKpjW0nAWNatbR6NxkU6Ni/view?
> usp=sharing
> Stefano Luoni
> External consultant for the European Commission (GFT Italia)
> European Commission
> Joint Research Centre – JRC.E.1
> Disaster Risk Management Unit
> Building 26b | Via E.Fermi 2749, I-21027 Ispra (VA) Italy, TP 266
> Tel: +39 033278 9451 <+39%200332%20789451>
> Email: stefano.luoni at ext.jrc.ec.europa.eu
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171109/a27f0686/attachment.html>
More information about the geonode-users mailing list
