[GeoNode-users] Problem uploading raster file
Stefano.LUONI at ext.ec.europa.eu Stefano.LUONI at ext.ec.europa.eu
Thu Nov 9 01:52:11 PST 2017
Thank you Simone,
we'll try to resave the file; the strange thing is that it works on my Geonode 2.9 development installation, so it might be that a most recent version of Geoserver can handle it as is.
Stefano
From: Simone Dalmasso [simone.dalmasso at gmail.com]
Sent: 09 November 2017 10:42
To: LUONI Stefano (JRC-ISPRA-EXT)
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Problem uploading raster file
Stefano, I tested on a new GeoNode installation and I can confirm the issue, geoserver is unable to spot the srs. It looks a data issue, could you try to reproject/resave it in a gis software and try again?
This is the gdalinfo output for info
PROJCS["ETRS_1989_LAEA",
    GEOGCS["GCS_ETRS_1989",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS_1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6258"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Lambert_Azimuthal_Equal_Area"],
    PARAMETER["latitude_of_center",52],
    PARAMETER["longitude_of_center",10],
    PARAMETER["false_easting",4321000],
    PARAMETER["false_northing",3210000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
2017-11-08 16:48 GMT+01:00 <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>>:
Hello,
I currently have issues with GeoTiff raster files: after uploading from GeoNode, the layer page displays an empty map. Looking from GeoServer admin website, I can see the layer it's disabled, because no SRS is detected; the only way to enable the layer is to manually set SRS.
After enabling the layer, this is visibile from GeoNode, but it is not centered in the map, like the bounds are not correctly computed; the layer preview from GeoServer is fine though.
This is happening on a 2.6.3 installation (standard deployment), with GeoServer 2.9; I tried using both open-jdk and Oracle Java8 with the same result.
The same raster file is uploaded correctly on a development installation (GeoNode 2.9, Geoserver 2.12).
You can find an extraction of GeoSever log attached to this email; it contains several errors, like
ERROR [geoserver.rest] - No such datastore: geonode,floodmapeu_rp200y
ERROR [geoserver.rest] - No such coverage store: geonode,floodmapeu_rp200y
ERROR [geoserver.rest] - No such wms store: geonode,floodmapeu_rp200y
ERROR [geoserver.rest] - No such style: floodmapeu_rp200y
ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer geonode:floodmapeu_rp200y
I guess something is wrong with my GeoServer installation, but I cannot say how.
You may download the raster file from this link: https://drive.google.com/file/d/1u2iUD4Gf_QZKpjW0nAWNatbR6NxkU6Ni/view?usp=sharing
Stefano Luoni
External consultant for the European Commission (GFT Italia)
European Commission
Joint Research Centre – JRC.E.1
Disaster Risk Management Unit
Building 26b | Via E.Fermi 2749, I-21027 Ispra (VA) Italy, TP 266
Tel: +39 033278 9451<tel:+39%200332%20789451>
Email: stefano.luoni at ext.jrc.ec.europa.eu<mailto:stefano.luoni at ext.jrc.ec.europa.eu>
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171109/4de6fe1e/attachment.html>
More information about the geonode-users mailing list
