[GeoNode-users] Geonode Updatelayers Error
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Nov 15 08:37:47 PST 2017
It seems like it is missing "http://" before the ip address.
How did you setup SITE_URL?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Nov 15, 2017 at 11:51 AM, Jeffy John Tomarong <jeffytoms at gmail.com>
wrote:
> Hi good fellas,
> I hope you could spare a portion of your time on this.
> I am reverting the IP of our geonode instance back to a local/private IP.
> Then I restarted apache and tomcat. The process seemed to have completed
> successfully.
> However, when I try to do a geonode updatelayer, an error comes out as
> shown below:
> jjqt at GeoNode:~$ sudo geonode updatelayers
> Stopping process because --ignore-errors was not set and an error was
> found.
> Exception: ('Failed to process non_nipas', RelativeURIError('Only absolute
> URIs are allowed. uri = 172.16.136.50/geoserver/wms/
> reflect?layers=geonode:non_nipas&width=200&height=150&format=image/png8
> <https://l.facebook.com/l.php?u=http%3A%2F%2F172.16.136.50%2Fgeoserver%2Fwms%2Freflect%3Flayers%3Dgeonode%253Anon_nipas%26width%3D200%26height%3D150%26format%3Dimage%252Fpng8&h=ATMe7M7ei4dgp8JtrBPhY5EHDy97YuhgsGOAMJ5GQR30pbPvEzAd-BIeTcy8emCD72RzidtlVRdg9S-veiGQpdIm5eWVLvvozEcKKw6jk8akhtQqAt0kA8fZlxJNPQqTeaPsRiCTYA>
> I also changed the IP in the Global setting in the geoserver to the
> private/local IP.
> In effect, the layers do now show in the map and I also cannot download
> the layers via the geonode site because the URL points back to the old
> public URL.
> Your help would be highly appreciated. Thank you very much.
> Best,
> Jeffy
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171115/7ba90ddf/attachment-0001.html>
More information about the geonode-users mailing list
