[GeoNode-users] how to update all the thumbnails
Paolo Corti pcorti at gmail.com
Thu Nov 16 07:27:44 PST 2017
Can you correctly access the layer which is causing the problem in GeoNode?
Try to updatelayers just for one layer to see if it works.
By the way, also saving the layer metadata will update the thumbnail
(at least in master)
p
On Thu, Nov 16, 2017 at 10:18 AM, Federico Gianoli <alpacagis at gmail.com> wrote:
> Thanks Paolo,
> I ran "geonode updatelayers" without results.
> The command give me the following message, should I give another command
> before to run updatelayers?
> # geonode updatelayers
> Inspecting the available layers in GeoServer ...
> Traceback (most recent call last):
>   File "/usr/bin/django-admin", line 21, in <module>
>     management.execute_from_command_line()
>   File
> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
> 354, in execute_from_command_line
>     utility.execute()
>   File
> 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
> line 445, in execute
>     output = self.handle(*args, **options)
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
> line 119, in handle
>     execute_signals=True)
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
> 439, in gs_slurp
>     resources = [k for k in resources if k.enabled in ["true", True]]
>   File "/usr/lib/python2.7/dist-packages/geoserver/support.py", line 67, in
> getter
>     self.fetch()
>   File "/usr/lib/python2.7/dist-packages/geoserver/support.py", line 176, in
> fetch
>     self.dom = self.catalog.get_xml(self.href)
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 214, in
> get_xml
>     return parse_or_raise(content)
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 205, in
> parse_or_raise
>     raise Exception(msg, e)
> Exception: ('GeoServer gave non-XML response for [GET
> http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/datastore/featuretypes/salah_aldin_wells_iraq_unesco_ll_point.xml]:
> <featureType>\n  <name>salah_aldin_wells_iraq_unesco_ll_point</name>\n
> <nativeName>salah_aldin_wells_iraq_unesco_ll_point</nativeName>\n
> <namespace>\n    <name>geonode</name>\n    <atom:link
> xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate"
> href="http://localhost:8080/geoserver/rest/namespaces/geonode.xml"
> type="application/xml"/>\n  </namespace>\n
> <title>salah_aldin_wells_iraq_unesco_ll_point</title>\n  <keywords>\n
> <string>features</string>\n
> <string>salah_aldin_wells_iraq_unesco_ll_point</string>\n  </keywords>\n
> <nativeCRS>GEOGCS["WGS 84", \n  DATUM["World Geodetic System
> 1984", \n    SPHEROID["WGS 84", 6378137.0, 298.257223563,
> AUTHORITY["EPSG","7030"]], \n
> AUTHORITY["EPSG","6326"]], \n
> PRIMEM["Greenwich", 0.0,
> AUTHORITY["EPSG","8901"]], \n  UNIT["degree",
> 0.017453292519943295], \n  AXIS["Geodetic longitude", EAST], \n
> AXIS["Geodetic latitude", NORTH], \n
> AUTHORITY["EPSG","4326"]]</nativeCRS>\n
> <srs>EPSG:4326</srs>\n  <nativeBoundingBox>\n
> <minx>43.0292000000001</minx>\n    <maxx>44.8967</maxx>\n
> <miny>33.7583000000001</miny>\n    <maxy>35.2347000000001</maxy>\n
> <crs>EPSG:4326</crs>\n  </nativeBoundingBox>\n  <latLonBoundingBox>\n
> <crs>GEOGCS["WGS84(DD)", \n  DATUM["WGS84", \n
> SPHEROID["WGS84", 6378137.0, 298.257223563]], \n
> PRIMEM["Greenwich", 0.0], \n  UNIT["degree",
> AXIS["Geodetic latitude", NORTH]]</crs>\n  </latLonBoundingBox>\n
> <projectionPolicy>FORCE_DECLARED</projectionPolicy>\n
> <enabled>true</enabled>\n  <store class="dataStore">\n
> <name>geonode:datastore</name>\n    <atom:link
> href="http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/datastore.xml"
> type="application/xml"/>\n  </store>\n  <maxFeatures>0</maxFeatures>\n
> <numDecimals>0</numDecimals>\n
> <overridingServiceSRS>false</overridingServiceSRS>\n
> <skipNumberMatched>false</skipNumberMatched>\n
> <circularArcPresent>false</circularArcPresent>\n  <attributes',
> ParseError(ExpatError('unclosed token: line 54, column 2',),))
> 2017-11-16 15:48 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> Hi Federico
>> updatelayers will regenerate thumbnails for layers.
>> Unfortunately there isn't a solution for maps right now. You can only
>> manually regenerate them by using the "Set thumbnail" button
>> cheers
>> p
>> On Thu, Nov 16, 2017 at 7:15 AM, Federico Gianoli <alpacagis at gmail.com>
>> wrote:
>> > Hi,
>> > I have, maybe a stupid question.
>> > I am using GeoNode 2.6.3.
>> > Is there any way to regenerate all the layers and maps thumbnails?
>> > Thanks
>> > Federico
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
