[GeoNode-users] Missing columns after migrating data from Geonode 2.4 to 2.6
Israel López asralf at gmail.com
Thu Oct 19 01:51:59 PDT 2017
Done it.
Good day
2017-10-19 2:33 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Ok thanks a lot, then we need to create the missing migration. Could you
> please open a ticket on this?
> best
> 2017-10-19 2:06 GMT+02:00 Israel López <asralf at gmail.com>:
>> Hi everybody, just in this moment I found the same error trying to delete
>> some layers.
>> Looking around I found that the file migration is missing for the Upload
>> app, it only has the
>> 24_initial.py, but this file includes the creation of the new fields, the
>> right way have to be two files,
>> the initial24.py and the 24_to_26.py as the other apps.
>> So as we run initial--fake, the tables are not created, the solution for
>> me was to delete the old
>> upload and upload_file tables (I don't know why are empty), delete the
>> fake migration in the
>> django_migrations table and run the migrate comand for upload, and thats
>> it, the tables were
>> created.
>> Hope this helps somebody. Greetings from Mexico.
>> 2017-10-18 13:39 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Thanks all for the answers and feedbacks, we should investigate why
>>> "migrate" did not add those columns. It should be its job.
>>> Best
>>> 2017-10-18 20:10 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
>>>> Thanks Annalisa, I ended up going that route too. I added those
>>>> columns and removed the not null constraint on last_login on
>>>> people_profile.
>>>> Eric
>>>> On Wed, Oct 18, 2017 at 2:49 AM, Annalisa Schiavon
>>>> <annalisa.schiavon at gmail.com> wrote:
>>>> > Dear Eric,
>>>> > on 3 July I found a similar issue: upload_upload table hasn't 4
>>>> attribute:
>>>> > mosaic_time_regex,
>>>> > mosaic_time_value, mosaic_elev_regex and mosaic_elev_value.
>>>> > I added those columns and solved my problem.
>>>> > Regards,
>>>> > Annalisa
>>>> > 2017-10-16 16:24 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
>>>> >> Hi all,
>>>> >> We're trying to upgrade from GeoNode 2.4 to 2.6. I have a new VM with
>>>> >> Geonode 2.6 installed on Ubuntu 16.04 from the PPA. I dumped the
>>>> >> postgres data from our 2.4 server and created new DBs on the Geonode
>>>> >> 2.6 instance and updated settings.py to point to the geonode 2.4
>>>> >> geonode and geonode_data DBs.
>>>> >> Following the suggestion in this thread
>>>> >> (http://osgeo-org.1560.x6.nabble.com/Help-for-migrate-data-f
>>>> rom-2-4-to-2-6-td5323208.html),
>>>> >> I ran geonode migrate --fake-initial and everything appears to have
>>>> >> worked, however if I try to create a new account from the geonode
>>>> >> registration page, or delete an existing account from the admin panel
>>>> >> I get some errors.
>>>> >> Trying to create a new account results in the following error:
>>>> >> IntegrityError: null value in column "last_login" violates not-null
>>>> >> constraint
>>>> >>  Trying to delete an account results in the following error:
>>>> >> ProgrammingError: column upload_upload.mosaic_time_regex does not
>>>> exist
>>>> >> It looks like the migration didn't run correctly. If anyone has
>>>> advice
>>>> >> on how fix/work a round this issue it would be greatly appreciated!
>>>> >> We'll be reloading the data anyway so our main concern is just
>>>> >> migrating the accounts and groups.
>>>> >> If it helps, here is the comparison of the geonode 2.4 and 2.6
>>>> schemas
>>>> >> for the upload_upload table. The mosaic* columns are missing from the
>>>> >> 2.4 database that was migrated:
>>>> >> geonode 2.4 database (after running migrate):
>>>> >> geonode24=# \d upload_upload
>>>> >>                                     Table "public.upload_upload"
>>>> >>    Column   |           Type           |
>>>>  Modifiers
>>>> >>  id         | integer                  | not null default
>>>> >> nextval('upload_upload_id_seq'::regclass)
>>>> >>  import_id  | bigint                   |
>>>> >>  user_id    | integer                  |
>>>> >>  state      | character varying(16)    | not null
>>>> >>  date       | timestamp with time zone | not null
>>>> >>  layer_id   | integer                  |
>>>> >>  upload_dir | character varying(100)   |
>>>> >>  name       | character varying(64)    |
>>>> >>  complete   | boolean                  | not null
>>>> >>  session    | text                     |
>>>> >>  metadata   | text                     |
>>>> >> Indexes:
>>>> >>     "upload_upload_pkey" PRIMARY KEY, btree (id)
>>>> >>     "upload_upload_layer_id" btree (layer_id)
>>>> >>     "upload_upload_user_id" btree (user_id)
>>>> >> Foreign-key constraints:
>>>> >>     "upload_upload_layer_id_fkey" FOREIGN KEY (layer_id) REFERENCES
>>>> >> layers_layer(resourcebase_ptr_id) DEFERRABLE INITIALLY DEFERRED
>>>> >>     "upload_upload_user_id_fkey" FOREIGN KEY (user_id) REFERENCES
>>>> >> people_profile(id) DEFERRABLE INITIALLY DEFERRED
>>>> >> Referenced by:
>>>> >>     TABLE "upload_uploadfile" CONSTRAINT
>>>> >> "upload_uploadfile_upload_id_fkey" FOREIGN KEY (upload_id)
>>>> REFERENCES
>>>> >> upload_upload(id) DEFERRABLE INITIALLY DEFERRED
>>>> >> Geonode 2.6 database (from initial install):
>>>> >> geonode=# \d upload_upload
>>>> >>       Column       |           Type           |
>>>> >>  Modifiers
>>>> >>  session           | text                     |
>>>> >>  metadata          | text                     |
>>>> >>  mosaic_time_regex | character varying(128)   |
>>>> >>  mosaic_time_value | character varying(128)   |
>>>> >>  mosaic_elev_regex | character varying(128)   |
>>>> >>  mosaic_elev_value | character varying(128)   |
>>>> >>  user_id           | integer                  |
>>>> >> Indexes:
>>>> >>     "upload_upload_7a39a38c" btree (layer_id)
>>>> >>     "upload_upload_e8701ad4" btree (user_id)
>>>> >>     "u_layer_id_6346de911330a880_fk_layers_layer_resourcebase_p
>>>> tr_id"
>>>> >> FOREIGN KEY (layer_id) REFERENCES layers_layer(resourcebase_ptr_id)
>>>> >>     "upload_upload_user_id_7fad116c8478bf31_fk_people_profile_id"
>>>> >> FOREIGN KEY (user_id) REFERENCES people_profile(id) DEFERRABLE
>>>> >> INITIALLY DEFERRED
>>>> >> Referenced by:
>>>> >> "upload_uploadfil_upload_id_21ef448d17dd4b6b_fk_upload_upload_id"
>>>> >> FOREIGN KEY (upload_id) REFERENCES upload_upload(id) DEFERRABLE
>>>> >> INITIALLY DEFERRED
>>>> >> Thanks!
>>>> >> Eric
>>>> >> _______________________________________________
>>>> >> geonode-users mailing list
>>>> >> geonode-users at lists.osgeo.org
>>>> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171019/a78b6ab3/attachment.html>
More information about the geonode-users mailing list
