[GeoNode-users] list index out of range
Israel López asralf at gmail.com
Mon Oct 23 17:40:24 PDT 2017
I found this problem recently, and just in case somebody found it again...
My problem was a mismatch in the Database, this code search for the layer
style url
and split it finding the word 'geoserver/', but if for any reason the
string isn't find it,
you'll have the error.
Posible solution: check the integrity of your database or the sld url
contains the string.
2015-12-16 11:18 GMT-06:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi,
> in a fresh geonode installation, from git (version *2.4.dev20151216081626)
> *on ubuntu 14.04,
> once I upload without error a shp file I see it on the layers list. By
> click on the layer uploaded
> I got the page error, which start as:
> IndexError at /layers/geonode:reg2001_s_wgs84utm33_1
> Request Method: GET
> Request URL: http://my_name_server/layers/geonode:reg2001_s_wgs84utm33_1
> Django Version: 1.6.11
> Exception Type: IndexError
> Exception Value:
> Exception Location: /dati/geonode/geonode/layers/models.py in
> absolute_url, line 68
> Python Executable: /usr/bin/python
> Python Version: 2.7.6
> Python Path:
> ['/dati/geonode/.venvs/geonode/lib/python2.7/site-packages',
>  '/dati/geonode',
>  '/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PILcompat',
>  '/home/eugenio']
> Server time: Wed, 16 Dec 2015 11:14:34 -0600
> Error during template rendering In template /dati/geonode/geonode/layers/
> templates/layers/layer_detail.html, error at line *322*
> the line 322 is:
> <a href="{{ GEOSERVER_BASE_URL }}{{ style.absolute_url }}" >{{
> style.sld_title }}</a>
> in apache error.log I got:
> [Wed Dec 16 11:14:34.197809 2015] [:error] [pid 25667] Internal Server
> Error: /layers/geonode:reg2001_s_wgs84utm33_1
> [Wed Dec 16 11:14:34.197933 2015] [:error] [pid 25667] Traceback (most
> recent call last):
> [Wed Dec 16 11:14:34.197939 2015] [:error] [pid 25667]   File
> "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py",
> line 112, in get_response
> [Wed Dec 16 11:14:34.197943 2015] [:error] [pid 25667]     response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Wed Dec 16 11:14:34.197946 2015] [:error] [pid 25667]   File
> "/dati/geonode/geonode/layers/views.py", line 294, in layer_detail
> [Wed Dec 16 11:14:34.197949 2015] [:error] [pid 25667]     return
> render_to_response(template, RequestContext(request, context_dict))
> [Wed Dec 16 11:14:34.197952 2015] [:error] [pid 25667]   File
> "/usr/local/lib/python2.7/dist-packages/django/shortcuts/__init__.py",
> line 29, in render_to_response
> [Wed Dec 16 11:14:34.197956 2015] [:error] [pid 25667]     return
> HttpResponse(loader.render_to_string(*args, **kwargs),
> **httpresponse_kwargs)
> [Wed Dec 16 11:14:34.197959 2015] [:error] [pid 25667]   File
> "/usr/local/lib/python2.7/dist-packages/django/template/loader.py", line
> 164, in render_to_string
> [Wed Dec 16 11:14:34.197962 2015] [:error] [pid 25667]     return
> t.render(Context(dictionary))
> [Wed Dec 16 11:14:34.197964 2015] [:error] [pid 25667]   File
> "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line
> 140, in render
> [Wed Dec 16 11:14:34.197967 2015] [:error] [pid 25667]     return
> self._render(context)
> [Wed Dec 16 11:14:34.197970 2015] [:error] [pid 25667]   File
> 134, in _render
> [Wed Dec 16 11:14:34.197973 2015] [:error] [pid 25667]     return
> self.nodelist.render(context)
> [Wed Dec 16 11:14:34.198001 2015] [:error] [pid 25667]   File
> 840, in render
> [Wed Dec 16 11:14:34.198007 2015] [:error] [pid 25667]     bit =
> self.render_node(node, context)
> [Wed Dec 16 11:14:34.198010 2015] [:error] [pid 25667]   File
> "/usr/local/lib/python2.7/dist-packages/django/template/debug.py", line
> 78, in render_node
> [Wed Dec 16 11:14:34.198013 2015] [:error] [pid 25667]     return
> node.render(context)
> [Wed Dec 16 11:14:34.198015 2015] [:error] [pid 25667]   File
> "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py",
> line 123, in render
> [Wed Dec 16 11:14:34.198018 2015] [:error] [pid 25667]     return
> compiled_parent._render(context)
> [Wed Dec 16 11:14:34.198021 2015] [:error] [pid 25667]   File
> 134, in _render
> [Wed Dec 16 11:14:34.198024 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198027 2015] [:error] [pid 25667]   File
> 840, in render
> [Wed Dec 16 11:14:34.198029 2015] [:error] [pid 25667]     bit =
> [Wed Dec 16 11:14:34.198032 2015] [:error] [pid 25667]   File
> 78, in render_node
> [Wed Dec 16 11:14:34.198035 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198037 2015] [:error] [pid 25667]   File
> line 123, in render
> [Wed Dec 16 11:14:34.198040 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198048 2015] [:error] [pid 25667]   File
> 134, in _render
> [Wed Dec 16 11:14:34.198051 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198054 2015] [:error] [pid 25667]   File
> 840, in render
> [Wed Dec 16 11:14:34.198057 2015] [:error] [pid 25667]     bit =
> [Wed Dec 16 11:14:34.198059 2015] [:error] [pid 25667]   File
> 78, in render_node
> [Wed Dec 16 11:14:34.198062 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198065 2015] [:error] [pid 25667]   File
> line 123, in render
> [Wed Dec 16 11:14:34.198097 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198159 2015] [:error] [pid 25667]   File
> 134, in _render
> [Wed Dec 16 11:14:34.198170 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198213 2015] [:error] [pid 25667]   File
> 840, in render
> [Wed Dec 16 11:14:34.198231 2015] [:error] [pid 25667]     bit =
> [Wed Dec 16 11:14:34.198250 2015] [:error] [pid 25667]   File
> 78, in render_node
> [Wed Dec 16 11:14:34.198263 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198276 2015] [:error] [pid 25667]   File
> line 62, in render
> [Wed Dec 16 11:14:34.198289 2015] [:error] [pid 25667]     result =
> block.nodelist.render(context)
> [Wed Dec 16 11:14:34.198315 2015] [:error] [pid 25667]   File
> 840, in render
> [Wed Dec 16 11:14:34.198330 2015] [:error] [pid 25667]     bit =
> [Wed Dec 16 11:14:34.198342 2015] [:error] [pid 25667]   File
> 78, in render_node
> [Wed Dec 16 11:14:34.198414 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198429 2015] [:error] [pid 25667]   File
> line 62, in render
> [Wed Dec 16 11:14:34.198442 2015] [:error] [pid 25667]     result =
> [Wed Dec 16 11:14:34.198455 2015] [:error] [pid 25667]   File
> 840, in render
> [Wed Dec 16 11:14:34.198467 2015] [:error] [pid 25667]     bit =
> [Wed Dec 16 11:14:34.198480 2015] [:error] [pid 25667]   File
> 78, in render_node
> [Wed Dec 16 11:14:34.198493 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198506 2015] [:error] [pid 25667]   File
> "/usr/local/lib/python2.7/dist-packages/django/template/defaulttags.py",
> line 305, in render
> [Wed Dec 16 11:14:34.198518 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198531 2015] [:error] [pid 25667]   File
> 840, in render
> [Wed Dec 16 11:14:34.198544 2015] [:error] [pid 25667]     bit =
> [Wed Dec 16 11:14:34.198556 2015] [:error] [pid 25667]   File
> 78, in render_node
> [Wed Dec 16 11:14:34.198569 2015] [:error] [pid 25667]     return
> [Wed Dec 16 11:14:34.198582 2015] [:error] [pid 25667]   File
> line 196, in render
> [Wed Dec 16 11:14:34.198594 2015] [:error] [pid 25667]
> nodelist.append(node.render(context))
> [Wed Dec 16 11:14:34.198607 2015] [:error] [pid 25667]   File
> 88, in render
> [Wed Dec 16 11:14:34.198620 2015] [:error] [pid 25667]     output =
> self.filter_expression.resolve(context)
> [Wed Dec 16 11:14:34.198632 2015] [:error] [pid 25667]   File
> 585, in resolve
> [Wed Dec 16 11:14:34.198645 2015] [:error] [pid 25667]     obj =
> self.var.resolve(context)
> [Wed Dec 16 11:14:34.198658 2015] [:error] [pid 25667]   File
> 735, in resolve
> [Wed Dec 16 11:14:34.198671 2015] [:error] [pid 25667]     value =
> self._resolve_lookup(context)
> [Wed Dec 16 11:14:34.198683 2015] [:error] [pid 25667]   File
> 789, in _resolve_lookup
> [Wed Dec 16 11:14:34.198696 2015] [:error] [pid 25667]     current =
> current()
> [Wed Dec 16 11:14:34.198709 2015] [:error] [pid 25667]   File
> "/dati/geonode/geonode/layers/models.py", line 68, in absolute_url
> [Wed Dec 16 11:14:34.198721 2015] [:error] [pid 25667]     return
> self.sld_url.split('geoserver/', 1)[1]
> [Wed Dec 16 11:14:34.198734 2015] [:error] [pid 25667] IndexError: list
> index out of range
> what does it means? Did I configure something wrong? or is a known issue?
> best regards
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171023/e74e529b/attachment.html>
More information about the geonode-users mailing list
