[GeoNode-users] Initial GeoNode account...
Chris Jackson webturtles at gmail.com
Fri Sep 1 03:19:06 PDT 2017
Thanks, helps to load the virtual env first!  Interestingly an admin user
already exists.  I did create an admin account during installation at the
Geoserver step.  Account works fine in Geoserver console, but same details
not liked by GeoNode. Is that expected behaviour?
Thanks
Chris
On 1 September 2017 at 08:52, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, "geonode createsuperuser" (or python manage.py createsuperuser) is
> your command.
> Hope it helps
> 2017-08-31 22:23 GMT+02:00 Chris Jackson <webturtles at gmail.com>:
>> Hi all
>> I have managed to install GeoNode 2.6 successfully on a clean Azure W2016
>> VM.  I can log into Geoserver and can see the GeoNode homepage with sample
>> datasets.  Admittedly the installer is not quite 100% there, I had to
>> manually add most the environment variables.
>> Question I have is how do you set up the initial GeoNode admin user
>> account, as it isn't covered as part of the install, and the Windows Binary
>> Installer instructions don't cover it either.  I am guessing it is a
>> command line process?
>> Thanks
>> Chris
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170901/c3e273b6/attachment.html>
More information about the geonode-users mailing list
