[GeoNode-users] Initial GeoNode account...
Simone Dalmasso simone.dalmasso at gmail.com
Fri Sep 1 04:09:42 PDT 2017
The admin of geoserver is only for internal use between geonode and
geoserver. Once you log into geonode with your generated superuser then
you'll be also logged in geoserver by pressing the login button once in the
geoserver home page.
2017-09-01 12:19 GMT+02:00 Chris Jackson <webturtles at gmail.com>:
> Thanks, helps to load the virtual env first!  Interestingly an admin user
> already exists.  I did create an admin account during installation at the
> Geoserver step.  Account works fine in Geoserver console, but same details
> not liked by GeoNode. Is that expected behaviour?
> Thanks
> Chris
> On 1 September 2017 at 08:52, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
>> Hi, "geonode createsuperuser" (or python manage.py createsuperuser) is
>> your command.
>> Hope it helps
>> 2017-08-31 22:23 GMT+02:00 Chris Jackson <webturtles at gmail.com>:
>>> Hi all
>>> I have managed to install GeoNode 2.6 successfully on a clean Azure
>>> W2016 VM.  I can log into Geoserver and can see the GeoNode homepage with
>>> sample datasets.  Admittedly the installer is not quite 100% there, I had
>>> to manually add most the environment variables.
>>> Question I have is how do you set up the initial GeoNode admin user
>>> account, as it isn't covered as part of the install, and the Windows Binary
>>> Installer instructions don't cover it either.  I am guessing it is a
>>> command line process?
>>> Thanks
>>> Chris
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170901/234ab1bb/attachment.html>
More information about the geonode-users mailing list
