[GeoNode-users] Error on Restore: [Errno 2] No such file or directory: '/tmp/restore/2017-08-23_141606/static_dirs/media'
Ariel Neri ariel.neriw at gmail.com
Fri Sep 1 13:10:48 PDT 2017
Hi all, I´ve updated to Geonode 2.6.3. Today I did a restore to a previous
backup file and got this error. The backup was made in 2.6.2 with no error
messages. The result in GeoNode is an empty GeoServer. No layers,
documents, maps, services and no admin user (or any user). I had also
backups of the Postgresql databases, so i did a restore on "geonode" and
"geonode_data" and now i can access with admin user and all layers, docs,
etc. are back in GeoNode. But when i upload a new layer or doc i get this:
UnicodeEncodeError at /layers/upload 'ascii' codec can't encode character
u'\xf3' in position 22:
is this a mis-configuration on my geonode?
Thanks
error on restore:
OSError at /admin/base/backup/
Request Method: POST
Request URL: http://192.168.0.56/admin/base/backup/
Django Version: 1.8.7
Exception Type: OSError
Exception Value:
Exception Location:
/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py
in copy_tree, line 203
Python Executable: /usr/bin/python
Python Version: 2.7.12
Python Path:
['/home/geonode/my_geonode',
 '/usr/lib/python2.7',
 '/usr/lib/python2.7/plat-x86_64-linux-gnu',
 '/usr/lib/python2.7/lib-tk',
 '/usr/lib/python2.7/lib-old',
 '/usr/lib/python2.7/lib-dynload',
 '/usr/local/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages/PILcompat',
 '/var/www',
 '/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/lib']
Server time: Vie, 1 Sep 2017 14:48:28 -0500
Traceback:File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py"
in get_response  132.                     response =
wrapped_callback(request, *callback_args, **callback_kwargs)File
"/usr/local/lib/python2.7/dist-packages/django/contrib/admin/options.py"
in wrapper  618.                 return
self.admin_site.admin_view(view)(*args, **kwargs)File
"/usr/local/lib/python2.7/dist-packages/django/utils/decorators.py" in
_wrapped_view  110.                     response = view_func(request,
"/usr/local/lib/python2.7/dist-packages/django/views/decorators/cache.py"
in _wrapped_view_func  57.         response = view_func(request,
"/usr/local/lib/python2.7/dist-packages/django/contrib/admin/sites.py"
in inner  233.             return view(request, *args, **kwargs)File
_wrapper  34.             return bound_func(*args, **kwargs)File
bound_func  30.                 return func.__get__(self,
type(self))(*args2, **kwargs2)File
in changelist_view  1592.                 response =
self.response_action(request, queryset=cl.get_queryset(request))File
in response_action  1335.             response = func(self, request,
queryset)File "/usr/local/lib/python2.7/dist-packages/geonode/base/admin.py"
in restore  99.                     call_command('restore',
force_exec=True, backup_file=str(siteObj.location).strip(),
stdout=out)File
"/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py"
in call_command  120.     return command.execute(*args,
**defaults)File
"/usr/local/lib/python2.7/dist-packages/django/core/management/base.py"
in execute  445.             output = self.handle(*args,
**options)File "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/restore.py"
in handle  287.
static_files_folder)File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/helpers.py"
in copy_tree  203.     for item in os.listdir(src):Exception Type:
OSError at /admin/base/backup/Exception Value: [Errno 2] No such file
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170901/ce3f15ba/attachment.html>
More information about the geonode-users mailing list
