[GeoNode-users] Poor performance GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Sep 8 01:06:00 PDT 2017
... adding to the previous email, it is also possible that somehow the HTTP
server and/or network configuration cause a delay. Sometimes requests are
slow simply because they are waiting for some timeout to expire. Tipically
a DNS or proxy issue.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Sep 8, 2017 at 10:04 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> From the video it looks like the issue is on GeoServer side.
> There could be many reasons for that, starting from the type of data (in
> the example I see you are asking vectorial datasets), how they are stored
> (shapefiles or DB), connections available and memory of the DB, complexity
> of styles (in this case look quite simple, unless you have a lot of rules),
> cache enabled or not (in this case it seems like the cache is disabled).
> If you feel comfortable you can contact me privately and share with me
> passwords for the instance so I can take a first look at the settings. From
> the informations I have right I cannot say much more than this currently.
> Regards,
> Alessio Fabiani
> http://goo.gl/it488V for more information.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax:     +39 0584 1660272 <0584%20166%200272>
> mob:   +39 331 6233686 <331%20623%203686>
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Fri, Sep 8, 2017 at 9:11 AM, Ana Boljevic <ana.boljevic at cedis.me>
> wrote:
>> Hi Alessio,
>> Please receive screen video recording link, so you can see by yourself
>> what do we mean by "Poor Performance".
>> https://www.dropbox.com/s/2ai2n8764p1ny9n/2017-09-08-08-38-33.flv?dl=0
>> This recording was taken during of heavy map rendering of 4 clients. We
>> have 144 vector layers and 2 external WMS layers (behaviour is the same
>> when we don't use WMS layers. In video link, we have used only local vector
>> layers, not external WMS layers). We are not experienced enough to know
>> what does cause the issue (GeoNode or GeoServer).
>> Please reveive one typical kml layer in the attachment.
>> Regards,
>> Ana Boljevic
>> *From:* Alessio Fabiani [alessio.fabiani at geo-solutions.it]
>> *Sent:* Thursday, September 07, 2017 4:21 PM
>> *To:* Ana Boljevic
>> *Cc:* John Jediny; Angelos Tzotsos; geonode-users at lists.osgeo.org
>> *Subject:* Re: [GeoNode-users] Poor performance GeoNode
>> Can you please better explain what you mean with "Map Performance"
>> exactly?
>> Getting the list of layers or rendering the map?
>> Also, how many layers you have and which type (vectorial / raster) ?
>> Are you able to identify performance issues? Those are on GeoNode or
>> GeoServer?
>> In the first case it is certainly an issue of your HTTP Server
>> configuration (and most probably the proxy module), in the second case it
>> could be an issue of data not correctly processed.
>> Regards,
>> Alessio Fabiani
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> On Thu, Sep 7, 2017 at 8:54 AM, Ana Boljevic <ana.boljevic at cedis.me>
>> wrote:
>>> Hi Angelos and John,
>>> Let me explain one more time, our performance issue. We have done fresh
>>> Geonode 2.6.2 installation (standard deployment), give VM 24GB RAM and 12
>>> CPU. After installation, we have done:
>>> 1) Replace OpenJVM with OracleJVM
>>> 2) We've increased the JVM memory by adding into /etc/default/tomcat7
>>> JAVA_OPTS="-Xmx12288M -Xms12288M -XX:MaxPermSize=1024M
>>> -XX:CompileCommand=exclude,net/sf/saxon/event/ReceivingConte
>>> ntHandler.startEvent"
>>> 3) Enable Native JAI and Native JAI ImageIO
>>> 4) Enable Tile caching into External PostgreSQL database
>>> Additionally, we have tried the following:
>>> 1) In /etc/tomcat7/server.xml added maxThreads="50":
>>>   <Connector port="8080" protocol="HTTP/1.1"
>>>                connectionTimeout="20000"
>>>                URIEncoding="UTF-8"
>>>                redirectPort="8443" maxThreads="50"/>
>>> 2) In /etc/apache2/mods-enabled/mpm_event.conf
>>> try to change conf parameters with no results:
>>> <IfModule mpm_event_module>
>>>         StartServers                     2
>>>         MinSpareThreads          25
>>>         MaxSpareThreads          75
>>>         ThreadLimit                      64
>>>         ThreadsPerChild          25
>>>         MaxRequestWorkers         150
>>>         MaxConnectionsPerChild   0
>>> </IfModule>
>>> Still, when 4-5 clients try to render maps, performance radically
>>> decrease and geonode become unresponsive.
>>> Do you have any idea how to increse performance ?
>>> Best regards,
>>> Ana Boljevic
>>> *From:* John Jediny [john.jediny at gmail.com]
>>> *Sent:* Saturday, September 02, 2017 3:32 AM
>>> *To:* Angelos Tzotsos
>>> *Cc:* Ana Boljevic; geonode-users at lists.osgeo.org
>>> apache2 mod_wsgi needs tuning. Add workers and up memory limits per
>>> worker
>>> On Fri, Sep 1, 2017 at 3:56 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
>>> wrote:
>>>> You need to add more workers on your WSGI server.
>>>> Best,
>>>> Angelos
>>>> On 08/29/2017 11:43 AM, Ana Boljevic wrote:
>>>> Dear Geonode Community,
>>>> We have installed fresh Geonode v2.6.2 on Ubuntu Server 16.04. In order to speed up system, we gave Geonode 24GB of RAM and 12 CPU. Unfortulnally, performance are still poor. Apart from basic installation (standard, not developement deployment) we have done:
>>>> 1) Replace OpenJVM with OracleJVM (see attachment geoserver.png)
>>>> JAVA_OPTS="-Djava.awt.headless=true -Xms6144m -Xmx6144m -XX:+UseParallelOldGC -XX:+UseParallelGC -XX:NewRatio=2 -XX:+AggressiveOpts -Xrs -XX:PerfDataSamplingInterval=500 -XX:MaxPermSize=512m"
>>>> For some reason, Server is not consuming memory no mater how many clients are requesting maps. There is always more than 16GB free memory (attachment free.jpg).
>>>> If you can give as any hint, idea or help, we would be thankful.
>>>> Regards,
>>>> Ana Boljevic
>>>> _______________________________________________
>>>> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Angelos Tzotsos, PhD
>>>> Charter Member
>>>> Open Source Geospatial Foundationhttp://users.ntua.gr/tzotsos
>>> Cell: 973-931-0580
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170908/3f6fd727/attachment-0001.html>
More information about the geonode-users mailing list
