[GeoNode-users] geoserver error
Paolo Corti pcorti at gmail.com
Thu Sep 28 09:03:01 PDT 2017
They are warnings and I don't think they are causing GeoServer to fail.
For sure deleting the default admin GeoNode users won't cause this kind of
problem.
Are you running GeoServer with enough memory?
p
On Thu, Sep 28, 2017 at 11:52 AM, Vicente <deluca.vicente at gmail.com> wrote:
> Sorry, maybe this is off-topic, my question is, Does removes some
> projection stuff when I delete the admin (default) user?
> The geoserver log error says
> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'polygon'
> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default workspace
> geonode
> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace 'geonode'
> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable authority
> factory: European Petroleum Survey Group
> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable authority
> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable authority
> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable authority
> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable authority
> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable authority
> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] - Invocation
> of destroy method failed on bean with name 'importer':
> java.lang.NullPointerException
> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] - Invocation
> of destroy method failed on bean with name 'geoServerLoader':
> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
> initialization failed
> org.springframework.beans.factory.BeanCreationException: Error creating
> bean with name 'kmlFormat' defined in URL [jar:file:/var/www/geo/
> httpdocs/geonode/geoserver/geoserver/WEB-INF/lib/gs-
> importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of
> bean failed; nested
> Another thing I did was add a kml file, but it looked fine!
> Some of the two things broke something in the geoserver.
> Thank you!
> On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com> wrote:
>> Hi,
>> the #paver start command throws the following error,
>> Error creating bean with name 'kmlFormat' defined in URL
>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-
>> of bean failed; nested
>> exception is java.lang.ExceptionInInitializerErro
>> I think it might have happened after removing some admin users from
>> geonode. It's possible?
>> I added them again but the problem persists, I do not want to lose the
>> information already loaded in the geoserver.
>> Thank you!
>> [image: MANTA] <http://www.estudiomanta.com/>
>> Vicente Deluca
>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
> Vicente Deluca
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/3a6aab83/attachment.html>
More information about the geonode-users mailing list
