[GeoNode-users] geoserver error
Vicente deluca.vicente at gmail.com
Thu Sep 28 09:15:10 PDT 2017
yes, I have 8GB, memory is not the problem
Then it must be the kml that I loaded
I'm ready to make a flush, could this solve it?
On Thu, Sep 28, 2017 at 1:03 PM, Paolo Corti <pcorti at gmail.com> wrote:
> They are warnings and I don't think they are causing GeoServer to fail.
> For sure deleting the default admin GeoNode users won't cause this kind of
> problem.
> Are you running GeoServer with enough memory?
> p
> On Thu, Sep 28, 2017 at 11:52 AM, Vicente <deluca.vicente at gmail.com>
> wrote:
>> Sorry, maybe this is off-topic, my question is, Does removes some
>> projection stuff when I delete the admin (default) user?
>> The geoserver log error says
>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'polygon'
>> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default workspace
>> geonode
>> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace 'geonode'
>> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable
>> authority factory: European Petroleum Survey Group
>> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable
>> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable
>> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable
>> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable
>> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable
>> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] -
>> Invocation of destroy method failed on bean with name 'importer':
>> java.lang.NullPointerException
>> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] -
>> Invocation of destroy method failed on bean with name 'geoServerLoader':
>> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
>> initialization failed
>> org.springframework.beans.factory.BeanCreationException: Error creating
>> bean with name 'kmlFormat' defined in URL [jar:file:/var/www/geo/httpdoc
>> s/geonode/geoserver/geoserver/WEB-INF/lib/gs-importer-core-
>> 2.7-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed;
>> nested
>> Another thing I did was add a kml file, but it looked fine!
>> Some of the two things broke something in the geoserver.
>> Thank you!
>> On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com>
>> wrote:
>>> Hi,
>>> the #paver start command throws the following error,
>>> Error creating bean with name 'kmlFormat' defined in URL
>>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-
>>> importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]: Instantiation
>>> of bean failed; nested
>>> exception is java.lang.ExceptionInInitializerErro
>>> I think it might have happened after removing some admin users from
>>> geonode. It's possible?
>>> I added them again but the problem persists, I do not want to lose the
>>> information already loaded in the geoserver.
>>> Thank you!
>>> [image: MANTA] <http://www.estudiomanta.com/>
>>> Vicente Deluca
>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>> Vicente Deluca
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Vicente Deluca
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/735ebc59/attachment-0001.html>
More information about the geonode-users mailing list
