[GeoNode-users] geoserver error
Vicente deluca.vicente at gmail.com
Thu Sep 28 12:24:19 PDT 2017
Geoserver on 8080?
I modified the jetty starter on pavement.py to run on 8082, just like the
local_settyngs.py file and it worked perfect.
It now runs on 8084 and the problem persists
I think that's not the problem
On Thu, Sep 28, 2017 at 4:01 PM, Paolo Corti <pcorti at gmail.com> wrote:
> According to first log, GeoServer is not starting because there is already
> a process running on 8080.
> Make sure to run "paver stop" before running again "paver start" and send
> the log of it if still failing
> cheers
> p
> On Thu, Sep 28, 2017 at 2:51 PM, Vicente <deluca.vicente at gmail.com> wrote:
>> I attach two log files, one is the output of the paver start command, the
>> other is the log of the geoserver/data/logs/geoserver.log folder
>> I increased the memory in the command line that runs the jetty and the
>> problem persists.
>> The command line running the jetty worked perfectly until yesterday
>> thks!
>> On Thu, Sep 28, 2017 at 3:20 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>> Could you attach a larger portion of the log? From here it is not clear
>>> that this error is the cause of GeoServer not being able to start.
>>> Generally when I see bean errors most of the time is because the Java
>>> process of the container of GeoServer (Tomcat or Jetty) is lacking RAM.
>>> Having a lot of RAM in the server doesn't mean that it will be correctly
>>> used by GeoServer, as it must be optimized (by default the GeoServer which
>>> comes with GeoNode is using parameters which are not ideal for production):
>>> http://docs.geoserver.org/latest/en/user/production/container.html
>>> regards
>>> p
>>> On Thu, Sep 28, 2017 at 12:17 PM, Vicente <deluca.vicente at gmail.com>
>>> wrote:
>>>> Please, look at these error lines. Do not they tell you anything?
>>>> Caused by: java.lang.RuntimeException: Could not decode: EPSG: 4326
>>>> at org.geoserver.importer.format.KMLFileFormat. <clinit>
>>>> (KMLFileFormat.java:65)
>>>> ... plus
>>>> Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No
>>>> "EPSG: 4326" code from the "European Petroleum Survey Group" authority
>>>> found for the "IdentifiedObject" object.
>>>> On Thu, Sep 28, 2017 at 1:15 PM, Vicente <deluca.vicente at gmail.com>
>>>> wrote:
>>>>> yes, I have 8GB, memory is not the problem
>>>>> Then it must be the kml that I loaded
>>>>> I'm ready to make a flush, could this solve it?
>>>>> On Thu, Sep 28, 2017 at 1:03 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>>> They are warnings and I don't think they are causing GeoServer to
>>>>>> fail.
>>>>>> For sure deleting the default admin GeoNode users won't cause this
>>>>>> kind of problem.
>>>>>> Are you running GeoServer with enough memory?
>>>>>> p
>>>>>> On Thu, Sep 28, 2017 at 11:52 AM, Vicente <deluca.vicente at gmail.com>
>>>>>> wrote:
>>>>>>> Sorry, maybe this is off-topic, my question is, Does removes some
>>>>>>> projection stuff when I delete the admin (default) user?
>>>>>>> The geoserver log error says
>>>>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'raster'
>>>>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style 'point'
>>>>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'line'
>>>>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style 'polygon'
>>>>>>> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default
>>>>>>> workspace geonode
>>>>>>> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace
>>>>>>> 'geonode'
>>>>>>> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable
>>>>>>> authority factory: European Petroleum Survey Group
>>>>>>> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable
>>>>>>> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable
>>>>>>> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable
>>>>>>> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable
>>>>>>> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable
>>>>>>> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] -
>>>>>>> Invocation of destroy method failed on bean with name 'importer':
>>>>>>> java.lang.NullPointerException
>>>>>>> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] -
>>>>>>> Invocation of destroy method failed on bean with name 'geoServerLoader':
>>>>>>> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
>>>>>>> initialization failed
>>>>>>> org.springframework.beans.factory.BeanCreationException: Error
>>>>>>> creating bean with name 'kmlFormat' defined in URL
>>>>>>> [jar:file:/var/www/geo/httpdocs/geonode/geoserver/geoserver/
>>>>>>> WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
>>>>>>> Instantiation of bean failed; nested
>>>>>>> Another thing I did was add a kml file, but it looked fine!
>>>>>>> Some of the two things broke something in the geoserver.
>>>>>>> Thank you!
>>>>>>> On Wed, Sep 27, 2017 at 8:54 PM, Vicente <deluca.vicente at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi,
>>>>>>>> the #paver start command throws the following error,
>>>>>>>> Error creating bean with name 'kmlFormat' defined in URL
>>>>>>>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-
>>>>>>>> exception is java.lang.ExceptionInInitializerErro
>>>>>>>> I think it might have happened after removing some admin users from
>>>>>>>> geonode. It's possible?
>>>>>>>> I added them again but the problem persists, I do not want to lose
>>>>>>>> the information already loaded in the geoserver.
>>>>>>>> Thank you!
>>>>>>>> [image: MANTA] <http://www.estudiomanta.com/>
>>>>>>>> Vicente Deluca
>>>>>>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>>>>>>> Vicente Deluca
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Paolo Corti
>>>>>> Geospatial software developer
>>>>>> web: http://www.paolocorti.net
>>>>>> twitter: @capooti
>>>>>> skype: capooti
>>>>> Vicente Deluca
>>>> Vicente Deluca
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
>> Vicente Deluca
> Paolo Corti
> twitter: @capooti
> skype: capooti
Vicente Deluca
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170928/a8985b27/attachment-0001.html>
(env)vicente at frontend:/var/www/geo.estudiomanta.com/httpdocs/geonode$ paver stop
---> pavement.stop
---> pavement.stop_geoserver
Stopping GeoNode ...
---> pavement.stop_django
(env)vicente at frontend:/var/www/geo.estudiomanta.com/httpdocs/geonode$ paver start
---> pavement.start
---> pavement.start_geoserver
cd /var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/data
java -version
java version "1.7.0_151"
OpenJDK Runtime Environment (IcedTea 2.6.11) (7u151-2.6.11-1+deb7u1)
OpenJDK 64-Bit Server VM (build 24.151-b01, mixed mode)
java -Xmx512m -XX:MaxPermSize=256m -DGEOSERVER_DATA_DIR=/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/data -Dorg.eclipse.jetty.server.webapp.parentLoaderPriority=true -jar /var/www/geo.estudiomanta.com/httpdocs/geonode/downloaded/jetty-runner-8.1.8.v20121106.jar --port 8084 --log /var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/jetty.log /var/www/geo.estudiomanta.com/httpdocs/geonode/scripts/misc/jetty-runner.xml > /dev/null &
Starting GeoServer on http://localhost:8084/geoserver/
2017-09-28 16:14:30.276:INFO:omjr.Runner:Runner
2017-09-28 16:14:30.277:WARN:omjr.Runner:No tx manager found
2017-09-28 16:14:30.346:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
Null identity service, trying login service: null
Finding identity service: null
2017-09-28 16:14:30.790:INFO:oejsh.ContextHandler:started o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/},../geoserver
2017-09-28 16:14:30.952:INFO:oejsh.ContextHandler:started o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/},../geoserver
Sep 28, 2017 4:14:31 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
2017-09-28 16:14:31.130:INFO:oejsh.ContextHandler:started o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/},../geoserver
2017-09-28 16:14:31.130:INFO:/geoserver:Initializing Spring root WebApplicationContext
Sep 28, 2017 4:14:32 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
2017-09-28 16:14:33.307:WARN:oejw.WebAppContext:Failed startup of context o.e.j.w.WebAppContext{/geoserver,file:/var/www/geo.estudiomanta.com/httpdocs//geonode/geoserver/geoserver/},../geoserver
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'kmlFormat' defined in URL [jar:file:/var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:997)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:943)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:607)
        at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:472)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
        at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
        at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771)
        at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:424)
        at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763)
        at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:249)
        at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
        at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706)
        at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:492)
        at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
        at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229)
        at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172)
        at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95)
        at org.eclipse.jetty.server.Server.doStart(Server.java:277)
        at org.mortbay.jetty.runner.Runner.run(Runner.java:504)
        at org.mortbay.jetty.runner.Runner.main(Runner.java:625)
Caused by:
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
        at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
        at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:990)
Caused by:
java.lang.RuntimeException: Could not decode: EPSG:4326
        at org.geoserver.importer.format.KMLFileFormat.<clinit>(KMLFileFormat.java:65)
Caused by:
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
        at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:951)
        at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:316)
        at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:390)
        at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
        at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
        at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
        at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
        at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
        at org.geotools.referencing.CRS.decode(CRS.java:520)
        at org.geotools.referencing.CRS.decode(CRS.java:448)
        at org.geoserver.importer.format.KMLFileFormat.<clinit>(KMLFileFormat.java:63)
2017-09-28 16:14:33.314:INFO:oejs.NCSARequestLog:Opened /var/www/geo.estudiomanta.com/httpdocs/geonode/geoserver/jetty.log
2017-09-28 16:14:33.326:INFO:oejs.AbstractConnector:Started SelectChannelConnector at 0.0.0.0:8084
More information about the geonode-users mailing list
