[GeoNode-users] geoserver error
Paolo Corti pcorti at gmail.com
Fri Sep 29 07:23:49 PDT 2017
Then it is not a memory problem.
Which version of GeoNode are you using?
Try to stop GeoServer, remove the cached copy - which seems to be
corrupted - of the EPSG database which should be in
/tmp/Geotools/Databases/HSQL (just remove this HSQL directory, it will
be create again on next GeoServer start)
Then start GeoServer again
hope this helps
p
On Fri, Sep 29, 2017 at 7:10 AM, Vicente <deluca.vicente at gmail.com> wrote:
> I ran paver setup, added memory and deleted all uploaded layers in
> geonode/geonode/uploaded/layers
> And the error continues, this has me baffled
> On Thu, Sep 28, 2017 at 4:55 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> According to your previous log (the first file), that was causing the
>> error which prevented GeoServer to start ("java.net.BindException:
>> Address already in use").
>> In this log you have attached now, I still see you are using
>> default minimal RAM parameters:
>> OpenJDK Runtime Environment (IcedTea 2.6.11) (7u151-2.6.11-1+deb7u1)
>> OpenJDK 64-Bit Server VM (build 24.151-b01, mixed mode)
>> java -Xmx512m -XX:MaxPermSize=256m -
>> Please try to use higher values and see if the error replicates
>> p
>> On Thu, Sep 28, 2017 at 3:24 PM, Vicente <deluca.vicente at gmail.com> wrote:
>> > Geoserver on 8080?
>> > I modified the jetty starter on pavement.py to run on 8082, just like
>> > the
>> > local_settyngs.py file and it worked perfect.
>> > It now runs on 8084 and the problem persists
>> > I think that's not the problem
>> > On Thu, Sep 28, 2017 at 4:01 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> >> According to first log, GeoServer is not starting because there is
>> >> already
>> >> a process running on 8080.
>> >> Make sure to run "paver stop" before running again "paver start" and
>> >> send
>> >> the log of it if still failing
>> >> cheers
>> >> p
>> >> On Thu, Sep 28, 2017 at 2:51 PM, Vicente <deluca.vicente at gmail.com>
>> >> wrote:
>> >>> I attach two log files, one is the output of the paver start command,
>> >>> the
>> >>> other is the log of the geoserver/data/logs/geoserver.log folder
>> >>> I increased the memory in the command line that runs the jetty and the
>> >>> problem persists.
>> >>> The command line running the jetty worked perfectly until yesterday
>> >>> thks!
>> >>> On Thu, Sep 28, 2017 at 3:20 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> >>>> Could you attach a larger portion of the log? From here it is not
>> >>>> clear
>> >>>> that this error is the cause of GeoServer not being able to start.
>> >>>> Generally when I see bean errors most of the time is because the Java
>> >>>> process of the container of GeoServer (Tomcat or Jetty) is lacking
>> >>>> RAM.
>> >>>> Having a lot of RAM in the server doesn't mean that it will be
>> >>>> correctly
>> >>>> used by GeoServer, as it must be optimized (by default the GeoServer
>> >>>> which
>> >>>> comes with GeoNode is using parameters which are not ideal for
>> >>>> production):
>> >>>> http://docs.geoserver.org/latest/en/user/production/container.html
>> >>>> regards
>> >>>> p
>> >>>> On Thu, Sep 28, 2017 at 12:17 PM, Vicente <deluca.vicente at gmail.com>
>> >>>> wrote:
>> >>>>> Please, look at these error lines. Do not they tell you anything?
>> >>>>> Caused by: java.lang.RuntimeException: Could not decode: EPSG: 4326
>> >>>>> at org.geoserver.importer.format.KMLFileFormat. <clinit>
>> >>>>> (KMLFileFormat.java:65)
>> >>>>> ... plus
>> >>>>> Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No
>> >>>>> "EPSG: 4326" code from the "European Petroleum Survey Group"
>> >>>>> authority found
>> >>>>> for the "IdentifiedObject" object.
>> >>>>> On Thu, Sep 28, 2017 at 1:15 PM, Vicente <deluca.vicente at gmail.com>
>> >>>>> wrote:
>> >>>>>> yes, I have 8GB, memory is not the problem
>> >>>>>> Then it must be the kml that I loaded
>> >>>>>> I'm ready to make a flush, could this solve it?
>> >>>>>> On Thu, Sep 28, 2017 at 1:03 PM, Paolo Corti <pcorti at gmail.com>
>> >>>>>> wrote:
>> >>>>>>> They are warnings and I don't think they are causing GeoServer to
>> >>>>>>> fail.
>> >>>>>>> For sure deleting the default admin GeoNode users won't cause this
>> >>>>>>> kind of problem.
>> >>>>>>> Are you running GeoServer with enough memory?
>> >>>>>>> p
>> >>>>>>> On Thu, Sep 28, 2017 at 11:52 AM, Vicente
>> >>>>>>> wrote:
>> >>>>>>>> Sorry, maybe this is off-topic, my question is, Does removes some
>> >>>>>>>> projection stuff when I delete the admin (default) user?
>> >>>>>>>> The geoserver log error says
>> >>>>>>>> 2017-09-28 10:16:59,001 INFO [org.geoserver] - Loaded style
>> >>>>>>>> 'raster'
>> >>>>>>>> 'point'
>> >>>>>>>> 2017-09-28 10:16:59,002 INFO [org.geoserver] - Loaded style
>> >>>>>>>> 'line'
>> >>>>>>>> 'polygon'
>> >>>>>>>> 2017-09-28 10:16:59,003 INFO [org.geoserver] - Loaded default
>> >>>>>>>> workspace geonode
>> >>>>>>>> 2017-09-28 10:16:59,005 INFO [org.geoserver] - Loaded workspace
>> >>>>>>>> 'geonode'
>> >>>>>>>> 2017-09-28 10:16:59,294 WARN [referencing.factory] - Unavailable
>> >>>>>>>> authority factory: European Petroleum Survey Group
>> >>>>>>>> 2017-09-28 10:16:59,295 WARN [referencing.factory] - Unavailable
>> >>>>>>>> 2017-09-28 10:16:59,296 WARN [referencing.factory] - Unavailable
>> >>>>>>>> 2017-09-28 10:16:59,301 WARN [referencing.factory] - Unavailable
>> >>>>>>>> 2017-09-28 10:16:59,302 WARN [referencing.factory] - Unavailable
>> >>>>>>>> 2017-09-28 10:16:59,303 WARN [referencing.factory] - Unavailable
>> >>>>>>>> 2017-09-28 10:16:59,308 WARN [support.DisposableBeanAdapter] -
>> >>>>>>>> Invocation of destroy method failed on bean with name 'importer':
>> >>>>>>>> java.lang.NullPointerException
>> >>>>>>>> 2017-09-28 10:16:59,309 WARN [support.DisposableBeanAdapter] -
>> >>>>>>>> 'geoServerLoader':
>> >>>>>>>> 2017-09-28 10:16:59,310 ERROR [context.ContextLoader] - Context
>> >>>>>>>> initialization failed
>> >>>>>>>> org.springframework.beans.factory.BeanCreationException: Error
>> >>>>>>>> creating bean with name 'kmlFormat' defined in URL
>> >>>>>>>> [jar:file:/var/www/geo/httpdocs/geonode/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
>> >>>>>>>> Instantiation of bean failed; nested
>> >>>>>>>> Another thing I did was add a kml file, but it looked fine!
>> >>>>>>>> Some of the two things broke something in the geoserver.
>> >>>>>>>> Thank you!
>> >>>>>>>> On Wed, Sep 27, 2017 at 8:54 PM, Vicente
>> >>>>>>>> wrote:
>> >>>>>>>>> Hi,
>> >>>>>>>>> the #paver start command throws the following error,
>> >>>>>>>>> Error creating bean with name 'kmlFormat' defined in URL
>> >>>>>>>>> [jar:file:/var/www/{...}/geoserver/geoserver/WEB-INF/lib/gs-importer-core-2.7-SNAPSHOT.jar!/applicationContext.xml]:
>> >>>>>>>>> exception is java.lang.ExceptionInInitializerErro
>> >>>>>>>>> I think it might have happened after removing some admin users
>> >>>>>>>>> from
>> >>>>>>>>> geonode. It's possible?
>> >>>>>>>>> I added them again but the problem persists, I do not want to
>> >>>>>>>>> lose
>> >>>>>>>>> the information already loaded in the geoserver.
>> >>>>>>>>> Thank you!
>> >>>>>>>>> Vicente Deluca
>> >>>>>>>>> +54 11 6091 4579
>> >>>>>>>> Vicente Deluca
>> >>>>>>>> +54 11 6091 4579
>> >>>>>>>> _______________________________________________
>> >>>>>>>> geonode-users mailing list
>> >>>>>>>> geonode-users at lists.osgeo.org
>> >>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> >>>>>>> Paolo Corti
>> >>>>>>> Geospatial software developer
>> >>>>>>> web: http://www.paolocorti.net
>> >>>>>>> twitter: @capooti
>> >>>>>>> skype: capooti
>> >>>>>> Vicente Deluca
>> >>>>>> +54 11 6091 4579
>> >>>>> Vicente Deluca
>> >>>>> +54 11 6091 4579
>> >>>> Paolo Corti
>> >>>> twitter: @capooti
>> >>>> skype: capooti
>> >>> Vicente Deluca
>> >>> +54 11 6091 4579
>> >> Paolo Corti
>> >> twitter: @capooti
>> >> skype: capooti
>> > Vicente Deluca
>> > +54 11 6091 4579
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
> Vicente Deluca
> +54 11 6091 4579
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
