[GeoNode-users] GeoNode 2.8.0 is out!
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 3 04:31:25 PDT 2018
Dear all,
GeoNode release 2.8.0 is out!
*Installing from apt on Ubuntu 16.04*
In order to test it through APT, on a clean Ubuntu 16.04 instance run:
sudo apt-add-repository ppa:geonode/testing
sudo apt update -y
sudo apt upgrade -y
sudo apt install geonode
*Few notes on finalizing the setup (this will be improved on next release)*
*1) Update your default map crs to 3857  sudo nano
/etc/geonode/local_settings.py      DEFAULT_MAP_CRS = "EPSG:3857"
DEFAULT_LAYER_FORMAT = "image/png8"      sudo service apache2 restart2)
Restart Tomcat in order to allow GeoServer to reload the configuration
sudo service apache tomcat8 restart*
*Setting up your custom project*
Please follow instructions from
https://github.com/GeoNode/geonode-project#using-a-python-virtual-environment
*Upgrading from 2.6.x release*
If you would like to update from a 2.6.x development version, please take a
look at the following document (still not definitive)
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/26_to_27/index.html#update-from-geonode-2-6-3-to-geonode-2-7
*Other type of setup / installer*
Docker and Windows installers won't be ready by the announcement of the
official release.
There are still many issues with those two packages, preventing us to
publish stable versions of them.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180403/9a222590/attachment-0001.html>
More information about the geonode-users mailing list
