[GeoNode-users] GeoNode install mix up.
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 3 09:24:36 PDT 2018
Daniel,
didn't try myself, but the easiest option I can figure out right now would
be to revert the geonode ppa to Trusty dist only
see for example
https://help.ubuntu.com/community/add-apt-repository
Sorry I guess I can't help much more than this. I didn't face such issue at
all until now.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-04-03 18:06 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
> I'm sorry Alessio but I don't quite understand. Is there a way to go back
> 'temporarily' to geonode 2.6.3 to get things fixed? I am running Ubuntu
> Xenial.
> Am I the only one that is having this problem?
> Cheers
> Daniel
> On Tue, Apr 3, 2018 at 11:38 AM Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Yes, currently all the updated packages are just for xenial distribution.
>> Most probably the easiest way would be to add ppa sources for Trusty only.
>> Another good thing to do, would be to spend some time (maybe let's open
>> an issues for that) to specify packages versions here
>> https://github.com/GeoNode/geonode/blob/master/package/debian/control
>> and rebuild the debs.
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-04-03 16:32 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>> Ok, thanks.
>>> Is there a easy way to do this? Can it be fixed using APT? Our IT
>>> Specialist mentioned he is having to manually download the debs? He also
>>> mentioned that this happened once with our OwnCloud instalation. So what
>>> the devs did was to have version specific repositories. Do we have that for
>>> geonode?
>>> Cheers
>>> Daniel
>>> On Tue, Apr 3, 2018 at 9:41 AM Alessio Fabiani <alessio.fabiani at geo-
>>>> I guess the only way is to revert dependency packages to old versions
>>>> from ppa.
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> 55054  Massarosa
>>>> (LU)
>>>> Italy
>>>> 2018-04-03 14:27 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>>> Hi all,
>>>>> First of all, thanks for the great work and this new 2.8 release.
>>>>> Looking forward to test it out.
>>>>> Meanwhile, I believe I messed things up on my side. The server that I
>>>>> had GeoNode 2.6 running went through an update and the new 2.8 version got
>>>>> installed. I'm now in a package dependency mess and my GeoNode install is
>>>>> not working.
>>>>> Looking back now, I thing I should have set the GeoNode 2.6 package on
>>>>> hold, correct? How can I go back to version 2.6 using apt? Or should the
>>>>> apt upgrade install version 2.8 on top of 2.6 fine?
>>>>> Cheers
>>>>> Daniel
>>>>> On Tue, Apr 3, 2018 at 9:16 AM Angelos Tzotsos <gcpp.kalxas at gmail.com>
>>>>> wrote:
>>>>>> Thanks all for the release!
>>>>>> On Tue, Apr 3, 2018 at 2:55 PM, Simone Dalmasso <
>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>> Thanks a lot Alessio! Great job!
>>>>>>> 2018-04-03 13:32 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
>>>>>>> solutions.it>:
>>>>>>>> *ERRATA CORRIGE:*
>>>>>>>> * sudo apt-add-repository ppa:geonode/testing -->  sudo
>>>>>>>> apt-add-repository ppa:geonode/stable*
>>>>>>>> Regards,
>>>>>>>> Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> 55054  Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>> 2018-04-03 13:31 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
>>>>>>>> solutions.it>:
>>>>>>>>> Dear all,
>>>>>>>>> GeoNode release 2.8.0 is out!
>>>>>>>>> *Installing from apt on Ubuntu 16.04*
>>>>>>>>> In order to test it through APT, on a clean Ubuntu 16.04 instance
>>>>>>>>> run:
>>>>>>>>> sudo apt update -y
>>>>>>>>> sudo apt upgrade -y
>>>>>>>>> sudo apt install geonode
>>>>>>>>> *Few notes on finalizing the setup (this will be improved on next
>>>>>>>>> release)*
>>>>>>>>> *1) Update your default map crs to 3857  sudo nano
>>>>>>>>> /etc/geonode/local_settings.py      DEFAULT_MAP_CRS = "EPSG:3857"
>>>>>>>>> DEFAULT_LAYER_FORMAT = "image/png8"      sudo service apache2 restart2)
>>>>>>>>> Restart Tomcat in order to allow GeoServer to reload the configuration
>>>>>>>>> sudo service apache tomcat8 restart*
>>>>>>>>> *Setting up your custom project*
>>>>>>>>> Please follow instructions from
>>>>>>>>> https://github.com/GeoNode/geonode-project#using-a-
>>>>>>>>> python-virtual-environment
>>>>>>>>> *Upgrading from 2.6.x release*
>>>>>>>>> If you would like to update from a 2.6.x development version,
>>>>>>>>> please take a look at the following document (still not definitive)
>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_
>>>>>>>>> admin/geonode_update/26_to_27/index.html#update-from-
>>>>>>>>> geonode-2-6-3-to-geonode-2-7
>>>>>>>>> *Other type of setup / installer*
>>>>>>>>> Docker and Windows installers won't be ready by the announcement
>>>>>>>>> of the official release.
>>>>>>>>> There are still many issues with those two packages, preventing us
>>>>>>>>> to publish stable versions of them.
>>>>>>>>> Regards,
>>>>>>>>> Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> 55054  Massarosa
>>>>>>>>> (LU)
>>>>>>>>> Italy
>>>>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>>>> _______________________________________________
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>> Simone
>>>>>> Angelos Tzotsos, PhD
>>>>>> OSGeo Charter Member
>>>>>> http://users.ntua.gr/tzotsos
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180403/aeab57ba/attachment-0001.html>
More information about the geonode-users mailing list
