[GeoNode-users] GeoNode 2.8.0 is out!
Ariel Nunez ingenieroariel at gmail.com
Tue Apr 3 12:27:55 PDT 2018
Thanks a lot Alessio and team!
On Tue, Apr 3, 2018 at 12:59 PM Bernard Justus Muhwezi <
bernard.muhwezi at gmail.com> wrote:
> Alessio,
> Just as promised, bravo dear man of effort. We congratulate and salute the
> much energy that goes into this accomplishment.
> Dear all you are appreciated from this part of the globe.
> Bernard Justus
> On Tue, Apr 3, 2018 at 2:31 PM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Dear all,
>> GeoNode release 2.8.0 is out!
>> *Installing from apt on Ubuntu 16.04*
>> In order to test it through APT, on a clean Ubuntu 16.04 instance run:
>> sudo apt-add-repository ppa:geonode/testing
>> sudo apt update -y
>> sudo apt upgrade -y
>> sudo apt install geonode
>> *Few notes on finalizing the setup (this will be improved on next
>> release)*
>> *1) Update your default map crs to 3857  sudo nano
>> /etc/geonode/local_settings.py      DEFAULT_MAP_CRS = "EPSG:3857"
>> DEFAULT_LAYER_FORMAT = "image/png8"      sudo service apache2 restart2)
>> Restart Tomcat in order to allow GeoServer to reload the configuration
>> sudo service apache tomcat8 restart*
>> *Setting up your custom project*
>> Please follow instructions from
>> https://github.com/GeoNode/geonode-project#using-a-python-virtual-environment
>> *Upgrading from 2.6.x release*
>> If you would like to update from a 2.6.x development version, please take
>> a look at the following document (still not definitive)
>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/26_to_27/index.html#update-from-geonode-2-6-3-to-geonode-2-7
>> *Other type of setup / installer*
>> Docker and Windows installers won't be ready by the announcement of the
>> official release.
>> There are still many issues with those two packages, preventing us to
>> publish stable versions of them.
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180403/c228e890/attachment.html>
More information about the geonode-users mailing list
