[GeoNode-users] GeoNode install mix up.
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 3 15:00:18 PDT 2018
Will try to send you instructions tomorrow. Basically for geonode you need
to update the dB and python libraries, while for geoserver you will need to
update war and align data directory.
Il mar 3 apr 2018, 20:58 Daniel Victoria <daniel.victoria at gmail.com> ha
scritto:
> OK, we tried to go back to v2.6.3 pulling from the trusty repository but
> that did not work. So we will now try to migrate to version 2.8
> I saw that there is a document about migrating from the 2.7.X development
> version. Are there migration scripts to do a 2.6 --> 2.8 migration? Or a
> writeup somewhere?
> Thanks
> Daniel
> On Tue, Apr 3, 2018 at 1:25 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> P.s.: at this point maybe you should envisage to update directly to 2.8,
>> but you must do this manually.
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-04-03 18:24 GMT+02:00 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it>:
>>> Daniel,
>>> didn't try myself, but the easiest option I can figure out right now
>>> would be to revert the geonode ppa to Trusty dist only
>>> see for example
>>> https://help.ubuntu.com/community/add-apt-repository
>>> Sorry I guess I can't help much more than this. I didn't face such issue
>>> at all until now.
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <0584%20962313>
>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>> mob:   +39 331 6233686 <331%20623%203686>
>>> 2018-04-03 18:06 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>> I'm sorry Alessio but I don't quite understand. Is there a way to go
>>>> back 'temporarily' to geonode 2.6.3 to get things fixed? I am running
>>>> Ubuntu Xenial.
>>>> Am I the only one that is having this problem?
>>>> Cheers
>>>> Daniel
>>>> On Tue, Apr 3, 2018 at 11:38 AM Alessio Fabiani <
>>>>> Yes, currently all the updated packages are just for xenial
>>>>> distribution.
>>>>> Most probably the easiest way would be to add ppa sources for Trusty
>>>>> only.
>>>>> Another good thing to do, would be to spend some time (maybe let's
>>>>> open an issues for that) to specify packages versions here
>>>>> https://github.com/GeoNode/geonode/blob/master/package/debian/control
>>>>> and rebuild the debs.
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054  Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> 2018-04-03 16:32 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>
>>>>>> Ok, thanks.
>>>>>> Is there a easy way to do this? Can it be fixed using APT? Our IT
>>>>>> Specialist mentioned he is having to manually download the debs? He also
>>>>>> mentioned that this happened once with our OwnCloud instalation. So what
>>>>>> the devs did was to have version specific repositories. Do we have that for
>>>>>> geonode?
>>>>>> Cheers
>>>>>> Daniel
>>>>>> On Tue, Apr 3, 2018 at 9:41 AM Alessio Fabiani <
>>>>>>> I guess the only way is to revert dependency packages to old
>>>>>>> versions from ppa.
>>>>>>> Regards,
>>>>>>> Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> 55054  Massarosa
>>>>>>> (LU)
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> 2018-04-03 14:27 GMT+02:00 Daniel Victoria <
>>>>>>>> Hi all,
>>>>>>>> First of all, thanks for the great work and this new 2.8 release.
>>>>>>>> Looking forward to test it out.
>>>>>>>> Meanwhile, I believe I messed things up on my side. The server that
>>>>>>>> I had GeoNode 2.6 running went through an update and the new 2.8 version
>>>>>>>> got installed. I'm now in a package dependency mess and my GeoNode install
>>>>>>>> is not working.
>>>>>>>> Looking back now, I thing I should have set the GeoNode 2.6 package
>>>>>>>> on hold, correct? How can I go back to version 2.6 using apt? Or should the
>>>>>>>> apt upgrade install version 2.8 on top of 2.6 fine?
>>>>>>>> Cheers
>>>>>>>> Daniel
>>>>>>>> On Tue, Apr 3, 2018 at 9:16 AM Angelos Tzotsos <
>>>>>>>> gcpp.kalxas at gmail.com> wrote:
>>>>>>>>> Thanks all for the release!
>>>>>>>>> On Tue, Apr 3, 2018 at 2:55 PM, Simone Dalmasso <
>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>> Thanks a lot Alessio! Great job!
>>>>>>>>>> 2018-04-03 13:32 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>> *ERRATA CORRIGE:*
>>>>>>>>>>> * sudo apt-add-repository ppa:geonode/testing -->  sudo
>>>>>>>>>>> apt-add-repository ppa:geonode/stable*
>>>>>>>>>>> Regards,
>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> 55054  Massarosa
>>>>>>>>>>> (LU)
>>>>>>>>>>> Italy
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> 2018-04-03 13:31 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>> Dear all,
>>>>>>>>>>>> GeoNode release 2.8.0 is out!
>>>>>>>>>>>> *Installing from apt on Ubuntu 16.04*
>>>>>>>>>>>> In order to test it through APT, on a clean Ubuntu 16.04
>>>>>>>>>>>> instance run:
>>>>>>>>>>>> sudo apt update -y
>>>>>>>>>>>> sudo apt upgrade -y
>>>>>>>>>>>> sudo apt install geonode
>>>>>>>>>>>> *Few notes on finalizing the setup (this will be improved on
>>>>>>>>>>>> next release)*
>>>>>>>>>>>> *1) Update your default map crs to 3857  sudo nano
>>>>>>>>>>>> /etc/geonode/local_settings.py      DEFAULT_MAP_CRS = "EPSG:3857"
>>>>>>>>>>>> DEFAULT_LAYER_FORMAT = "image/png8"      sudo service apache2 restart2)
>>>>>>>>>>>> Restart Tomcat in order to allow GeoServer to reload the configuration
>>>>>>>>>>>> sudo service apache tomcat8 restart*
>>>>>>>>>>>> *Setting up your custom project*
>>>>>>>>>>>> Please follow instructions from
>>>>>>>>>>>> https://github.com/GeoNode/geonode-project#using-a-python-virtual-environment
>>>>>>>>>>>> *Upgrading from 2.6.x release*
>>>>>>>>>>>> If you would like to update from a 2.6.x development version,
>>>>>>>>>>>> please take a look at the following document (still not definitive)
>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/26_to_27/index.html#update-from-geonode-2-6-3-to-geonode-2-7
>>>>>>>>>>>> *Other type of setup / installer*
>>>>>>>>>>>> Docker and Windows installers won't be ready by the
>>>>>>>>>>>> announcement of the official release.
>>>>>>>>>>>> There are still many issues with those two packages, preventing
>>>>>>>>>>>> us to publish stable versions of them.
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> 55054  Massarosa
>>>>>>>>>>>> (LU)
>>>>>>>>>>>> Italy
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>> Simone
>>>>>>>>> Angelos Tzotsos, PhD
>>>>>>>>> OSGeo Charter Member
>>>>>>>>> http://users.ntua.gr/tzotsos
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180403/d8b4c8bb/attachment-0001.html>
More information about the geonode-users mailing list
