[GeoNode-users] GeoNode install mix up.
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Apr 4 04:39:47 PDT 2018
So, currently I don't have time to try to setup a whole infrastructure
starting from 2.6.x. Therefore let's see if we can manage this somehow with
a first troubleshooting by using your instance as a test base.
I would try doing something like this:
1. Double check /etc/geonode/local_settings.py is this still your original
one or it has been replaced by the setup? Also you should do a diff with
the following one
https://github.com/GeoNode/geonode/blob/2.8.0/package/support/geonode.local_settings
2. Once the settings have been checked, try to run the following commands
DJANGO_SETTINGS_MODULE=geonode.local_settings geonode makemigrations
DJANGO_SETTINGS_MODULE=geonode.local_settings geonode migrate
hopefully those will update the layers to the 2.8 schema
3. You will need to update GeoServer and be sure it starts on local tomcat
This guide
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_update/26_to_27/index.html
starting from "Download the latest GeoServer WAR..." point, should help you
to understand how to update GeoServer.
By using apt:
a) The GeoServer code is located into /usr/share/geoserver
b) The GeoServer Data Dir is located into /usr/share/geoserver/data
c) The Catalina Context is configured
into /var/lib/tomcat8/conf/Catalina/localhost/geoserver.xml
d) The Tomcat logs are located into /var/lib/tomcat8/logs
To restart GeoServer run: sudo service tomcat8 restart
To restart GeoNode run: sudo service apache2 restart
To check for GeoNode errors do: sudo tail -F -n 300
/var/log/apache2/error.log
To check for GeoServer errors either look into:
  /var/lib/tomcat8/logs/catalina.out
  /usr/share/geoserver/data/logs/geoserver.log
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-04-04 0:00 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Will try to send you instructions tomorrow. Basically for geonode you need
> to update the dB and python libraries, while for geoserver you will need to
> update war and align data directory.
> Il mar 3 apr 2018, 20:58 Daniel Victoria <daniel.victoria at gmail.com> ha
> scritto:
>> OK, we tried to go back to v2.6.3 pulling from the trusty repository but
>> that did not work. So we will now try to migrate to version 2.8
>> I saw that there is a document about migrating from the 2.7.X development
>> version. Are there migration scripts to do a 2.6 --> 2.8 migration? Or a
>> writeup somewhere?
>> Thanks
>> Daniel
>> On Tue, Apr 3, 2018 at 1:25 PM Alessio Fabiani <alessio.fabiani at geo-
>> solutions.it> wrote:
>>> P.s.: at this point maybe you should envisage to update directly to 2.8,
>>> but you must do this manually.
>>> Regards,
>>> Alessio Fabiani
>>> http://goo.gl/it488V for more information.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> 2018-04-03 18:24 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
>>> solutions.it>:
>>>> Daniel,
>>>> didn't try myself, but the easiest option I can figure out right now
>>>> would be to revert the geonode ppa to Trusty dist only
>>>> see for example
>>>> https://help.ubuntu.com/community/add-apt-repository
>>>> Sorry I guess I can't help much more than this. I didn't face such
>>>> issue at all until now.
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> 55054  Massarosa
>>>> (LU)
>>>> Italy
>>>> phone: +39 0584 962313 <0584%20962313>
>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>> 2018-04-03 18:06 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>>> I'm sorry Alessio but I don't quite understand. Is there a way to go
>>>>> back 'temporarily' to geonode 2.6.3 to get things fixed? I am running
>>>>> Ubuntu Xenial.
>>>>> Am I the only one that is having this problem?
>>>>> Cheers
>>>>> Daniel
>>>>> On Tue, Apr 3, 2018 at 11:38 AM Alessio Fabiani <alessio.fabiani at geo-
>>>>>> Yes, currently all the updated packages are just for xenial
>>>>>> distribution.
>>>>>> Most probably the easiest way would be to add ppa sources for Trusty
>>>>>> only.
>>>>>> Another good thing to do, would be to spend some time (maybe let's
>>>>>> open an issues for that) to specify packages versions here
>>>>>> https://github.com/GeoNode/geonode/blob/master/package/debian/control
>>>>>> and rebuild the debs.
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> 2018-04-03 16:32 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com
>>>>>>> Ok, thanks.
>>>>>>> Is there a easy way to do this? Can it be fixed using APT? Our IT
>>>>>>> Specialist mentioned he is having to manually download the debs? He also
>>>>>>> mentioned that this happened once with our OwnCloud instalation. So what
>>>>>>> the devs did was to have version specific repositories. Do we have that for
>>>>>>> geonode?
>>>>>>> Cheers
>>>>>>> Daniel
>>>>>>> On Tue, Apr 3, 2018 at 9:41 AM Alessio Fabiani <alessio.fabiani at geo-
>>>>>>>> I guess the only way is to revert dependency packages to old
>>>>>>>> versions from ppa.
>>>>>>>> Regards,
>>>>>>>> Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> 55054  Massarosa
>>>>>>>> (LU)
>>>>>>>> Italy
>>>>>>>> 2018-04-03 14:27 GMT+02:00 Daniel Victoria <
>>>>>>>>> Hi all,
>>>>>>>>> First of all, thanks for the great work and this new 2.8 release.
>>>>>>>>> Looking forward to test it out.
>>>>>>>>> Meanwhile, I believe I messed things up on my side. The server
>>>>>>>>> that I had GeoNode 2.6 running went through an update and the new 2.8
>>>>>>>>> version got installed. I'm now in a package dependency mess and my GeoNode
>>>>>>>>> install is not working.
>>>>>>>>> Looking back now, I thing I should have set the GeoNode 2.6
>>>>>>>>> package on hold, correct? How can I go back to version 2.6 using apt? Or
>>>>>>>>> should the apt upgrade install version 2.8 on top of 2.6 fine?
>>>>>>>>> Cheers
>>>>>>>>> Daniel
>>>>>>>>> On Tue, Apr 3, 2018 at 9:16 AM Angelos Tzotsos <
>>>>>>>>> gcpp.kalxas at gmail.com> wrote:
>>>>>>>>>> Thanks all for the release!
>>>>>>>>>> On Tue, Apr 3, 2018 at 2:55 PM, Simone Dalmasso <
>>>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>> Thanks a lot Alessio! Great job!
>>>>>>>>>>> 2018-04-03 13:32 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
>>>>>>>>>>> solutions.it>:
>>>>>>>>>>>> *ERRATA CORRIGE:*
>>>>>>>>>>>> * sudo apt-add-repository ppa:geonode/testing -->  sudo
>>>>>>>>>>>> apt-add-repository ppa:geonode/stable*
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> 55054  Massarosa
>>>>>>>>>>>> (LU)
>>>>>>>>>>>> Italy
>>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>>> 2018-04-03 13:31 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>> GeoNode release 2.8.0 is out!
>>>>>>>>>>>>> *Installing from apt on Ubuntu 16.04*
>>>>>>>>>>>>> In order to test it through APT, on a clean Ubuntu 16.04
>>>>>>>>>>>>> instance run:
>>>>>>>>>>>>> sudo apt update -y
>>>>>>>>>>>>> sudo apt upgrade -y
>>>>>>>>>>>>> sudo apt install geonode
>>>>>>>>>>>>> *Few notes on finalizing the setup (this will be improved on
>>>>>>>>>>>>> next release)*
>>>>>>>>>>>>> *1) Update your default map crs to 3857  sudo nano
>>>>>>>>>>>>> /etc/geonode/local_settings.py      DEFAULT_MAP_CRS = "EPSG:3857"
>>>>>>>>>>>>> DEFAULT_LAYER_FORMAT = "image/png8"      sudo service apache2 restart2)
>>>>>>>>>>>>> Restart Tomcat in order to allow GeoServer to reload the configuration
>>>>>>>>>>>>> sudo service apache tomcat8 restart*
>>>>>>>>>>>>> *Setting up your custom project*
>>>>>>>>>>>>> Please follow instructions from
>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project#using-a-
>>>>>>>>>>>>> python-virtual-environment
>>>>>>>>>>>>> *Upgrading from 2.6.x release*
>>>>>>>>>>>>> If you would like to update from a 2.6.x development version,
>>>>>>>>>>>>> please take a look at the following document (still not definitive)
>>>>>>>>>>>>> admin/geonode_update/26_to_27/index.html#update-from-
>>>>>>>>>>>>> geonode-2-6-3-to-geonode-2-7
>>>>>>>>>>>>> *Other type of setup / installer*
>>>>>>>>>>>>> Docker and Windows installers won't be ready by the
>>>>>>>>>>>>> announcement of the official release.
>>>>>>>>>>>>> There are still many issues with those two packages,
>>>>>>>>>>>>> preventing us to publish stable versions of them.
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> 55054  Massarosa
>>>>>>>>>>>>> (LU)
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>>> Simone
>>>>>>>>>> Angelos Tzotsos, PhD
>>>>>>>>>> OSGeo Charter Member
>>>>>>>>>> http://users.ntua.gr/tzotsos
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180404/7107ab10/attachment-0001.html>
More information about the geonode-users mailing list
