[GeoNode-users] Theming Geonode
Simone Dalmasso simone.dalmasso at gmail.com
Mon Apr 9 23:22:24 PDT 2018
you actually used a different approach form the dev workshop because you
installed geonode with apt-get. It is ok to do like this but you need to
change a bit the setup.
In your case geonode and geoserver are already running (apache and tomcat)
so you can skip the "cd geonode && paver start_geoserver" at all. Just run
your geonode-project, it will use the geonode installed system wide.
Anyway to answer your question, if you want to wrap commands in a .sh
script, you can put it where you prefer, just make sure the path it will
use are correct.
Regards
2018-04-09 22:48 GMT+02:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Hi Geonode contributers and developers,
> Going back to a previous recommendations made by Tony Schonbuchner and
> Alessio Fabiane about Theming Geonode.
>  https://github.com/GeoNode/geonode-project
> Then the rest should be basic Django.
> - create your app
> - create your view
> - create your template
> - create your urls.py
> - add it to your settings file
> - and add it to project urls.py
> http://geonode.org/dev-workshop/#/ *
> Adding to Toni details,
> once you have been able to setup you geonode-project (see the README on
> how to do that), you should be able to add tabs by modifying this file here
> https://github.com/GeoNode/geonode-project/blob/2.8.0/projec
> t_name/templates/site_base.html
> Just remove the {% comment %} / {% endcomment %} keywrods to enable the
> code and update the <li> accordingly.
> Said that, I did the following based in here http://geonode.org/dev-
> workshop/#/3/2 :
>  1 - I created a virtualenv <geonode-virtualenv> in
> (/etc/julierme_virtualenv/)
>  2 - I executed  django-admin.py startproject geonode-project --template=
> https://github.com/GeoNode/geonode-project/archive/2.8.0.zip -epy,rst.
>  3 - I activated geonode-virtualenv and ran:
>                pip install -e geonode-project
> Now I have:
> 1 -  geonode  in ( /etc/geonode/templates and
> /usr/local/lib/python2.7/dist-packages/geonode )  #installed via apt-get#
> 2 -  geonode-project in /etc/julierme_virtualenv/geonode-virtualenv/
> #Installed according to here http://geonode.org/dev-workshop/#/3/2#
> I got confused in here (http://geonode.org/dev-workshop/#/3/3):
>    - cd geonode && paver start_geoserver
>    - cd ../my_geonode && python manage.py runserver
> *You can wrap this in a simple executable .sh script*
> *Should I have two .sh files ( one for cd geonode && paver start_geoserver
> and other for cd ../my_geonode && python manage.py runserver) ? if so,
> where should them be stored? If one .sh file, where should it be stored?*
> *Thank you for your time in advance*
> *I appreciated your time and patience.*
> *Kind Regards*
> *Julierme Pinheiro*
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180410/f3770085/attachment-0001.html>
More information about the geonode-users mailing list
