[GeoNode-users] Theming Geonode
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Apr 16 08:59:43 PDT 2018
Hi Francesco Bartoli,
Find attached  my geonode.conf file available in
/etc/apache2/sites-available/ and /etc/apache2/sites-enabled/.
my_geonode project is installed in my_geonode virtualenv available in "
(my_geonode) root at geo:/etc/julierme_virtualenv/my_geonode/my_geonode "
I have python2.7 (2.7.12) installed in  /usr/bin/python2.7 and in
/etc/julierme_virtualenv/my_geonode/bin/python2.7.
I have my geonode production installed via apt-get (see
geonode-production.png in attached) and geonode-project installed via (
https://github.com/GeoNode/geonode-project) (see
geonode-project-virtualenv.png).
What changes should I make in geonode.conf, so I can mirror/apply the
changes made in geonode-project to geonode production?
I apologize for my small background in IT.
Thank you very much for your patience and time.
I appreciated it.
Kind regards
Julierme Pinheiro
2018-04-14 14:02 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
> Apache configuration (i.e. http://docs.geonode.org/
> en/master/_downloads/geonode.conf) has to be changed accordingly with
> your geonode upstream project my_geonode and its python-path matters.
> Il giorno 11/apr/2018, alle ore 17:11, Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
> HI Francesco,
> Thank you for your reply.
> That means If I install my_geonode via virtualenv I would need a side
> script to apply my_geonode changes in my geonode installed via apt-get in
> respect to theming geonode?
> Thank you for your time and patience
> I appreciated it
> Julierme
> 2018-04-10 3:26 GMT-03:00 francesco bartoli <xbartolone at gmail.com>:
>> Hi Julierme,
>> those commands are supposed to be executed in development mode within the
>> same virtual environment assuming you have geonode and my_geonode folders
>> with the code base in a common base path:
>> <base path>/geonode
>> <base path>/my_geonode
>> It's up to you if you want to automate within a script, usually in dev
>> mode you start geoserver and keep it up and running while hacking
>> geonode/my_geonode
>> Francesco
>> 2018-04-09 22:48 GMT+02:00 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com>:
>>> Hi Geonode contributers and developers,
>>> Going back to a previous recommendations made by Tony Schonbuchner and
>>> Alessio Fabiane about Theming Geonode.
>>> Then the rest should be basic Django.
>>> - create your app
>>> - create your view
>>> - create your template
>>> - create your urls.py
>>> - add it to your settings file
>>> - and add it to project urls.py
>>> http://geonode.org/dev-workshop/#/ *
>>> Adding to Toni details,
>>> once you have been able to setup you geonode-project (see the README on
>>> how to do that), you should be able to add tabs by modifying this file here
>>> https://github.com/GeoNode/geonode-project/blob/2.8.0/projec
>>> t_name/templates/site_base.html
>>> Just remove the {% comment %} / {% endcomment %} keywrods to enable the
>>> code and update the <li> accordingly.
>>> Said that, I did the following based in here
>>> http://geonode.org/dev-workshop/#/3/2 :
>>>  1 - I created a virtualenv <geonode-virtualenv> in
>>> (/etc/julierme_virtualenv/)
>>>  2 - I executed  django-admin.py startproject geonode-project
>>> --template=https://github.com/GeoNode/geonode-project/archive/2.8.0.zip
>>> -epy,rst.
>>>  3 - I activated geonode-virtualenv and ran:
>>>                pip install -e geonode-project
>>> Now I have:
>>> 1 -  geonode  in ( /etc/geonode/templates and
>>> /usr/local/lib/python2.7/dist-packages/geonode )  #installed via
>>> apt-get#
>>> 2 -  geonode-project in /etc/julierme_virtualenv/geonode-virtualenv/
>>> #Installed according to here http://geonode.org/dev-workshop/#/3/2#
>>> I got confused in here (http://geonode.org/dev-workshop/#/3/3):
>>>    - cd geonode && paver start_geoserver
>>>    - cd ../my_geonode && python manage.py runserver
>>> *You can wrap this in a simple executable .sh script*
>>> *Should I have two .sh files ( one for cd geonode && paver
>>> start_geoserver and other for cd ../my_geonode && python manage.py
>>> runserver) ? if so, where should them be stored? If one .sh file, where
>>> should it be stored?*
>>> *Thank you for your time in advance*
>>> *I appreciated your time and patience.*
>>> *Kind Regards*
>>> *Julierme Pinheiro*
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180416/0adf7d9e/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180416/0adf7d9e/attachment-0001.obj>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180416/0adf7d9e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180416/0adf7d9e/attachment-0003.png>
More information about the geonode-users mailing list
