[GeoNode-users] New Install of GeoNode (Centos7) - error on loaddata step
Ivan Terry ivanterry1 at gmail.com
Tue Feb 6 07:26:37 PST 2018
Hi Simone, here is the output:
$ pip freeze | grep django
django-activity-stream==0.6.1
django-appconf==0.5
django-autocomplete-light==2.3.3
django-bootstrap-form==3.3
django-bootstrap3-datetimepicker==2.2.3
django-braces==1.10.0
django-celery==3.1.16
django-downloadview==1.2
django-extensions==1.6.1
django-forms-bootstrap==3.0.1
django-friendly-tag-loader==1.2.1
django-geoexplorer==4.0.5
django-geonode-client==0.0.15
django-guardian==1.4.6
django-haystack==2.4.1
django-js-asset==1.0.0
django-jsonfield==0.9.16
django-jsonfield-compat==0.4.4
django-leaflet==0.13.7
django-modeltranslation==0.12
django-mptt==0.8.6
django-nose==1.4.4
django-oauth-toolkit==0.12.0
django-pagination==1.0.7
django-polymorphic==0.9.2
django-storages==1.1.8
django-taggit==0.21.0
django-tastypie==0.12.2
django-treebeard==3.0
On Tue, Feb 6, 2018 at 10:08 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Ivan,
> could you check the django version? pip freeze | grep django
> 2018-02-06 15:46 GMT+01:00 Ivan Terry <ivanterry1 at gmail.com>:
>> Hi,
>> New to GeoNode/Django.  I'm following the instructions here:
>> http://docs.geonode.org/en/latest/tutorials/install_and_adm
>> in/setup_on_centos/install_geonode.html  and when I get to the
>> "Initialize Geonode" step:
>> cd /opt/apps/geonode/geonode/python manage.py migratepython manage.py loaddata geonode/base/fixtures/initial_data.json
>> When I run manage.py migrate nothing happens, then when I run loaddata I
>> get the following error:
>> $ python manage.py loaddata geonode/base/fixtures/initial_data.json
>> Traceback (most recent call last):
>>   File "manage.py", line 29, in <module>
>>     execute_from_command_line(sys.argv)
>>   File "/usr/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>>     utility.execute()
>> line 346, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File "/usr/lib/python2.7/site-packages/django/core/management/base.py",
>> line 394, in run_from_argv
>>     self.execute(*args, **cmd_options)
>> line 445, in execute
>>     output = self.handle(*args, **options)
>>   File "/usr/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>> line 60, in handle
>>     self.loaddata(fixture_labels)
>> line 90, in loaddata
>>     self.load_label(fixture_label)
>> line 141, in load_label
>>     for obj in objects:
>>   File "/usr/lib/python2.7/site-packages/django/core/serializers/json.py",
>> line 85, in Deserializer
>>     six.reraise(DeserializationError, DeserializationError(e),
>> sys.exc_info()[2])
>> line 79, in Deserializer
>>     for obj in PythonDeserializer(objects, **options):
>>   File "/usr/lib/python2.7/site-packages/django/core/serializers/python.py",
>> line 96, in Deserializer
>>     Model = _get_model(d["model"])
>> line 168, in _get_model
>>     raise base.DeserializationError("Invalid model identifier: '%s'" %
>> model_identifier)
>> django.core.serializers.base.DeserializationError: Problem installing
>> fixture '/opt/apps/geonode/geonode/geonode/base/fixtures/initial_data.json':
>> Invalid model identifier: 'base.topiccategory'
>> Any help would be much appreciated!!
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180206/9f25b513/attachment-0001.html>
More information about the geonode-users mailing list
