[GeoNode-users] Geonode project problem
Francesco Bartoli xbartolone at gmail.com
Wed Feb 21 11:17:08 PST 2018
Ariel,
are you sure to having started from a 2.6 geonode-project as described here http://geonode.org/geonode-workshop/foss4git2017/#/8 ?
Please double check.
F.
Il giorno 21/feb/2018, alle ore 03:34, Ariel Neri <ariel.neriw at gmail.com> ha scritto:
> Hi, I have just installed a new GeoNode 2.6 (quick install) on ubuntu 16.04 and then followed this instructions to create a new project:
> https://github.com/GeoNode/geonode-project   ( readme.rst )
> however, when i run
> python manage.py collectstatic
> This error comes up:
> Traceback (most recent call last):
>   File "manage.py", line 11, in <module>
>     execute_from_command_line(sys.argv)
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
>     utility.execute()
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/core/management/__init__.py", line 328, in execute
>     django.setup()
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/__init__.py", line 18, in setup
>     apps.populate(settings.INSTALLED_APPS)
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/apps/registry.py", line 85, in populate
>     app_config = AppConfig.create(entry)
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/apps/config.py", line 86, in create
>     module = import_module(entry)
>   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
>     __import__(name)
>   File "/home/admin01/.local/lib/python2.7/site-packages/autocomplete_light/__init__.py", line 7, in <module>
>     from .shortcuts import *  # noqa
>   File "/home/admin01/.local/lib/python2.7/site-packages/autocomplete_light/shortcuts.py", line 8, in <module>
>     from .forms import *
>   File "/home/admin01/.local/lib/python2.7/site-packages/autocomplete_light/forms.py", line 438, in <module>
>     class ModelForm(six.with_metaclass(*bases)):
>   File "/home/admin01/.local/lib/python2.7/site-packages/autocomplete_light/forms.py", line 283, in __new__
>     attrs)
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/forms/models.py", line 247, in __new__
>     new_class = super(ModelFormMetaclass, mcs).__new__(mcs, name, bases, attrs)
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/forms/forms.py", line 91, in __new__
>     .__new__(mcs, name, bases, attrs))
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/forms/widgets.py", line 145, in __new__
> TypeError: Error when calling the metaclass bases
>     metaclass conflict: the metaclass of a derived class must be a (non-strict) subclass of the metaclasses of all its bases
> localhost still points to the default welcome page, and all python manage.py commands throw this same error.
> I donĀ“t know what this error is about. Any advice will be welcome
> Thanks
> Ariel
> 	Libre de virus. www.avast.com
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180221/125e1ae5/attachment.html>
More information about the geonode-users mailing list
