[GeoNode-users] Geonode project problem
Ariel Neri ariel.neriw at gmail.com
Wed Feb 21 13:31:33 PST 2018
I did what Simone suggested:* pip install six==1.10.0*   it was installed
successfully.
Trying again with* python manage.py *i get this error:
  File "manage.py", line 11, in <module>
    execute_from_command_line(sys.argv)
  File
"/home/admin01/.local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
    utility.execute()
  File
line 328, in execute
    django.setup()
  File
"/home/admin01/.local/lib/python2.7/site-packages/django/__init__.py", line
18, in setup
    apps.populate(settings.INSTALLED_APPS)
  File
"/home/admin01/.local/lib/python2.7/site-packages/django/apps/registry.py",
line 85, in populate
    app_config = AppConfig.create(entry)
  File
"/home/admin01/.local/lib/python2.7/site-packages/django/apps/config.py",
line 86, in create
    module = import_module(entry)
  File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
    __import__(name)
  File
"/home/admin01/.local/lib/python2.7/site-packages/polymorphic/__init__.py",
line 13, in <module>
    __version__ = pkg_resources.require("django-polymorphic")[0].version
  File
"/home/admin01/.local/lib/python2.7/site-packages/pkg_resources/__init__.py",
line 984, in require
    needed = self.resolve(parse_requirements(requirements))
  File
line 875, in resolve
    raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (Django 1.8.18
(/home/admin01/.local/lib/python2.7/site-packages),
Requirement.parse('Django>=1.11'), set(['django-polymorphic']))
Francesco, The setps i have followed for creating project are in this
README.rst:  https://github.com/GeoNode/geonode-project
I compared both and are not exactly the same. I did edit the geonode.conf
changing the  WSGIScriptAlias  as it states, wich is not mentioned in the
link you just send.
I now edited back to the original files and tried continuing with your
guide, but I can´t run *python manage.py*, so i´m stuck there.
The error mentions the "requirements". The "requirements.txt" file in the
geonode-project has only one line:
geonode==2.6.3
is that fine?
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Libre
de virus. www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
2018-02-21 16:17 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
> Ariel,
> are you sure to having started from a 2.6 geonode-project as described
> here http://geonode.org/geonode-workshop/foss4git2017/#/8 ?
> Please double check.
> F.
> Il giorno 21/feb/2018, alle ore 03:34, Ariel Neri <ariel.neriw at gmail.com>
> ha scritto:
> Hi, I have just installed a new GeoNode 2.6 (quick install) on ubuntu
> 16.04 and then followed this instructions to create a new project:
> https://github.com/GeoNode/geonode-project   ( readme.rst )
> however, when i run
> python manage.py collectstatic
> This error comes up:
>   File "/home/admin01/.local/lib/python2.7/site-packages/
> django/core/management/__init__.py", line 354, in
>     utility.execute()
> django/core/management/__init__.py", line 328, in execute
>     django.setup()
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/__init__.py",
> line 18, in setup
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/apps/registry.py",
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/apps/config.py",
> line 86, in create
> import_module
>     __import__(name)
> autocomplete_light/__init__.py", line 7, in <module>
>     from .shortcuts import *  # noqa
> autocomplete_light/shortcuts.py", line 8, in <module>
>     from .forms import *
>   File "/home/admin01/.local/lib/python2.7/site-packages/autocomplete_light/forms.py",
> line 438, in <module>
>     class ModelForm(six.with_metaclass(*bases)):
> line 283, in __new__
>     attrs)
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/forms/models.py",
> line 247, in __new__
>     new_class = super(ModelFormMetaclass, mcs).__new__(mcs, name, bases,
> attrs)
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/forms/forms.py",
> line 91, in __new__
>     .__new__(mcs, name, bases, attrs))
>   File "/home/admin01/.local/lib/python2.7/site-packages/django/forms/widgets.py",
> line 145, in __new__
> TypeError: Error when calling the metaclass bases
>     metaclass conflict: the metaclass of a derived class must be a
> (non-strict) subclass of the metaclasses of all its bases
> localhost still points to the default welcome page, and all python
> manage.py commands throw this same error.
> I don´t know what this error is about. Any advice will be welcome
> Thanks
> Ariel
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Libre
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180221/64aeaec4/attachment-0001.html>
More information about the geonode-users mailing list
