[GeoNode-users] Error when installing Geonode 2.6 Ubuntu
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jan 3 01:27:14 PST 2018
Hi, the error shows that you already have geonode installed, it is
suggested to install it on a very clean machine. Moreover, when the
geoserver installations stops, it may indicate that the machine doesn't
have enough power to run it. A 8 Gb server is required.
Regards
2018-01-03 7:18 GMT+01:00 James Mbugua <jmbugua at cordioea.net>:
> I had the same issues and reverted to using ubuntu 14.04
> <http://releases.ubuntu.com/14.04.5/> and it worked.
> James.
> On Wed, Jan 3, 2018 at 5:45 AM, Franklin, Chris - Perth. <
> CFranklin at rml.com.au> wrote:
>> Hi,
>> Im installing Geonode 2.6.3 from PPA on Ubuntu 16.04 but keep getting
>> this error:
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> geonode is already the newest version (2.6.3+thefinal0).
>> 0 to upgrade, 0 to newly install, 0 to remove and 244 not to upgrade.
>> 2 not fully installed or removed.
>> After this operation, 0 B of additional disk space will be used.
>> Do you want to continue? [Y/n] Y
>> Setting up geoserver-geonode (2.9.0) ...
>> Job for tomcat7.service failed because the control process exited with
>> error code. See "systemctl status tomcat7.service" and "journalctl -xe" for
>> details.
>> dpkg: error processing package geoserver-geonode (--configure):
>> subprocess installed post-installation script returned error exit status 1
>> dpkg: dependency problems prevent configuration of geonode:
>> geonode depends on geoserver-geonode | geoserver; however:
>> Package geoserver-geonode is not configured yet.
>> Package geoserver is not installed.
>> dpkg: error processing package geonode (--configure):
>> dependency problems - leaving unconfigured
>> No apport report written because the error message indicates its a
>> followup error from a previous failure.
>> Errors were encountered while processing:
>> geoserver-geonode
>> geonode
>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>> Any ideas what going wrong?
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Best regards,
> James Mbugua
> ____________________________________________________________
> Research Assistant GIS & Remote sensing at CORDIO East Africa #9 Kibaki
> Flats,
> P.O.Box10135 Mombasa 80101,
> ​Bamburi​
> Mobile: +254720978196 <+254%20720%20978196>
>> Skype: mbugua.james1 Email: jmbugua at cordioea.net
>> Website:www.cordioea.net
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180103/13e60358/attachment-0001.html>
More information about the geonode-users mailing list
