[GeoNode-users] Upgraded to Geoserver 2.12.1 -- Unexpected
Toni Schönbuchner toni.schoenbuchner at csgis.de
Sun Jan 7 02:50:44 PST 2018
Dear Unni,
as said I´m afraid I cannot say if geonode 1.7 and geoserver 2.12 are compatible (I would say it should work).
Let´s see what others say regarding your exception. (Alessio?)
Gsconfig is used for manipulating geoserver through it´s rest api. I would check the version you´re using
$ pip show gsconfig. (1.0.8 should be fine) But that's nothing more than a vague guess.
Cheers,
Toni
> Am 07.01.2018 um 11:30 schrieb unni mana <unnivm at gmail.com>:
> Hi Toni,
> Do I need to upgrade geonode as well? The main reason for upgrading geoserver to latest is that I need to use .mbtiles extension. But in order to use this extension, I need to use latest geoserver.
> Geoserver 2.10 does not support mbtiles. I have tried that earlier.
> what are the things I need to look into gsconfig file?
> Thanks
> Unni M
> On Sun, Jan 7, 2018 at 3:24 PM, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Hi Unni,
> Geonode needs a modified geoserver version (because of auth).
> That´s why I mentioned the build resource.
> Unfortunately I´m not familiar with this exception further cannot say if geonode 1.7.11
> and geoserver 2.12.1 are compatible. ( 1.7.11 ships with 2.10 as far as I remember ) .
> I´m sure other users can help you here.
> Just to double check, you´re settings are correct and you brought everything in sync?
> manage.py updatelayers etc … ? Also a look at your gsconfig version could be a first
> step.
> Cheers,
> Toni
>> Hi Toni,
>> I upgraded to latest geoserver (2.12.x ) from that location(http://build.geonode.org/geoserver/latest/ <http://build.geonode.org/geoserver/latest/>) you have mentioned. But when I upload a layer from geonode, I am getting the following error
>> Unexpected excwpti9n 'NoneType' object has no attribute 'store_type'
>> The current geonode version is used :is 1.7.11
>> Thanks
>> Unni M
> If not played, Free Sudoku Android Game <https://play.google.com/store/apps/details?id=com.gamerfan.sudoku>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180107/d8472d3c/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180107/d8472d3c/attachment.sig>
More information about the geonode-users mailing list
