[GeoNode-users] is 2.8 released?
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jan 30 06:28:07 PST 2018
Hi Ariel,
2.8 release will be available soon, probably during the GeoNode Summit
which will happen in March.
There is 2.8.0rc available on ppa:geonode/testing if you want a preview,
and yes, it is based on Ubuntu 16.04.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-01-30 15:13 GMT+01:00 Ariel Neri <ariel.neriw at gmail.com>:
> Hi, I´m about to install a Geonode in a new server. I´m still choosing the
> server to hire.
> And i´m a bit confused about the current version.  I´ve seen in the
> documentation that in some places it says " The current release, 2.8 is
> available only for Ubuntu 16.04." (http://docs.geonode.org/en/
> master/tutorials/install_and_admin/quick_install.html ), but most others
> still mention 2.6 version.
> Is 2.8 version also for Ubuntu 16.04 as it is stated? Should i prepare a
> 16.04 then?
> If the current is 2.6, should i wait for 2.8? if it is going to be
> released soon i prefer to wait, but if not I´ll go on with 2.6 version.
> Thanks.
> Ariel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180130/f6c2aad4/attachment.html>
More information about the geonode-users mailing list
