[GeoNode-users] Authentication problem between Geonode and Geoserver
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jul 6 05:08:47 PDT 2018
It looks like GeoFence rules for Layers have not been created on GeoServer.
1. Check that changing Layer permissions GeoFence Rules are created on
GeoServer GeoServer Admin GUI > Security > GeoFence Rules
2. Check that the options
        'GEONODE_SECURITY_ENABLED': True,
        'GEOFENCE_SECURITY_ENABLED': True
have been correctly set on settings > OGC_SERVER
Il giorno ven 6 lug 2018 alle ore 13:40 Joshi, Jigeeshu <
Jigeeshu.Joshi at ils-forschung.de> ha scritto:
> Hi ,
> I am having trouble understanding the authentication / authorization
> settings between Geonode and Geoserver. I have a problem that , the layers
> in Geonode are not available/ visible unless logged into Geosever with user
> admin. After login to Geoserever as admin, everything works normally.  But,
> every user does not have Geoserver admin credential so in that case, any
> user other than admin would not be able to see the layers.
> Has anyone come across this problem. Any solution is appreciated. Let me
> know if I have not made the problem clear.
> Regards,
> Joshi
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180706/11b0128d/attachment-0001.html>
More information about the geonode-users mailing list
