[GeoNode-users] Authentication problem between Geonode and Geoserver
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jul 6 05:20:44 PDT 2018
GeoFence Data Rules, correct.
Il giorno ven 6 lug 2018 alle ore 14:15 Joshi, Jigeeshu <
Jigeeshu.Joshi at ils-forschung.de> ha scritto:
> Hi Alessio,
> Do you mean Geofence Data Rules ?  There are three option undere Security
> 1.       Geofence
> 2.       Geofence Data Rules
> 3.       Geofence Admin rules
> Geofence data rules looks like one in the image attached.
> Thanks
> Joshi
> *Von:* Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
> *Gesendet:* Freitag, 6. Juli 2018 14:09
> *An:* Joshi, Jigeeshu
> *Cc:* geonode-users
> *Betreff:* Re: [GeoNode-users] Authentication problem between Geonode and
> Geoserver
> It looks like GeoFence rules for Layers have not been created on GeoServer.
> 1. Check that changing Layer permissions GeoFence Rules are created on
> GeoServer GeoServer Admin GUI > Security > GeoFence Rules
> 2. Check that the options
>         'GEONODE_SECURITY_ENABLED': True,
>         'GEOFENCE_SECURITY_ENABLED': True
> have been correctly set on settings > OGC_SERVER
> Il giorno ven 6 lug 2018 alle ore 13:40 Joshi, Jigeeshu <
> Hi ,
> I am having trouble understanding the authentication / authorization
> settings between Geonode and Geoserver. I have a problem that , the layers
> in Geonode are not available/ visible unless logged into Geosever with user
> admin. After login to Geoserever as admin, everything works normally.  But,
> every user does not have Geoserver admin credential so in that case, any
> user other than admin would not be able to see the layers.
> Has anyone come across this problem. Any solution is appreciated. Let me
> know if I have not made the problem clear.
> Regards,
> Joshi
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
> * This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.*
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180706/5ddff3a1/attachment.html>
More information about the geonode-users mailing list
